Helping an old friend out
Discussion in 'The Wood Pile' started by Kevin in Ohio, Dec 25, 2015.
  1. pantelis
    pantelis
    Europe
    Tell me please why you use this notch system and the system with the wedge what you want to control or what to avoid , i think that if the tree is straight up without to have other problems a face cut and a back cut will finish the job also you use and cable for more control so why so much complex methods
    Kevin in Ohio likes this.
  2. S. Roche
    S. Roche
    Nebraska
    Excellent play by play. You have to love the come along. Nice saw logs too.
  3. Chopy
    Chopy
    Upstate NY
    Well said. Giving a hand to those that need it is what should make for a better world. Too bad not everybody thinks this way.
  4. Kevin in Ohio
    Kevin in Ohio
    It just gives you another option when a cable/rope is not really needed. I don't use it that often. The tenon will hold the direction to a point but you do run the risk of a side popper if it has too much lean. Sometimes in the woods it honestly doesn't matter which way it falls, it's just better if you can get it somewhere that makes it easier to work up. Kind of have a hard time following your question on the other "notch system"
    Eric VW and pantelis like this.
  5. Firewood Bandit
    Firewood Bandit
    I believe the intent of using this technique is when relatively small trees are being cut. The wedge won't generate enough lift due to bottoming out on the hinge. The slot cut in the face allows the wedge to be driven in farther without obstruction. Making a bore cut through the face is not complex and can be accomplished in seconds in a small tree like that.
    Eric VW, Chvymn99, pantelis and 2 others like this.
  6. Kevin in Ohio
    Kevin in Ohio
    Exactly. The risk is there is no hinge left essentially once the wedge pops the tenon loose. I always wondered, and I need to try, if you leave a small amount of wood on the lateral cuts right near the face cut if it would still work. that would probably be much safer as it would cut down the risk of a side pop. Maybe next time.
  7. Stinny
    Thanks for the pics of your kickin' ash there Kevin in Ohio... we have a lot of ash here too... nice to work with.
  8. MasterMech
    My only criticism of your technique is that you cut through the hinge on either side of your wedge. That severely reduces the amount of control you have from side weight or wind influence. Leave the hinge and it's a much safer method.
    The method works pretty well on smaller trees that have a slight back lean and would benefit from being wedged over.
  9. pantelis
    pantelis
    Europe
    :yes::yes::yes:
    Eric VW and Kevin in Ohio like this.
  10. Kevin in Ohio
    Kevin in Ohio
    That's exactly what I was thinking about trying to do in the post above. Should have known somebody was allready doing it. Still, I wouldn't do it on a leaner as it wouldn't take much to pop that out on the deep side of the wedge cut.
  11. pantelis
    pantelis
    Europe
    Yes ALWAYS , ALWAYS ALWAYS leave a hinge even a small , the job of the hinge is not to control the tree fall where the face cut is, the hinge keep the tree falling left or right and avoid bad situations.
  12. pantelis
    pantelis
    Europe
    For me if you do this technique without someone pro faller tell it to you , you are a PRO
    Hat off to you:yes:
  13. pantelis
    pantelis
    Europe
    Now lets tell the crazy method
    1 start the back cut and stop when the hinge will start
    2 put a wedge to the back cut
    3 start the face cut first the down cut and then the angle cut
    4 hit the wedge until the tree fall
    God bless you
    Dont try this at home:D
  14. Life In Farmland
    Life In Farmland
    Minnesota
    Nice work! Love it
    Eric VW, Chvymn99 and Kevin in Ohio like this.
  15. Chvymn99
    Impressive... Will have to review this thread later. But great job helping out...
  16. Smokinpiney
    Smokinpiney
    "South" Jersey
    Job well done Kevin! And kudos to you for lending a helping hand. Dad and I use cables/ropes quite often if needed. :yes:
  17. Erik B
    Erik B
    Western Wisconsin
    Kevin in Ohio How far up in the tree do you get your rope or cable and how do you get it up there?
    Eric VW, Kevin in Ohio and Stinny like this.
  18. Stinny
    That's a great question, especially on how to get a rope high in a tree.
    papadave, Eric VW and Kevin in Ohio like this.
  19. pantelis
    pantelis
    Europe
    Stinny likes this.
  20. Kevin in Ohio
    Kevin in Ohio
    Here at my place it's really handy......
    This thing makes anything up high easy. ;)
    I've found that 16- 20 ft is normally enough. We are just using an extension ladder and I carry up a short 5/16 and cable when I climb. dad steadies the ladder. I hook the cable on the top of the ladder till I bear hug the chain on, then hook it in. You have to remember the advantage of pull you have from that height. The higher the better naturally but it becomes a danger thing of putting up a ladder too high. Never had a problem at 16 - 20 ft.
    papadave, S. Roche, Eric VW and 3 others like this.
