Help with Plumbing Waste Drains Problem?
Discussion in 'The DIY Room' started by wildwest, Aug 9, 2015.
  1. rookie1
    rookie1
    Does water drain well from lower fixtures? Sounds like restriction past house heading to septic. Not sure how but I'd try to ug lower fixtures and drain upper tub to see what happens.
    wildwest likes this.
  2. wildwest
    Yes, the lower bath drains fine without a volcano errupting in the toilets or showing up in the septic clean out pipe. Isn't this crazy bananas?
    Stinny likes this.
  3. wildwest
    The new bath is connected somehow to the new plumbing on the kitchen sink, kitchen sink is on same lower level as old bath.
    WildWildWest snaked the main drain the other night, problem persists.
    Stinny likes this.
  4. Stinny
    You and WWW will be really glad you did this riiiiiiiiight about Jan, when it would not be fun at all to play in the frozen septic system... :yes:
  5. wildwest
    x2!
    Oct is not soon enough for me, Yikes Oct 2013 was wicked. But, I am relieved to know we found someone to do it before Jan, and he is well known and in the business several decades now. :handshake:
    (I still have fears of living in the RV this winter if mid Oct is too late :headbang:)
    papadave and Stinny like this.
  6. wildwest
    PS, going to ask if I can get the leech field run a different direction for a possible patch of sod for the lil one next summer :)
  7. Stinny
    Fingers crossed. Let's hope you guys have a mild October this year.
    papadave and wildwest like this.
  8. rookie1
    rookie1
    Not doubting his snaking but there could be a restriction and the snake will pass easy. Has it always done this too or did the water drain fine until one day.
  9. wildwest
    We used this place for vacations for a year, offically moved in late 2013 (septic tank pumped at the same time for good measure). This never happened until we put the new bath into use in early 2015.
    We hired a good plumber, he replumbed existing lower kitchen sink, and also NEW lines for plumbing to NEW higher bath. Immediately I saw the toilets blowing bubbles and called in for a septic pumping. I "assumed" it was the septic, there is no hatch/manhole on this system to inspect it..... That second pumping did not fix it the volcano toilets, but everything drained ok til a month or so ago. It started to overflow water from the septic cleanout pipe when we drained the new tub:doh:
    We have very few building codes and they are not enforced, so who knows what is under the ground. We have a good idea where 1 or 2 leech lines run in the yard, but there is no way to inspect them or get them jetted that I am aware of (unlike my septic at previous home with a large lid, I could have fit down there if I needed to!).
    I believe the septic system is from the 1960's when that owner added a kitchen and old bath. I did not know septic tanks without a manhole were available then? Also, we have an aged galvanized cistern for house water, I can't help but wonder if our septic tank is the same kind but with a cleanout pipe on top for the septic tank?
    A kind septic pump business owner that has been out here in years past was nice enough to trouble shoot with me on the phone, he suggested both a plumbing vent problem AND clogged dirt around leech lines.
    I do think we need a new system. My fear is that the new bathroom tub deluge will clog the baffle on the new system. Is it possible that's what happened here and that it can happen again?
    I apologize, did not answer your question. The old system plugged up in the past, plunger or snake fixed it. Yes, this started to the day we used the new bathtub.
    I appreciate your time for thinking about this :)
    Stinny likes this.
  10. wildwest
    I missed that, what is ug lower fixtures? My mind read that as "plug" instead of ug. Is ug "under ground"?
    Stinny likes this.
  11. rookie1
    rookie1
    plug. not sure how i did that.
  12. Firebroad
    Firebroad
    Finksburg, Maryland
    My condolences! I lucked out, septic system was replaced in my place eight years before I got here.
  13. Stihl Livin
    Stihl Livin
    Minnesota
    Wild West is the drain lines for the lower bath accessible? You could put in a back water valve between where the new plumbing ties in and the lower bathroom. I am a plumber by trade since 97. I have dealt with lots of older things. Minnesota has some if the most strict codes and it definatly sounds like a venting issue. Shoot me a pm if you want to talk more about the issue at hand
    Canadian border VT and wildwest like this.
  14. Stihl Livin
    Stihl Livin
    Minnesota
    I talked with wild west onthe phone tonight and what a wonderful person. It's amazing the people you can meet even via phone call. Hopefully we can get this squared away over pictures and talking. If I would of seen this thread earlier I probably would of just drove the 14 hours out there for the long weekend to get this figured out. It actually has been going through my mind since I read the thread and received some pictures last even. The op had a busy day so we just got back to the issue at hand tonight.
  15. wildwest
    Thank You for the great conversation! We will do the trouble shooting in the next few days... I very much appreciate your time and thought on my plumbing issue friend:handshake:
  16. wildwest
    Main vent inspected from the roof (could not talk hubby into hose) but he took a shop light. All clear.
    Hoping to check the main line via the plug tomorrow :)
    Still on sched for new septic/leech in mid Oct, excavator said he will move us up if possible.
    basod, papadave and Stinny like this.
  17. Stinny
    :yes:
  18. Stihl Livin
    Stihl Livin
    Minnesota
    Glad it goes straight down so he didn't have to use water.
  19. wildwest
    We are fortunate to be moved up in the schedule for new septic system. How did I not realize we would not have toilets for 5 days?!??!?!?
    RV will be out front for solids, but what about early morning potty?
    Looking for suggestions/input please, what would you do?
    Looking at this online
    Stinny likes this.
  20. Stinny
    "How did I not realize we would not have toilets for 5 days?!??!?!?" ... I bet that was fun to hear... :hair: We had a bucket rig like that at the cabin when we first started building. They work. And they're cheap too.
