Help with my Ford 753 Backhoe, Hydraulic Cylinder/Chain on King Post
Discussion in 'Chainsaws and Power Equipment' started by Boog, Jun 20, 2014.
  1. rookie1
    rookie1
    The small lines are probably like vents. I would crack that little line loose and see what comes out. Maybe years of hyd il bleeding by the packing has filled that side of the cylinder. Maybe it's binding the works up.
  2. Boog
    Boog
    Where my spirit is free
    I dove into it yesterday and tried to get the piston on the left cylinder back in. I first cracked its fitting at the control box, just a very tiny amount of oil leaked and then stopped. I tried to work from the side grabbing the chain/piston head in one hand and the rear of the cylinder in the other. Nothing. I removed its hose completely off the fitting and tried again till my pectorals were complaining and gave up, that was not going to work trying to compress it by "2 hands". I then pulled the left cylinder all the way back taking up the slack in the chain. Then I drove 2 wood wedges between the piston head and the frame to try and hold the head tight. The cylinder was now sticking out the back about 5", and I tried pushing against the cylinder to compress it. I tried this several times pushing with everything I had until the wedges would let go with no luck. I could not push that piston back in. I then removed the small rear line from that cylinder, nothing leaked out. I tried compressing that cylinder again and still no go.
    So with both hydraulic lines detached from the cylinder, I could not push that piston back in, too much resistance. I see two things more to try. 1) Unhook the chain and remove that left cylinder out of the housing to see If I can get the piston back in to the "right" spot, then reassemble and try to run it mounted. 2) Mount it up as is and try using the hydraulic power to work that cylinder, then try bleeding things while under pressure to see if I get reach an equilibrium point.
  3. cwn877
    cwn877
    Central Pa
    I would pull the cylinder while you have it off and see what can be determined on the bench. Bleeding under pressure when mounted up I would think is necessary anytime something is done to them and should basically happen every time the are cycled during operation.
    rookie1 likes this.
  4. ilbdarned
    ilbdarned
    Arizona
    I know this question is old but maybe this will help others with this problem.
    I have the 19-481 model Backhoe like yours. The problem you are having is caused by a loss of pressure in one cylinder, whichever side the chain is loose on is the side with the loss of pressure.
    An explanation of how the system works:
    Two lines come off the main control valve and lead to what I will call a balancing valve mounted on the cross support bars forming the X
    From the bottom of that valve the 2 lines feed each cylinder,
    at each cylinder from the balancing valve, pressure is maintained equally when the control lever is in neutral( as long as there is no air in either side), no leaking past the bypass check valve located inside the balancing valve, and no leak in either cylinder, any of which could cause a loss of pressure on one side.
    When you move the lever to swing right, you send pressure through one side of the balancing valve to the cylinder (on your right side as you are sitting in the seat),
    that same pressure inside the balancing valve while your swinging right moves a valve inside the balancing valve allowing pressure from the left cylinder to be sent against the closing force of a check valve with a heavy spring holding it closed.
    The force from the right cylinder as you swing right pulls the left cylinder with the chain compressing the fluid in it, pressure then builds up on the left cylinder forcing the check valve open allowing the fluid in the left cylinder to bleed past it back to the opposite line coming from the main control valve pressure is not being applied to
    During the process of swinging right, although the fluid in the left cylinder is being released, a ( lower than main hydraulic pressure) is being maintained in the left cylinder by the spring holding the check valve closed. This allows a lower but constant pressure in the left cylinder as the main line pressure is being applied to the right cylinder, therefore keeping the chain tight
    If your chain is not tight, you are losing pressure on the side that is loose as you are pulling the opposite direction.
    To troubleshoot, first see if there is air in the loose side cylinder, there are 2 bleed valves on the balancing valve, one on each side for each cylinder . Note since the lines from the cylinders to the valve cross, the right bleed valve looking rearward bleeds the left cylinder, and the left bleed valve bleeds the right cylinder.
    Bleed the side where the hose from the loose cylinder connects.
    If you are sure there is no air in the loose side of the system, it means you are leaking fluid pressure either inside the loose side cylinder, or inside the balancing valve.
    Since there is only one check valve releasing pressure from the cylinder that is being pulled as you swing, a leak past the check valve would cause either opposite cylinder to be lose as you swing either left or right.
    Unhooking the lines and letting the backhoe sit idle is most likely to cause air in your lines. Bleeding would be the first thing to try, then checking for pressure loss on the loose side cylinder and if found changing seals, if no problem exists there, remove the balancing valve and pressure check it as directed below, if it does not hold pressure disassemble it and clean it while checking for wear and changing any seals.
    If you can do a bench test, rig up a way to apply pressure to the cylinder, even air pressure will work, and if you do not loose pressure, and you previously eliminated air in the system being a problem by bleeding it, your problem has to be in the balancing valve.
    To bench test the balancing valve remove it, rig up a way to pressurize the port leading to the cylinder that the chain is lose on, Both TO CYL) ports to going each cylinder should hold pressure bench testing.
    It is basically this simple, while the balancing valve is sitting idle with no input pressure to either top port on the balancing valve which are labeled with an arrow and the words To Valve, both bottom ports with arrows labeled To CYL should hold pressure applied to them. If they don't the valve is leaking inside.
    If the cylinder does not hold pressure, it has a leak inside.
    If both the (To CYL labeled) valve ports and both the cylinders hold pressure, and the lines connecting the two does not leak in either side, and also any air in system was previously eliminated from the valve port to the cylinders, there is no way the pressure will not be maintained on both sides to keep the chain tight while swinging in either direction..
    MasterMech and eatonpcat like this.
