Help ID this muscly tree
Discussion in 'The Wood Pile' started by Yawner, Oct 25, 2019.
  1. Yawner
    Yawner
    Louisiana
    Several small understory trees like this from a tornado blowdown area. The trunks remind me of a muscled up animal. The trunks have ridges all over, making it look like muscly. The leaves look a lot like elm or ironwood. It's pretty heavy and dense. I got them thinking prolly good firewood. Hope someone knows. Maybe 20 to 30 ft tall trees. Biggest I have is maybe six inch diameter.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Sent from my SM-G960U using Tapatalk
    Chaz, JoeinO, buZZsaw BRAD and 8 others like this.
  2. Oakman69
    Oakman69
    Mechanicsville
    Hop hornbeam, iron wood or musclewood. All the same . Great firewood. Seasons in a year. I have some on inventory... Great score!!
    Chaz, JoeinO, Chvymn99 and 7 others like this.
  3. Horkn
    That appears to be a beech of some sort.
    Hop hornbeam is not smooth like that.
    This is hop hornbeam bark
    I'll be collecting a little bit of it as I saw a couple dead ones on my land yesterday.
    Chaz, JoeinO, Slocum and 8 others like this.
  4. billb3
    +1 for looking like american hornbeam
    have some in a corner of the property and they are all full of cankers
    They also tend to sport deer antler rub marks. Probably the size of the tree trunks more than anything.
    Chaz, Chvymn99, bear 1998 and 5 others like this.
  5. Oakman69
    Oakman69
    Mechanicsville
  6. Oakman69
    Oakman69
    Mechanicsville
    Must be different varieties.. check the link I posted.
  7. bang
    bang
    South central Indiana
    Around here we call it ironwood, muscle beech or blue beech
    huskihl, Chaz, bear 1998 and 6 others like this.
  8. Fanatical1
    Fanatical1
    It's american hornbeam or often called blue beech. Great firewood! Needs to be protected from dampness or it can go punky on you. This was a big one, maybe 10" at the base.
    Here's a pic of some of mine. It crazy heavy...
    Ikeholt, Mitch Newton, Chaz and 9 others like this.
  9. Horkn
    You mentioned "hop" hornbeam. There's the difference. It is blue beech.
    Ikeholt, Chaz, JoeinO and 6 others like this.
  10. Scotty Overkill
    American hornbeam, I know it better as blue beech. Never gets real big here, but I saw some bigger examples when at Backwoods Savage 's GTG's, he has quite a bit in his woods.....
    Chaz, Chvymn99, bear 1998 and 6 others like this.
  11. Scotty Overkill
    That's the key.....
    Hophorn grows here too, I used a piece of a trunk to make the handle for my cant hook. That piece was around 5" diameter and had probably around 60 rings in it! Very dense, strong stuff.
    Mitch Newton, Chaz, JoeinO and 10 others like this.
  12. Backwoods Savage
    Yes, it is blue beech. Some call it musclewood. Technically it is in the hop hornbeam family. There are a few who call it ironwood and perhaps rightly so as it does seem to be about as hard as iron. Also, it tends to grow in a clump.
    It does not keep well so if you cut some, burn it within a year.
    Chaz, JoeinO, Chvymn99 and 5 others like this.
  13. Oakman69
    Oakman69
    Mechanicsville
    Agree..
  14. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Agree with the beech. I have several on my property and the bark and leaves are a perfect match. I have a few that are smaller and couple larger that have a lot of bumps and uneven surfaces on them.....they split hard....very hard. Good stuff though if you get it dry.
  15. Yawner
    Yawner
    Louisiana
    Very cool, American hornbeam? Also called musclewood? It sure looks NOTHING like hop hornbeam, surprised they are related. Musclewood, well, that sure fits based on my thread title! I am very pleased to have you guys make this ID, now I know what American hornbeam looks like and what this is! Yes, I found some clumps. I find it interesting you guys said it would go punky, that surprises me, as it is so dense! The bark isn't very thick though.
    What about ironwood, a.k.a. hop hornbeam... does it go punky, too?
    Are there ok in a stack? Need to cover?
    Backwoods Savage, Chaz, MFMc. and 4 others like this.
  16. Horkn
    Hop hornbeam, aka ironwood it's pretty long lasting, but obviously keep it dry and it will last.
    Unfortunately many use the term "ironwood" interchangeably, and this really shouldn't be the case as the only ironwood is the hophornbeam. That, and the hornbeam thing with only the"hop" as the name differentiation.
    Here's a little reading,
    Eastern hop hornbeam and American hornbeam
    Eastern hop hornbeam , (Ostrya virginiana) is in a completely different genus than
    Blue beech, aka musclewood ( Carpinus caroliniana) . Then again, I'm no botanist, although I did take some 5 credit botany classes in college and I've stayed at Holiday Inn Expresses in the past. ;)
  17. billb3
    Yes american hornbeam and american hophornbeam are not the same tree although the leaves look a lot alike.
    unfortunate and confusing similarity in names
    ironwood is unfortunately a nickname or common name applied to a long list of trees
    Ironwood - Wikipedia
  18. Karvinkanuck
    Karvinkanuck
    Blue Beech
    Backwoods Savage and Chaz like this.
  19. buZZsaw BRAD
    Nice rehandle Scotty Overkill :thumbs: Did you use a lathe?
  20. buZZsaw BRAD
    We always called that ironwood (which i guess isnt the correct name)and yup it never got that big. Great firewood though.
