Heating Area with Loft
Discussion in 'Modern EPA Stoves and Fireplaces' started by Lowbid, Sep 4, 2021.
  1. brenndatomu
    You could...but most people just use flex liner the whole way...make sure you spring for the insulation blanket for it too...provides a nice performance increase and also makes the liner "legal"...helps the liner run/stay cleaner too.
    Highbeam, amateur cutter and moresnow like this.
  2. Lowbid
    Lowbid
    Tower, MN
    OK thanks.
    I see they make an insulated flex liner. Is that the way to go or is the wrapped blanket a better option?
  3. brenndatomu
    I've used both...I really like the pre-insulated stuff, but it is a lil more money too...if you have a tough install I'd recommend it though...it will take a little more "install abuse" too.
    amateur cutter likes this.
