Hearthstone green mountain 60 sucks
Discussion in 'Modern EPA Stoves and Fireplaces' started by Homemade, Jan 11, 2023.
  1. Canadian border VT
    Put a box fan in corner and blow cold air to stove
    wildwest, Hoytman and theburtman like this.
  2. Well Seasoned
    Here are a few things that will work for you. Due to strict epa regulations, the amount of incoming air is restricted so much that some stoves including the gm60 are having issues with really long ignition times, smoke spillage ect. Yes, outside air might help, but as a dealer we've found a fix to these common issues.
    - sub par wood
    -dumb but possible, the data plate underneath the stove could be blocking the air inlet- I've seen it happen
    - "some" in the production year 2020-2021 of the gm60's had the air port (the one just inside the firebox, middle front) incorrectly sized. Contact your dealer for the different air port.
    - the baffle was made too deep, adding to the smoke spillage. Trimming the back of the baffle about an inch from the left to right or vice versa fixes most of that.
    - The dealer should bring a piece of stove pipe with a hole in it and measure the draft going up the chimney to see how that looks.
    - If the above don't fix the problem, the air port can be step drilled out creating a bigger hole. This may take time, increasing the size, testing with a burn, increasing size testing the burn ect. You do not want to make the hole to big.
    Try these things or have the dealer. These are all good fixes
    wildwest, moresnow, ole and 4 others like this.
  3. Homemade
    Homemade
    Wisconsin
    Thanks. Perhaps you could better explain trimming the baffles. I’m not quite seeing it in my head by your description
  4. Well Seasoned
    There is a channel piece that runs across the front, left to right. Remove that, remove the baffle and just trim off an inch of material from left to right. That way the depth of the baffle will be less.
    JimBear likes this.
  5. Homemade
    Homemade
    Wisconsin
    Gotcha
    Well Seasoned likes this.
  6. Hoytman
    Hoytman
    OH
    For those reading this into the future…
    I’m sorry, but if a window is near the stove (or far way…doesn’t matter) and is opened some and the stove still isn’t operating correctly, regardless of brand of stove, then an outside air connection isn’t going to help. Something else is the cause of the issue. That is called guessing and hoping.
    Cold air drops to the floor from any open window and will travel towards the stove as part of natural convection currents.
    The point: Look for the cause as being something else besides needing an outside air connection. Again, if an open window doesn’t help your stove draft better then the house is already leaking plenty of air into the home…enough for proper draft. Look elsewhere for the cause of stove mot running correctly.
    theburtman likes this.
  7. Old Nate
    Old Nate
    Western PA
    Yeah I’d like to know what they ended up doing. I feel the OAK prob was not needed. Adding extra 2’ of chimney and using good dry wood prob fixes all the issues. My guess anyway.
    Hoytman likes this.
  8. Homemade
    Homemade
    Wisconsin
    The outside air kit was not added. The two feet of extra chimney was. My parents are going to get into “better” wood that isn’t so soft and so on. We took down a few dead ash that had a summer to finish seasoning and are more solid then last years wood.
    I think giving the baffle a trim will help with the smoke spillage during starting and reloading.
    Only time will tell
    billb3 likes this.
  9. Old Nate
    Old Nate
    Western PA
    What do you mean giving the baffle a trim? I'm not opposed to making adjustments, even on OEM parts, but trimming the baffle... I would think that is something you don't need to do.
    Hoytman likes this.
  10. Hoytman
    Hoytman
    OH
    By design, there should be no need to trim the baffle, or else every stove they sold was wrong and needing the same. I highly doubt this is the case.
    Old Nate likes this.
  11. Old Nate
    Old Nate
    Western PA
    I agree. Now I understand the Green Mountain is a newer stove and maybe it has some quirks, but there's another thread going about the GM 60 and the original poster is more than happy with it's performance. So, yeah i think there could be some other issues at play... wood, draft, etc. I'm interested in the thread because I bought a Hearthstone Manchester that I need to install this fall.
  12. Hoytman
    Hoytman
    OH
    Be sure and install a stove pipe damper…whether you need it or not. It’ll be there if and when you need it. If you don’t need it, simply leave it open all the time, but don’t make the mistake that others do.
  13. Old Nate
    Old Nate
    Western PA
    Did not have a damper at my old house for my Oslo 500... most people don't have one on their chimneys, right?
  14. Homemade
    Homemade
    Wisconsin
    Most newer stoves don’t need a damper because they are tighter then the older stoves and the intake regulates air flow without slowing down the exhaust. You’ll only need a damper if the intake on low still and she still cranks out the heat.
  15. Hoytman
    Hoytman
    OH
    I don’t agree with any of that, but believe what you wish.
  16. Old Nate
    Old Nate
    Western PA
    What stove do you have?
  17. Hoytman
    Hoytman
    OH
    Should I list them all?:rofl: :lol:
  18. Old Nate
    Old Nate
    Western PA
  19. Highbeam
    Highbeam
    Most newer stoves, noncats especially, are the opposite of air tight. They purposely have tons of holes and openings wide open to allow lots of air to keep combustion temperatures way up in order to be clean burning. Folks on this forum and others have gotten quite the lesson with learning how to reel these stoves in to gain control back. Getting proper draft is the best way to regain control and that is best done with a key damper if your chimney system drafts too hard. It's usually not needed with low drafting chimneys that meet the specification of the stove. Even if it's not needed, the key damper doesn't hurt anything and can be very helpful when you have a chimney fire or outside temperatures or wind cause temporary overdraft and your stove goes nuclear.
    brenndatomu likes this.
  20. Canadian border VT
    ^^^ I agree probably because my natural draft is ridiculous.
