Harman PF100 furnace
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ECsaws, Jan 14, 2017.
  1. Lousyweather
    Lousyweather
    feed rate wont make a real difference in heat, unless you set it too low. Do that, and you might be replacing your auger weldment......
    ivanhoe likes this.
  2. ivanhoe
    ivanhoe
    Northern Ontario
    Check which auger motor/rpm you have on, hopefully the previous owner switch it with a different one. It's as been known to happen. This has nothing to do with why the furnace is not shutting down but more on feeding to fast.
    jtakeman likes this.
  3. ECsaws
    ECsaws
    It has a 10rpm on it the new one I have is 6rpm
    ivanhoe and jtakeman like this.
  4. ECsaws
    ECsaws
    I hate to say to much cuz I'll jink my self lol.
    But here I go I put the new 6 RPM auger motor on.
    Not sure this all makes scenes but this furnace has never worked this good.
    Keeps a smaller fire when not working, blower dosnt turn on and off because chamber is hot.
    And to beat all it actually shut its self down when I turned the t-stat down
    Is this posable ??????
    imacman, DexterDay and ivanhoe like this.
  5. ivanhoe
    ivanhoe
    Northern Ontario
    There you go :D
    My hunch was off base but came through :whistle:
    Let's see how it goes from here:yes:
  6. DexterDay
    DexterDay Administrator
    Northeast Oh
    Even at idle it should cycle the blower. Eventually enough heat builds up and it has to cool itself off. But it's a long interval of off and on. When it's calling for heat? The distribution blower should run constant.
    With a auger that has less RPM it should have a smaller fire and still kick on/off? For the distribution blower to run constant when it's feeding less Pellets? It's boggles my mind. But if it's working properly? Go with it!! In these temps I keep my Fahrenheit in Tstat mode (never shuts off) so that it is always making a little heat even when the Tstat isn't calling for heat. Gives me longer cycles between idle and high heat.
    imacman and ivanhoe like this.
  7. ECsaws
    ECsaws
    I'm not concerned with the blower coming on but when it was raising the house temp 3-5* with out the furnace actually working I don't think that's rite? , may as well be using a uncontrollably wood burner .
    When it's cold and t-stat is left alone I don't think it would ever go out. From my testing it appears it takes a min of 30 mins with out T-stat calling for it to shut down.
    So far, from what ever freak reason it running like "l" think it should now
    DexterDay, imacman and ivanhoe like this.
  8. DexterDay
    Northeast Oh
    :thumbs: Cant argue with that!
    ivanhoe likes this.
  9. Lousyweather
    Lousyweather
    the blower actually checks the temp in the plenum and operates from that, basically independently of the stove temp, depending on the temp settings of the plenum switch....and that part is something that we do occasionally sell.
    ivanhoe likes this.
  10. Lousyweather
    Lousyweather
    lets way oversimplify this.....
    all the blowers work.
    both feeders work.
    the circulation blower seems to work.
    What controls it all? The CB and probe. They tell the stove when to feed, shut down, etc. Im wondering if the probe is reading incorrectly (never getting down to "shutoff" resistance), or the new board is simply faulty. A check with the DDM will tell you what the probe reads.
    I have seen new circuitboards be bad (not so rare). Ive seen new probes bad (rare).
    OP mentioned the vac switch bypassed. This allows the feeder to run when it shouldn't be able to. Its simply closed or open. Check continuity.....at normal atmospheric pressure, its open. If a vacuum exists >-0.15 " water, it closes, energizing the feeder and igniter circuit.
    As for why the fire is staying in even at off, takes me back to CB or probe.
  11. ECsaws
    ECsaws
    IDK it's decently odd ...
    I'm not sure what a DDM is or how or what I need to check it ... like I said I'm not beyond buying maintenance equipment... I'd rather be sure than buy more parts.
    With the 6RPM motor everything appears to be working as it should even the vac switch is hooked up and working.
    I know there's a concern with the slower motor " back burning" into the pot I don't want to create more issues.
    I ordered all new gaskets and have intentions of striping furnace soon inspecting and replacing anything that looks bad.
    Just for chits&gigles I put the 10rpm motor back on today it went rite back to its old way ?
  12. ivanhoe
    ivanhoe
    Northern Ontario
    Strange indeed:loco: :crazy:
  13. ECsaws
    ECsaws
    Ok I have my furnace completely tore down , did a super clean job on it ( almost looks new inside now)
    I've been able to find all the gaskets/parts I need but one item.
    I noticed the little glass window in the door has a hair line crack in, I'd like to replace it but my dealer says the glass and gasket are NLA. So I'm hoping one of the older dealers may have one on shelf .. if anyone has one or knows of one let me know ... if I can find one guess I'll weld a plate over the hole.
    imacman, ivanhoe and jtakeman like this.
  14. imacman
    imacman
    Denver, NC
    If this is a window that's exposed to the firebox, it's not glass but ceramic "glass". If you can get it out, a local glass shop should be able to cut you a replacement.
    jtakeman and ivanhoe like this.
  15. Lousyweather
    Lousyweather
    Yup. Ceramic "glass". I know of no dealer who stocks it. Ive never seen one broken before. My local glass guy keeps glass and cuts to size.....maybe one near you?
  16. ECsaws
    ECsaws
    Great idea I'm sure I can get one cut .. guess I'd have to male a gasket also
  17. DexterDay
    Northeast Oh
    Gasket is the easy part in my opinion. Let me know if you need help. I have plenty of flat gasket material
    ivanhoe and imacman like this.
  18. oscarmaggie
    oscarmaggie
    Wisconsin
    I have the same problem that EC does. My PF100 won't shut down, regardless of what I set the thermostat to. It kicks on and runs a small maintenance fire until it is out of pellets. When I change the ESP (black wires) the problem goes away for a while or so but then the stove starts doing it again. I've gone through quite a few ESP's over the years. I clean the probe regularly and I am careful not to damage it. My question is about changing to the newer revision of the CB and the red wire EDP. I've been told that red ESP is more durable and will last longer. I was wondering if any of you guys have any thoughts/opinions on this. I feel like I am wasting a lot of pellets.
  19. ivanhoe
    ivanhoe
    Northern Ontario
    Welcome to FHC oscarmaggie:cheers:
    The furnaces aren't quite running yet so the furnace folks are still enjoying summer:D
    I'm sure someone will pop in soon enough:)
    You can PM Lousyweather as he's the Harman guru:smoke:
  20. imacman
    imacman
    Denver, NC
