Harman PF100 furnace
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by ECsaws, Jan 14, 2017.
  1. Mr._Graybeard
    Mr._Graybeard
    Ixonia, Wis.
    FWIW, I got what I believe was the final burn pot revision for my PB 105, and it has held up well through nearly three heating seasons and at least 15 tons of pellets. So I *believe* Harman did eventually build a burnpot that stands up to the rigors of a high-BTU unit. And yes, they are pricey.
    Jay Z, ivanhoe, imacman and 1 other person like this.
  2. ECsaws
    ECsaws
    As it turned out this one had the burn pot replaced at some point , not sure if it's the PB 105 but as of now it looks great.
    I have the original one that I believe could be fixed it's not that bad really.
    I see some one is making a SS pot also
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    Shucks guys! You're making me blush!!
    ECsaws went from no stoves, to having 4 in a matter of what seemed like days ;) lol. Sold his Englander and looking to sell his Quad CB 1200 if anyone around Ohio is looking for a nice solid stove.
    Now he has two awesome units!! The PC-45 in his shop and the PF-100 in his home!!
    I have 2 awesome pellet stoves, but his 2 Harmans were acquired within 2 weeks of one another and he now has the ultimate setup!! :thumbs:
    ivanhoe, imacman and will711 like this.
  4. DexterDay
    Northeast Oh
    And he got numerous extra parts with each unit (extra burn pot with each stove, combustion blowers, auger, etc). He has well over $1,000 in parts and most are interchangeable (auger, combustion blower).
  5. will711
    will711
    Pocono Mts.
    No worries Bro , you know your Chit
    ivanhoe, imacman and DexterDay like this.
  6. Mr._Graybeard
    Mr._Graybeard
    Ixonia, Wis.
    Looks like the PF100 and PB105 pots are interchangeable. Harman & Heatilator Furnace & Boiler Firepot | Earth Sense Energy Systems
    ivanhoe and jtakeman like this.
  7. ECsaws
    ECsaws
    Question for the harman gurus
    In the warmer weather like we are having shouldn't the p100 shut down ( fire go out) after it sets idol for a while ?
    I'm sure it never burnt ( blower turned on ) yesterday yet fire still going in pot ? It's in auto.
    ivanhoe likes this.
  8. Lousyweather
    Lousyweather
    yup. It should.
    ivanhoe likes this.
  9. ECsaws
    ECsaws
    It's not something must not be rite or not working
    ivanhoe likes this.
  10. ECsaws
    ECsaws
    Almost like the feed auger isn't shutting off ?
    ivanhoe likes this.
  11. DexterDay
    Northeast Oh
    What mode is it in?
    ivanhoe likes this.
  12. Lousyweather
    Lousyweather
    try turning the room temp down a bit lower and see if that works.....probs a bad CB
    JZM2CC and ivanhoe like this.
  13. ECsaws
    ECsaws
    Auto
    ivanhoe likes this.
  14. ECsaws
    ECsaws
    I turned it down as far as it would go , it still keep fire in pot
    ivanhoe likes this.
  15. ECsaws
    ECsaws
    Looking at electrical diagram it appears the low pressure switch has been by passed but previous owner ?
    Not sure what it dose could that have anything to do with it ?
    ivanhoe likes this.
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Would need the rest of the circuit. Something in addition to the low pressure switch needs to be bypassed. Running with the vac switch bypassed isn't safe.
    ivanhoe likes this.
  17. Lousyweather
    Lousyweather
    if someone bypassed the switch, it was to get it running when the switch was shutting the igniter and the feed motor down...usually indicative of another issue that the bypasser couldn't find or fix. Safety device....bypass it at your own risk. It would have no bearing on the fire staying lit though........its either a bad ESP or circuitboard
  18. ECsaws
    ECsaws
    When you say ESP are you referring to the wire probe or ? I have a probe I could try. But I'm sure it's what ever cost the most that's my luck
    Lousyweather, ivanhoe and jtakeman like this.
  19. ivanhoe
    ivanhoe
    Northern Ontario
    Probe in the exhaust passage, usually a black or red single wire. It should be at the end of the furnace exhaust outlet. The cheapest compare to CB!
    jtakeman likes this.
  20. Lousyweather
    Lousyweather
    my luck usually as well.....make sure you replace the probe with the same wire color probe....all will work, but you'll have circuitboard settings to change if they aren't the same
