Harman P68 did not shut down
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by gbreda, Nov 15, 2015.
  1. ivanhoe
    ivanhoe
    Northern Ontario
    We let the HD Gremlins on site, now they are residing everywhere:headbang: Hope you find a quick solution:D
    ttdberg, gbreda, bogieb and 1 other person like this.
  2. gbreda
    gbreda
    NH
    Like most pieces of electronics. Unplugging might clear a glitch.
    ttdberg, CleanFire and jtakeman like this.
  3. bogieb
    HD will assimilate everything :dex:
  4. imacman
    imacman
    Denver, NC
    Had the same issue here. Battery back-up on the 'puter switched to battery 3-4 times during the wind, but only for 3-4 seconds.
    bogieb, ttdberg and CleanFire like this.
  5. subsailor
    subsailor
    Winthrop, Maine
    When turning the dial from stove temp to room temp or vice versa, if you don't pause in the off position until the status light goes out you're still in the original mode. So if you were in room temp and turned the stove off and it didn't shut down. So when you got up and the stove was running and the status light is on, you were still in room temp. If you then turned it to stove temp without the light going off, you're still in room temp. If you then turned back through the off position to room temp and the light never went off, you are still in room temp from the night before. Hope this makes sense.
    CleanFire, gbreda, imacman and 2 others like this.
  6. jtakeman
    Maybe after a few more beers! :D
    :zip:
  7. gbreda
    gbreda
    NH
    It does make sense but I was pausing at the off position and it did not make a difference. Since that night, I am making sure that the Status light is off when I shut down.
    So far so good after the reset as well as removing the board and cleaning the contacts. I still dont have anything to put in the pots, but just turning them many many times might have cleaned them up a bit as well
