Harman Advance shutting down
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by cliffmac, Apr 16, 2019.
  1. cliffmac
    cliffmac
    Cleveland NY
    Thx for the info i could just get my fingers in there, and felt the buildup, so i bent a screw driver to scrape it clean. when i was done it was nice and smooth in there.
    Cliff
    imacman, ivanhoe and Lousyweather like this.
  2. Lousyweather
    Lousyweather
    so youre probably all good right now......cleaned, and added a bypass tube....good for another 20 years!
    imacman and ivanhoe like this.
  3. badbob
    badbob
    There is a sticker on the control board, a part number. That can be compared with part numbers on the net,parts suppliers. In my limited experience with the newest versions(the "platinum board"), you may get slightly less heat at max, the flames may not totally roll over the top of the inside of the firebox and lick the glass. Also, room fan comes to high speed quicker,and stays on longer,when stove is cooling down. Also,combustion blower acts different,(yes, there are still people that think a Harman combustion blower runs at the same speed,all the time,but it does not), but I did not record and document the combustion blower readings on my Harman test meter,when I was doing testing. My overall opinion of the newer board,slightly less heat,possible more heat wasted out the flue,but, much cleaner stove. Same as when I put the very last produced programming prom in my Austroflamm, same results. Normally we would call that progress. Enjoy your stove. I very recently purchased a P68(older,but good shape) for my sister, hauled it up to them,showed BIL how to clean it,he could not believe a 1 ton cleaning could be that easy,after using their prescott for so many years.
    ivanhoe, Lousyweather and imacman like this.
  4. cliffmac
    cliffmac
    Cleveland NY
    Thx Bob for all your expertise and advice
    Cliff
    ivanhoe, badbob and imacman like this.
