Handheld propane torch
Discussion in 'Chainsaws and Power Equipment' started by Eckie, Jan 25, 2023.
  1. Mrxlh
    Mrxlh
    Dat Boot
    It’s the torch itself, I bought a cheap one for starting charcoal chimneys, it does the exact same thing. My turbo torch that is almost 30 years old does not. I lay the bottle horizontal on it all the time lighting the charcoal chimney, zero issues.
    clemsonfor, Screwloose and JB Sawman like this.
  2. Mrxlh
    Mrxlh
    Dat Boot
    Mapp will work on any torch that works correctly, mapp does use a little more air, (you might not get all the available BTU out of the more expensive gas) but will still work none the less.
  3. Mrxlh
    Mrxlh
    Dat Boot
  4. Eckie
    Eckie
    On my weber grill, I've done the same, not sure if its the same problem though.... Then I read that the grill has a safety feature. If you have any of the burners turned to "on" when (before) you turn the gas bottle valve on, it senses that there is a leak and will not run at full speed. Make sure the burners are off, open bottle valve, then turn on a burner and ignite. After realizing the grill had this safety feature, I haven't had any more issues...
  5. In the Pines
    In the Pines
  6. KSPlainsman
    KSPlainsman
    Kansas
    I have never heard of that either. Something else to keep in mind. Thanks.
    clemsonfor, Eckie and Screwloose like this.
  7. Screwloose
    Screwloose
    It's a good thing to have.
    If say for instance a turkey frier fire melts through the hose it won't start violently spraying propane everywhere.
    brenndatomu, Eckie and KSPlainsman like this.
  8. clemsonfor
    I have a cheapo expert grill or whatever from Walmart and sometimes with a new bottle I get a low flow situation. Unhooking and rehooking it up fixes that as well.
    Eckie, KSPlainsman and Screwloose like this.
