Is it normal to get a fair amount of junk out of a bars grooves between filling the tank? I`ve started flipping the bar between fillings and noticed a lot of junk needing to be removed. Thanks
Depends on the wood mostly. I've had more build-up in hardwoods with thick bark or cutting standing dead trees than something like Maple or Oak.
Some of it is determined by how sharp your chain is. Sharp chains pull chips, dull ones create dust which can pack the bar grove.
Some, you will get more junk in there if the chain is really loose. A slightly loose chain shouldn't matter much.
I seem to have gunk in there every time I clean the saw. I put a piece of stiff wire in the toolbox the right size to clean it out. I clean & turn the bar after every cord or 2. Maybe it should be left in there, it's soaked well with oil ?
Wet or dry, sharp chain or not.. you will get plenty of crud that will build up in the bar groove. I dont have a routine, but clean it out when I have the chain off. Stihl makes a depth gauge (non progressive), with a nice little bit on the end for getting down in the bar channel.
I clean my saws after I cut - I run compressed air down the groove (away from the sprocket) and most of the build up gets blown out - also run air through the oil hole in the bar - they get build up pretty quick. Every once in a while I'll take a piece of broken piston ring and run down the groove, but normally not much there - the air does a pretty good job. Cheers!
Isn't there some kind of rule of thumb with coins? The dime is .050", penny .058 and a nickel for .063?
Gotcha, ya one day last year i grabbed a dime to clean the grooves just to try and it worked pretty good. Penny works great too for .063
