Guess I'd better get the rest of my stash
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by 343amc, Oct 2, 2014.
  1. 343amc
    343amc
    Northeast Lower Michigan
    This was on the news tonight.
    http://fox17online.com/2014/10/02/heating-pellet-prices-rising-ahead-of-winter-season/
    Last year when 'pellet shortage' was said on the news (this same particular channel) it was like a bread and milk run when the weatherman says 'blizzard'. Last winter, you could buy full tons the day the story about the pellet shortage aired, next day you could only buy 10 bags at a time. Strangely enough, this particular channel is the only one who ever mentions anything about pellets, and the store mentioned is one of the most expensive places in this area to buy anything pellet related.
    I guess I'm proud to be one of the hoarders mentioned at the end of the article. I won't be cold come February. :dex:
    Well Seasoned, DexterDay and imacman like this.
  2. bogydave
    Pellets were on the news here.
    Political talk about "Biomass fuels"
    Talk was about NG shortage + higher NG prices
    several new pellets stoves installed this year.
    Most pellets are barged up to Alaska.
    The need for a pellet plant in the Anchorage area.
    Stock up. Better to have some left over. :zip:
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    It's always better to be a Hoarder!! Doesn't matter if it's coal, corn, pellet, wood, or any other sold fuel/biomass!!
  4. Gasifier
    I have not even started buying pellets for the camp yet. Have some left over from last year to get started with. I have heard from a few places they have sold everything in the next load or two loads they have coming in. WT_? Are any of you guys having problems buying right now?
  5. jtakeman
    Certain places in CT seem to be having issues getting them. My area is skimpy, But you can get them. All 3 box stores have a decent supply. The 2 pellet houses have many brands listed as sold out or out of stock. Made me a bit nervous so I packed in an extra ton to be sure we have a full seasons worth. I will still add more as soon as I have room to.
    Lots of panic from what I see this season! Not so much a shortage, But more like getting batteries before a major storm. Once the rush settles, Things should ease a bit. But if it does get very cold like last season, I'm not sure well find much come mid February??
  6. 343amc
    343amc
    The store by me still has about 20 tons available. I'm picking more up tomorrow.
    On my way to work this morning, one of the local talk radio shows was talking about a propane shortage, propane prices being higher than last year, etc. I've always been curious what prices for gasoline, heating fuel, etc would be if the media kept quiet and just let the market dictate prices. Seems every time I hear 'gas prices haven't been this low in X months', they fly up 30 cents a gallon the next day.
    I figure I'll have enough for a bad season. If it ends up not being so cold, I'm that much farther ahead next year. If winter is brutal, then I pick up 10 bags at a time to make it through.
    Well Seasoned likes this.
  7. bogydave
    What's your other heat .
    I have a NG furnace. Use it thru Spring & Fall to take the chill off when needed.
    NG in the garage & shop set for 40/45°
  8. 343amc
    343amc
    My 'real' furnace uses heating oil. In addition to the pellet furnace, I have a wood burning fireplace insert and a pellet fireplace insert. Oil is the last thing I burn if I have anything to say about it. :)
    The nearest NG is three miles away. There is a line that gas and technology (cable TV and high speed internet) doesn't cross.
  9. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    343amc I thought I read that you got your pellets at TSC? What brand did you get?
    Gary
  10. 343amc
    343amc
    I get mine at Family Farm and Home. They have Pro Pellets early in the year, then switch to Michigan pellets later in the season.
  11. Gary_602z
    Gary_602z
    How are the ProPellets? I got 2 tons of them from TSC on their early buy and then another from my stove dealer with my insert. First year with pellets.
    Gary
  12. DexterDay
    Northeast Oh
    Pro Pellets are a very good pellet. If you are a first year burner and don't want to gamble? It's one of the brands you want in your stash!!
    343amc likes this.
  13. savemoney
    Pellet Pigs to the rescue!
  14. 343amc
    343amc
    They're a good pellet. Decent heat, low ash, all around good for the price. And they're made in Michigan (White Pigeon, right on the Indiana line).
    Somersets burn a bit hotter, but they're also around $40/ton more.
  15. bogydave
    3 heat systems, you'll never freeze out . LOL :)
    I hear you about oil, high $$ dollar . Same here most expensive is oil.
  16. 343amc
    343amc
    Oil is priced as low as it's been for the past couple years. Mine was filled last in 2010 (I think, maybe 2009), and I have just under a half tank.
    I only ran two bags through the pellet insert last season, and that's when the power was out and I was running on generator. My pellet furnace is manual ignition, and when the power goes out it has to be manually started from the ground up, even if it was just a short outage and it's still at running temp. The insert is auto ignition and will pick it where it left off as long as it is still at operating temp.
    I try not to use pellets until at least November. Before that it's wood. In the dead of winter when it gets to 10 degrees or below I burn both wood and pellets. And run a humidifier. :)
  17. jtakeman
    save, You lost a lil weight I see!! ;)
    eatonpcat, subsailor and smoke show like this.
  18. smoke show
    smoke show
    Pittsfield, Wi
    :rofl: :lol: :picard:
    eatonpcat and jtakeman like this.
  19. jtakeman
    Sure go ahead and laugh, Wait until the Mrs. puts your lard furry butt on a stinkin diet! :p
    SmokeyTheBear and savemoney like this.
  20. savemoney
    Actually I have. Just came back from the fall rally of Maine Tops (take off pounds sensibly ) it is a support group for people trying to loose weight. I was the top male looser for the summer competition in this state. About the only time being called a looser is a good thing. I still have a huge journey ahead for me, but I ssem to be off to a good start.
    343amc, DexterDay, subsailor and 3 others like this.
