Groundhog Max
Discussion in 'Chainsaws and Power Equipment' started by Gary_602z, May 28, 2014.
  1. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    Ooooooh. . What a fantastic machine. .
    That would be great to use.. From a home garden, all the way to a full blown food plot!
  3. bogydave
    An uncle had one in WV.
    His ATV wasn't big enough to work it very well.
    He was going to put in a big food plot, but ended up pretty small & a lot of hand work.
    What size ATV you plan on using?
  4. Gary_602z
    Gary_602z
    Polaris Sportsman 500
    Gary
  5. Chvymn99
    The only killer on that might be the IRS on the Sportsman, allowing it to push up the suspension... Just a thought...
  6. bogydave
    If you have level ground & it's been worked before, should do ok.
    Add some weight to the rear might help too.
  7. MasterMech
    I know lots of folks do it, but how do ATVs hold up doing heavy ground engaging work like this? Most that I have seen do not have very heavy frames and I could see an attachment like that bending/breaking things.
    What does this thing cost?
  8. jetjr
    jetjr
    Pa/Md line
    Seems to me that you would always be riding on the strip you plowed on the pass beforehand. I have seen them at tractor supply and they don't seem very wide.
  9. nate
    nate Banned
    Palmer, AK
    $400 for that thing! Sucker born everyday I guess!
  10. lukem
    I've considered buying on in the past, but I can't get past the $400 tag.
    I can borrow a small 36" disc when I need it for a case of (cheap) beer to pull behind my quad.
  11. lukem
    The part of this setup that scares me is there are no shear pins....so if you hit a big root or rock at any kind of speed you're probably going to break something on the quad.
    I wouldn't want to run any kind of ground engaging stuff every day on a quad because it does work them pretty hard. When I pull a disk with mine I put in low range and take it easy...and only do it twice a year.
    concretegrazer and MasterMech like this.
  12. MasterMech
    Pulling that disk is probably a lot easier on the quad than the ground hog doohickey.
  13. lukem
    Is it? I don't know. I load the disc down pretty good with block. And it's almost twice as wide as the groundhog. Seems like the disc should be harder. I honestly don't know though. I wouldn't want to do much more with mine...and it has a good amount of low end thump.
    concretegrazer likes this.
  14. concretegrazer
    concretegrazer
    Southwest MO
    You'll have to work the ground in reverse with this groundhog thing or you'll end up making a ditch.
  15. Gary_602z
    Gary_602z
    We will find out, got one coming!:popcorn:
    Gary
    Chvymn99, concretegrazer and lukem like this.
