Gooseneck trailer question
Discussion in 'Everything Else (off topic)' started by VOLKEVIN, Dec 27, 2017.
  1. Camber
    Camber
    Montana
    We call them beavertails too!
    rdust and huskihl like this.
  2. Greg
    Greg
    I have always called mine a gooseneck, but effective immediately, it shall be a beaver tail. Much cooler name.
    And since deck over is higher, I cannot overstate how helpful drop sides are. I can load mine from 3 sides and sometimes just split right off it using a medium length pickeroon
  3. mdavlee
    mdavlee
    14 4x5 is pretty well maxed out on 14k. 5x5 you're over by a good bit. We're using a dual tandem now with 12k lb axles. I seen a PJ trailer today that the neck was 16" above the bed of a Dodge mega cab 3rd gen.
    rdust, Camber and huskihl like this.
  4. VOLKEVIN
    VOLKEVIN
    Shenandoah Valley, Virginia
    Like Michigan hiring Harbaugh? HAHAHAHA...
  5. VOLKEVIN
    VOLKEVIN
    Thanks for that info. I need to go lay eyes on a PJ...and I could always cut the hay back to 10-12 bales, and make an extra trip. There's so many folks that make/sell hay here it wouldn't be much to make an extra run.
    rdust, Camber, huskihl and 1 other person like this.
  6. huskihl
    huskihl
    Pfft
    Lol. We're still hopeful his year is coming
  7. mdavlee
    mdavlee
    PJ seems to be the best bet.
    I've hauled 18 4x5 on a 14k lb trailer. Not wanting to make a habit of it so we got a 25k lb one now. Works better with the bigger tractors.
    rdust, Camber, concretegrazer and 2 others like this.
  8. VOLKEVIN
    VOLKEVIN
    I definitely need to go see one of these! It's a PJ trailer, 22' tilt bed deck over. The options available on these is substantial, but they have a 6" extra tall gooseneck height option with an adjustable ball height receiver. They also have a pretty cool option called Blackwood lumber, they cut out some of the deck board and inlay non-slip rubber. I would have to splurge on that feature! PJ is jumping to head of the line at the moment for me...
    Link: PJ Trailers | Deckover Tilt (T8)
    rdust likes this.
  9. mdavlee
    mdavlee
    I would check them out before you buy.
    rdust likes this.
  10. LinkedXJ
    LinkedXJ
    Indiana
    I wouldnt do it with your current set up, no way.
    rdust likes this.
  11. VOLKEVIN
    VOLKEVIN
    Can you go into some more detail?
    rdust likes this.
  12. LinkedXJ
    LinkedXJ
    Indiana
    Lift, tire size.
    Not ideal at all for towing large equipment trailers.
    Its your vehicle, you'll do what you want.
    rdust, VOLKEVIN and Camber like this.
  13. JustWood
    JustWood Guest
    Yep. Height makes rolling a bigger possibility .
    If your dead set on the idea. Buy the best brake and controller options available especially if you're going to max the trailer gross out . Driving habits will need to change also. Like slowing to speed before a curve/corner and powering through instead of braking through .
    rdust, VOLKEVIN, Camber and 1 other person like this.
  14. CDF_USAF
    CDF_USAF
    Dover DE
    I have a PJ car hauler, it has served me well, tows great, no complaints. The paint is starting to flake off on the underside now, but most of my towing has been in the winter and I wouldn't really say that it gets alot of love when it's put up after each use. I did have an electrical issue when I bought it, they said it was truck side on the lot, after an afternoon of me chasing wires and using another trailer to test truck side, the dealer came and picked it up and then returned it all fixed up.
    rdust likes this.
  15. XXL
    XXL
    Ontario, Canada
    rdust, concretegrazer and VOLKEVIN like this.
  16. VOLKEVIN
    VOLKEVIN
    I love that outside-the-box solution! It would solve the deck height disparity; but, I still have the clearance issue of the neck at the bed rails. On flat ground I'm good to go, but if I was to pull up into a gas station or feed store it would probably hit my bed rails.
    The other option of course, is a bumper pull trailer. I could retain stock trailer height since I have an adjustable 9 inch drop tow hitch.
    rdust and XXL like this.
  17. XXL
    XXL
    Ontario, Canada
    This is what my brother has done with his old Cummins 2500 and his new F350 towing his 32' enclosed car carrier. Air ride load leveling suspension is a nice option for this.
    rdust likes this.
  18. MasterMech
    Yes, but can it handle 15k of trailer? The whole rig is only as good as the weakest link.
    If you could do a suitable bumper pull option, I have done 10 bales on a beaver tail plus 4 on the truck (‘01 8.1L Chevy 1T w/rackbody). That worked fairly well and wasn’t awful to haul for reasonable trips.
    Your truck would probably thank you for a gooseneck config tho.
    VOLKEVIN and rdust like this.
  19. XXL
    XXL
    Ontario, Canada
    I'm not sure if I am following you. By raising the trailer similar to the truck, would it not ride and pull with similar bed rail clearances as a stock height truck and trailer?
  20. concretegrazer
    concretegrazer
    Southwest MO
    I would think the adjustable neck tube would get you there after the trailer lift.
    mdavlee, VOLKEVIN and rdust like this.
