Good Read. Hardwood vrs Softwood
Discussion in 'The Pellet Bag' started by Tullytown, Mar 7, 2015.
  1. Tullytown
    Tullytown
    North of Phila Eagles.
    An outside article for what it;s worth
    Hardwood vs Softwood
    Whether your wood pellets are made from hardwood sawdust or softwood sawdust will have absolutely no influence whatsoever regarding how those pellets will burn. Many people will argue that only hardwood pellets should be burned in their stove and conversely, some people will argue that softwood pellets are the only way to go. NEITHER OF THESE AGRUMENTS HOLDS WATER!
    You do not want to burn softwood in a WOOD STOVE (as opposed to a pellet stove) if you can avoid it. This is because in a wood stove, hardwood will burn hotter and longer than softwood will and softwood will burn much dirtier.
    Now, let me break this down in two parts. First, the only reason that hardwood burns hotter and longer in a wood stove is because hardwood, in its natural state, has a much higher density that softwood does. For instance, when you have two equal sized pieces of wood, and one is oak (hardwood) and the other is pine (softwood) you will get much more heat out of the oak than you will the pine. However, if you took a ten pound piece of oak and compared it to a ten pound piece of pine, the piece of oak is going to be much smaller than the pine. But, in ten pounds of oak, there is just as much energy (or heat) as there is in ten pounds of pine. This all comes down to density, and all wood, on a dry basis, will have equal amounts of energy (heat/BTUs) per pound.
    But, remember that with wood pellets, they all start out as sawdust. And regardless of whether the sawdust is hardwood, softwood or a mixture of the two, they will all get compressed to the same high density regardless of whether the sawdust is oak, pine, maple, fir, cherry or any other species of wood. This is an absolute fact and something that is often a source of confusion for many wood pellet burners. Therefore, there really is no such thing as a “hard” wood pellet or a “soft” wood pellet….there’s just wood pellets!
    This takes us to a statement that I made earlier here, that softwood, IN A WOODSTOVE, (in its natural state) will burn much dirtier than hardwood. This is true… but here is why. If you have ever seen a pine tree, you will see the sap, or pitch, oozing in spots where either the bark has been scraped or a branch has broken off. This pitch, when burned, will create a lot of creosote and the burn will be very dirty. But understand that this pitch only exists in the outer living layer of bark on a tree. Good, clean wood pellets, whether hardwood or softwood, will have no bark in them. A good clean softwood pellet will look nice and pure, almost blonde in color. There should be no bark in them and therefore, no pitch. Therefore, unlike firewood in a woodstove, softwood pellets will have the same high density as hardwood pellets and will burn just as clean as hardwood pellets if the bark is removed.
    That’s not to say that all softwood pellets are great, nor are all hardwood pellets great. Truth is, there are some great hardwood pellets out there and there are some lousy hardwood pellets out there as well. And at the same time, there are some great softwood pellets out there and there are some lousy softwood pellets out there as well. What I am really trying to emphasize here is that whether a wood pellet is made of hardwood sawdust or softwood sawdust will have no bearing or influence over the quality of that specific wood pellet. What really matters is how clean the raw materials are that make up that pellet and how low the moisture content is- that’s this big difference!
    jtakeman, Gasifier and wildwest like this.
  2. tuneighty
    tuneighty
    South Central PA
    I love burning softwoods IN MY WOODSTOVE, and I don't think they burn "dirtier", as long as its dried properly. Were coming up on prime softwood season for us WOODSTOVE burners. Article makes sense as it relates to pellets, but his info on WOODSTOVES is very innacurate.
    higgy, whitey, will711 and 5 others like this.
  3. Lousyweather
    Lousyweather
    somehow a WOODSTOVE guy found his way over here into the pellet forums! Everyone knows you only burn hardwood pellets! :popcorn:
    wildwest and tuneighty like this.
  4. Tullytown
    Tullytown
    yep.. no one here is going to bother to debate hardwood vrs softwood for wood stoves.
    He should copy/paste it and Un-leash it on the wood burner peeps forum.
    wildwest likes this.
  5. wildwest
    Do other trees have less sap and pitch than pine? Sincere question, not a statement lol.
    jtakeman likes this.
  6. Gasifier
    I have burned mixed blend pellets and softwood pellets in my pellet stove. Some have been good burning, and some have been not so good. Some of this winter the softwood pellets have been burning crappy. Now they are burning great. Same exact brand. An obvious quality control problem from one batch to the next.? That is the way it looks.
    As far as cordwood goes. I have burned hardwood and softwood in my wood stove and now my Gasification boiler, and it all burns great when it is properly dried.:fire:
  7. Tullytown
    Tullytown
    Don't think so.... not here in the East anyways..
  8. jtakeman
    "less" sap? Oh yes. Most hardwoods have little to no sap at all. Some of the softer hardwoods(sugar maple) have some amount if cut during sapping season(early spring when the snow starts to melt). Its how we get maple syrup. Sapping season is just about on us and the buckets will be put out very soon.
    Burning improperly seasoned softwood will load up the flue faster than improperly seasoned hardwood. As the sap is steamed off it just sticks to the flu liner. Seeing this(improperly seasoned) is what is often burned(not many actually season anything properly IMHO) it certainly has been a main cause to why softwood has gotten a bad wrap here in New England. Clogged flues and chimney fires is what the common New England burner thinks of softwoods in the wood eater.
    Properly seasoned softwood is burnable. I would burn some in the shoulder's, But because softwood is far less dense in natural form, You just don't get the burn times out of softwood compared to hardwood.
    Everything is changed with the pelletizing process. Compression is the equalizer, So softwoods get just as dense as the hardwoods. Then they actually gain an advantage because most softwoods actually contain less ash in the fiber than most hardwoods.
    Bucks Pellets and wildwest like this.
  9. subsailor
    subsailor
    Winthrop, Maine
    I fixed it for ya Jay.
    wildwest, tuneighty and jtakeman like this.
  10. jtakeman
    Thanks sub, I'll blame it on the amount of beer consumed. "hick" Burp! :drunk:
    I owe ya a :cheers: or 2 ! ;)
    IHATEPROPANE, wildwest and subsailor like this.
  11. Tullytown
    Tullytown
    oops,, thought he said MORE SAP.. my bad...
    IHATEPROPANE, jtakeman and wildwest like this.
  12. wildwest
    I should have worded the question differently. lol
    IHATEPROPANE likes this.
  13. Tullytown
    Tullytown
    No.. you were fine..
    I was asleep at the wheel...
    IHATEPROPANE and wildwest like this.
  14. golf66
    golf66
    Groan.....ugh....uhhhh.......errrrrrrrrrrrrrrrrrhhhhhhhhhhhh.......faaaaaaaaaaaaaaaaaaaaart......plop.........Ahhh
  15. Tullytown
    Tullytown
    Sounds of a classy guy.:rofl: :lol:
  16. golf66
    golf66
    Thanks, I try...:D:p:thumbs:
    wildwest and Tullytown like this.
