Good haul this weekend !
Discussion in 'The Wood Pile' started by Mykidsdadd, Dec 17, 2017.
  1. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Was sure hoping to get it all split and stacked but did get a good jump on it.
    321C784A-F9E0-423A-BAAB-B2B59F63C5B5.jpeg 717A8D29-65C2-4697-B8FB-C7D54DED956A.jpeg 4777AB27-2706-47D3-990A-9250719D70D2.jpeg 0266AFED-A725-49DF-BD4E-406F0DD646FC.jpeg 1AE43849-AEC1-4FAC-BF9B-DF63B2E94F03.jpeg
  2. Locust Post
  3. Pallet Pete
    Pallet Pete Moderator
    Ovid
  4. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Thanks. Juts can’t hang the bigger ones up, you can run into them if you don’t pay attention.
  5. GrJfer
    GrJfer
    The Woods of Arkansas
    Nice load on the silverado. Putting it to work earning its keep.
  6. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Nice. Be careful of the back window in your pickup. . A friend made me a couple wall mount saw hangers. They are Great. Finally my saws are put up where they don't get kicked , stepped on or stuff piled on them.
    Nice looking stacks.
  7. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Yep ! I definitely make her earn it.
  8. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    I don’t have far to haul it and all backroads, but yes I am still mindful of the back window. I do get a little out of hand sometimes tho. Thanks for the reminder!
  9. Horkn
    Yes nice work!
    You can put a ratchet strap across the top of the first row to secure the stack down so they don't migrate to the rear window. I'm sure there's tie down points at the front of the bed corners.
  10. HDRock
    Nice load of :woodsign:man  :saw::tree:whatcha got there some Maple or sompin? :)
    By the way welcome to da club
  11. Cold Trigger Finger
    Cold Trigger Finger
    A cheap and effective window protector. Is a piece of 3/4 plywood with a rectangular hole cut in it about 10" high by 20" wide with a piece of expanded metal/ 3/4" diamonds/ concrete floor reinforcing. Cut a couple inches over size and stapled or screwed on to cover the hole . But it will give visibility And prevent and wood from flying up and breaking the window. It can be laid down in the bed when the truck is empty and stood up in place when loading starts. The first stack of wood will hold it in place.
    Having broken about 6 back windows out of pickups. I promise it is about 100 times easier to do and use and about the same times less expensive than having a rear window replaced. ;-)
    A piece of screen from a rock crushers or shaker plant works equally as well. Maybe better.
  12. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Thanks for the welcome !
    Mostly pecan , oak , hickory and one lone elm this weekend.
  13. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Good ideas. Thanks!
  14. bde269
    bde269
    eastern south dakota
    nice score
  15. Backwoods Savage
    I notice several different lengths of logs in that load. Is there a reason for that?
  16. Mag Craft
    Mag Craft
    South East Wyoming
    Pecan, Oak , and Hickory. Sounds like some good smoking wood.
  17. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    There is a reason, not a good one but a reason nonetheless. My dad was cutting with me and he cuts them pretty short. I prefer 22-24 , saw some 14-16 this weekend. I don’t really care honestly as they all burn! I usually throw theb14” pieces in a pile and take them to my neighbor, he has a small stove and loves the short ones. Keen eye by the way !
  18. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Indeed !! I do smoke quite a bit but it is all firewood first and I juts pick what I want when I am cooking.
