Good description of secondary burn?
Discussion in 'Modern EPA Stoves and Fireplaces' started by wildwest, Nov 20, 2014.
  1. wildwest
    That's what I thought it should look like! Thanks
    fox9988 and HDRock like this.
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    In order to achieve secondary combustion, you must close the primary down more, so that the secondary inlet gets more attention.
    But having a hot fire, good coal bed, good wood, and good technique are all required.
    splitoak, papadave, HDRock and 2 others like this.
  3. MightyWhitey
    MightyWhitey
    Better not keep talking "dirty" like that or you'll get "moderated"!!!:whistle::rofl: :lol:
  4. HDRock
    What's your stove top temp when your pipe is at 850
    wildwest likes this.
  5. DexterDay
    Northeast Oh
    Much cooler.. But I have a convection deck and the blower always on High.
    I push this beast pretty hard to keep the basement about 80°. This keeps the floors warm throughout.
    wildwest and HDRock like this.
  6. HDRock
    I see :) I can run mine hard to with blower on high
    DexterDay and wildwest like this.
  7. wildwest
    Last night I laid on the floor after I lit the fire, I could not see the front tube but if I put my head on the floor I could see the back two. I finally saw secondary burns. Some were on the left, some on the right, some on this tube and others from a different tube. My guess is that the other times I have studied them the fire was already in full swing, so no off gassing.
    Thanks everybody!
    fox9988 likes this.
  8. Freakingstang
    Freakingstang
    WOW I thought mine was hot at 650... I have two magnetic temp gauges, being that mine is an insert I can only read the flue right at the stove outlet and on the face of the soave, right by the door. For a normal hot burn is 600-650 and if I'm really trying to crank it, it hits 675-700. Stove face temp is normally 300ish at 600 outlet temps, 350 at 650-675.
    After having wood smoke dragons my whole life, anything over 500 on the black pipe would make it glow, so when i lit it the first time following the manual and online advice and temps, i freaked out. Dad was over when I lit it and he thought the liner was going to melt when it got to 600. i've never told him with a load of good dry oak or hedge really cranking it hits 675-700. it had me very uneasy leaving the house the first couple times just because it was so much hotter than every other stove I've ever had or used.
  9. oldspark
    oldspark
    NW Iowa
    Reading the flue temp that close to the stove will be a little misleading, if you have ever read the flue with an IR tester the temps drop off quickly as you go up the pipe.
    Freakingstang and HDRock like this.
  10. HDRock
    Dexter's 850 reading is with a probe thermometer, measuring the temp on the inside of the pipe above the stove, not on the surface so that's a big difference
    DexterDay likes this.
  11. Free BTUs
    Free BTUs
    The drier the wood the better, because it will burn hotter which will allow more off-gassing from the wood. One thing I have noticed is that I get secondaries way easier from hard wood vs. soft wood. If I throw in a load of pine the wood just seems to take off in a hurry and it is the wood that is burning instead of the gases. If I load with oak then I get a much better and very visual secondary burn - gas flames coming out of all the holes on the tubes.
    splitoak and wildwest like this.
  12. Freakingstang
    Freakingstang
    Yes I have, one foot up it drops almost 100 degrees. I can't measure any higher up due to the insert..
  13. NW Walker
    NW Walker
    Olympic Peninsula
    I thought you guys might enjoy this view of secondaries in my stove. It's a bit different, but still has that "secondary" look of gasses burning separate from the fuel.
    Gark, concretegrazer, milleo and 2 others like this.
  14. Woodporn
    Woodporn
    S. MA
    that's darn cool!
    what stove is that/?
    NW Walker and wildwest like this.
  15. NW Walker
    NW Walker
    Olympic Peninsula
    Thank you, it's a home made thingy. It's a work in progress, that clip is me playing with secondary air configurations. I thought it looked cool, so I shot it, and it turns out it does a good job of illustrating the concept of burning the gasses separate from the wood. I hope it's helpful.
    concretegrazer and milleo like this.
  16. mike holton
    mike holton
    Old Dominion
    from the initial post above.
    one thing with non-cats is to make sure you leave room in the top of the firebox to allow secondaries. if its loaded all the way to the tubes or close to that the secondary air gets diffues around the wood , doesnt generally give good secondaries.
    try a load no higher than the top of the bricks see if secondaries improve with some space up there to burn freely
  17. weatherguy
    weatherguy
    central massachusetts
    Seems when I load all I can fit through the door on the PH it still leaves a few inches for secondaries, looks like I could easily fit another split or two if I played around with it but I've been leaving it as is and getting beautiful secondaries. I assume they did that on purpose. I loaded at 1 and I'm still getting nice secondaries at 5.
  18. fox9988
    fox9988
    NW Arkansas 72717
    Seconaries can look much different. Even in the same stove. One of my favorite's from the Woodstock Keystone. Volume down;)
    weatherguy, wildwest and HDRock like this.
  19. weatherguy
    weatherguy
    They can look different in the same load. I've had the rollers and jets and once the load was burned down I get some like the keystone video.
  20. wildwest
    Thanks Mike! You just solved my mystery. I have been doing the fires recently (husband= traveling, then flu=me building the fires lol), I don't have it in me to cram as many splits in at a time like my husband does. With his fires, the firebox is so full the flames lick at the baffle. My fires are smaller (apparently below the fire brick) , I finally saw the secondary burn! I am not concerned about aesthetics of the secondary burn but obviously curious about them.
    I am concerned with the frequency of stoking. I fear this model is too small for our needs. We need to stoke it every few hours. We are likely in different situation than a lot of burners, no furnace and a cold windy climate, no hard feelings.
    Any suggestions greatly appreciated :)
    fox9988 likes this.
