Good deal!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Well Seasoned, Nov 5, 2016.
  1. milleo
    milleo
    Maine
    Nice...Need a doggy bed on each side for Maple and Saucy...:thumbs:
    colin.p, papadave, Horkn and 4 others like this.
  2. Well Seasoned
    Chimney up.......
    Stove pipe on, things cleaned up, fresh paint....... (wanted a better picture, the sun was reflecting everywhere)
    papadave, Horkn, clemsonfor and 14 others like this.
  3. Well Seasoned
    Agree! Hardwood floor not so good for puppy bones......:)
    Horkn, clemsonfor, unclefess and 2 others like this.
  4. will711
    will711
    Pocono Mts.
    Time for a cold one and admire that Great work :cheers:
  5. Well Seasoned
    Oh yea, one coming up! Dawn is happy, so I'm happy! :thumbs:
    papadave, DexterDay, Horkn and 13 others like this.
  6. Well Seasoned
    And we have liftoff!
    papadave, DexterDay, Horkn and 14 others like this.
  7. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    That's a really nice, clean install. I like the color of the pad much better. You must be really happy to have it installed now. What is that, four heat sources now?
    :coldfire:
    Ya done good. Way to get it done.
    papadave, Horkn, clemsonfor and 8 others like this.
  8. Well Seasoned
    Thanks, I'm really stoked right now! :yes:
    Super cedar & kindlin with a couple splits, primary air wide open.... bypass damper open, learning the flu temps while having a coal bed then closing the bypass will be a learning curve, plus knowing what setting the primary should be at. Will probably takes awhile to fine tune, but once I'm dialed in, supposed to give 17 hours of steady heat, which is a long shot, but we'll see! Glad is a little warm out, 43°F so i can leave a window open to burn of this paint I did.
    :coldfire:
    papadave, Horkn, clemsonfor and 7 others like this.
  9. fishingpol
    fishingpol
    Are you getting cool temps up there this week? I'm curious what you will get for temps and duration.
  10. Well Seasoned
    We will be in the upper 40's for a high all week. We've had bitter cold already alot, been snowing off and on for 3 weeks. It could be sunny and warm, and soon after, blizzard conditions, like this past Friday.
    I think this stove compared to the castine, I'll get longer burn times. The fire seems to be a faint ghost like fire now, mostly coming from the bottom rear combustion package, but also getting the ghost like flames coming up to the glass. Pretty cool so far......
  11. fishingpol
    fishingpol
    Thats good that you can put it through its paces before winter really hits.
    I saw a Harman Oakwood on CL down this way. I belive it is the big brother of yours?
  12. Well Seasoned
    Yea, it's quite a bit bigger, solid stove. The cooking grille looks cool, just sits inside the top load door.
  13. gregbesia
    gregbesia
    CT
    That is a great looking install. Cant wait for your review of the stove. Maybe a video?:popcorn:
  14. Well Seasoned
    thanks! Once my skills are fine tuned, I'll post a video. Might take a little while to learn this thing. Currently, have a small ghost like fire going, but a little smoke coming from chimney. So I'm not there just yet :emb:
  15. Well Seasoned
    Oops, forgot to answer your question......
    3 heat sources..... oil/kero, pellet, wood. Maple lets off some heat too....:thumbs:
  16. HDRock
    Way to go man,Real Nice job ,gettin er done :thumbs::salute: and ya got er choochin too :campfire:
    Can't beat , good old :woodsign: fire n heat :fire:
  17. Well Seasoned
    The first load was small, a test load. Burned it down to nearly all coals and got it right this time........ loaded bigger splits on a coal bed- bypass damper open, primary open, within ten minutes, flu temps right, closed bypass, no smoke from chimney and just a glow with some ghost like flames here and there. Everything happens in the bottom rear, I think I'll get decent burn times from this thing!
    Edit......
    I'm seeing bigger puffs of flames, which when ignited, kinda shaking the stove pipe a bit....... This normal? No ash exploding anywhere through the stove like a you tube video ive seen.
  18. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Open one of those windows, see if you might need the extra air.
  19. Well Seasoned
    I have one open...... didn't hook up the oak, it's a 4.5" inlet! Was going to test out awhile, then decide. I do have insulated oak pipe.
    Horkn and Beetle-Kill like this.
  20. savemoney
    You were very lucky to jump on getting that stove and getting it installed so quickly. I've seen Novembers where the snow started the first of Nov. and didn't leave until spring. Would be a lot harder to do with ice on the roof. Good job well done.
