Giz/Emma and everyones pets on the board
Discussion in 'Everything Else (off topic)' started by Loon, Mar 25, 2014.
  1. Well Seasoned
    Looking for little red riding hood?
    Chvymn99, mat60, wildwest and 5 others like this.
  2. wildwest
    Can anybody offer advice on shearing dogs? (we did the llamas once or twice but it was huge crazy thing like 2 hp engine (J/K), but seriously, like 8 lbs, and the goal was to to get the long mats off for summer, regardless of the hackjob outcome:emb:. Atleast they were more comfortable.
    I'm doing what I can with the pet grooming shears on the pup again, have not figured out the basic stuff like using the length comb attachments, running it along her at an angle with just a couple woopsies here and there (and everywhere lol). The one grooming she has had was not what I expected, much longer cut than I was hoping for, she looks like a homeless hippie dog. I'd like to see a 6 month old little growing dog body, not flopsy mopsy hippie dog. The hair above her eyes is long enough as of today a very short but cute ponytail so she can see without looking through fur and, yes, looks a d o r a b l e.
    I've been doing her nails like I do Blondie and Blackie and the Cocoa cat, but have not pulled ear hair since, um, 1989. I bought the gripping powder from amazon and its here, not sure why I'm a bit squeemish about doing it?
    brenndatomu, Chvymn99, mat60 and 5 others like this.
  3. bogieb
    What blade you got under that comb? If it is a high number, then you will just have to work with the comb and do the best you can (this time of year anyway). If it is a a #3 all the way up to #8, I would do it with the blade only along the body, then put the comb on for the legs (if you can - if there are matts, forget it). That should get it short, but not too short. If using a blade, don't try to angle it, just run it so the back of the blade glides along the skin. Use firm, but not hard pressure.
    Combs are really tough to work with, but you probably don't want to try to scissor the legs, so go with the comb. Don't try to follow the contour of the legs - go for more of a straight glide from the hip/shoulder straight down to the paw. Yes, it will be longer but less whoopsies and will look better as a puppy-type cut.
    Don't even want to try to tell you about how to get the hair out of her eyes because that really should be done by someone with confidence and practice.
    The ears are nothing - just put the powder in both ears, rub it into the ears (like you are giving her ear noogies) for 10-20 seconds to let it spread and dry out everything. Then grab a little and pluck. Just do a couple hairs at a time (more than a couple, less than a good pinch full). Give it a quick yank and you should be fine.
    Why yes, I was a dog groomer in the early 80's thru the 90's.
    brenndatomu, Chvymn99, Chaz and 6 others like this.
  4. Midwinter
  5. Stinny
    Chvymn99, yooperdave, Chaz and 3 others like this.
  6. wildwest
    BB THANKS!! I'm grateful for your input.
    Belly hair for surgery prep on mutts is a totally different ball game than this furry poodle puppy named Peaches. TONS of fine hair. Here is the cheapie I bought on sale last Christmas , I cannot find any identification on the blade except "MSQ" , but there is a rotating collar that adjusts the vibrating teeth out/retracts the teeth. it reads 0.8 through 2.0. I have to say the cordless aspect is pretty cool though. I was looking at comments on the same clipper in a different brand and found this picture, this what Peaches looks like at the moment.
    brenndatomu, Chvymn99, Loon and 7 others like this.
  7. Midwinter
  8. bogieb
    Put the blade on the 2.0 - that will give you the longest hair without using the comb. That is perfect for the body.
    If she has fine hair, the comb may not work well at all because fine hair tends to tangle even as you are working with it (Bishon's hair is much harder to work with and get good results than a long haired cocker spaniel for example).
    The before/after pictures crack me up because they fail to tell you that dog has been thoroughly combed, bathed, and blown dry (to get the hair straight). Dog hair dryers are much more forceful than people dryers. They are used to literally blow the water off the hair and the force also straightens the hair. Slow, warm drying will allow the hair to curl and get wavy. But using a forceful dryer also means that you have to have the nozzle in constant motion so you don't hurt the dog (it can actually cut the skin). Groomers get wicked strong forearms and wrists from using the dryer.
    They also fail to tell you that if they used the clipper with comb attachment to do the face (I have my doubts), that was definitely an experienced groomer with lots of clipper practice and she/he used the steel comb to get the hair to stand up from the skin while using the clipper. Usually, groomers use scissors around the face for shaping and really fine clippers around the eyes. But, using scissors, for the average person is probably not the best because you can definitely do damage if you lose control of the dog or scissors. Use the comb to pull sections of hair up and run the clippers along the comb. If you've ever paid even slight attention to the way a hair dresser cuts sections, just a little at a time, that would be the general idea.
    Just an FYI, if you didn't already know, if you run the clippers with the grain of the hair, you will leave more hair. If you clipper against the grain, it will be shorter and a smoother cut. But, this time of year, you probably want to go with the hair to leave her enough weather protection. And, if it leaves too much, then do it against the grain. Much easier to take more hair off than try to put it back on :salute:
  9. Thor
    Thor
    Genoa City,Wi
    Floyd is hard at work. :picard:
  10. rottiman
    So is Dixie................................talk about a dog's life !!!!!!
  11. bogieb
    I came I from refreshing my coffee this morning to see bookends on my desk
    Both of them looking in same direction - what could have grabbed their attention?
    Oh look, it's Spot, who had been winding herself around my feet while I was refreshing my coffee. Had to take several pictures before I caught one that wasn't a blur from her moving around.
  12. Well Seasoned
  13. Chazsbetterhalf
    Chazsbetterhalf
    Looks nice and comfortably. If i had that sun light, i would be there with him.
  14. wildwest
    :picard: Peaches poodle and Cocoa cat were having a blast with some sort of tag game, Peaches spun around like a crazy happy puppy and her backwards rear leg joint cracked against the side of my foot. Yes, it hurt, that said, I'm so used other joints hurting much worse than normal when bumped, so did not pay much attention. Gosh Darn, can barely put weight on my heel tonight a couple hours later.
  15. Loon
    Loon
    North of the border
    Took The Dew a few minutes but he did get himself dug in on the couch for the night. :coldone:
  16. Thor
    Thor
    Genoa City,Wi
    :drunk: Floyd and I are a little thick in the waist. We sleep on top of the covers.:emb:
  17. Loon
    Loon
    North of the border
    With the size of Floyd I'm surprised he can even fit on a couch.:hair: :coldone:
  18. Well Seasoned
    Careful, could get mixed in with the laundry!
    :eek:
  19. wildwest
    I can't wait for it to warm up and dry out to pooperscoop! The piles multiplied under the snow:rofl: :lol:. We fenced about 1/8th acre but they prefer the 20 x 20' patch of sod we laid:rolleyes:. The foot thing was gone by day 3. Thanks again @bogie, I've worked on her 3 times for a couple minutes each (the easy part, torso). Thrilled she's relaxed with the clippers, just wiggly and gets bored holding still. Starting to look like the lanky adolescent she is and less like a hippie. We'll get her back to the groomer eventually to get her muzzle/around eyes, and feet down to the skin.
  20. bogieb
    Yeah, young one's are just like human kids - can't sit still for too long :)
