Git'ter done down in Dixie
Discussion in 'The Wood Pile' started by T.Jeff Veal, Dec 29, 2018.
  1. T.Jeff Veal
    No sir, different guy, different tractor, other guy has a Massey Ferguson, this friend has 2 John Deere. I've gotten trees from him several times. He usually pays me in BBQ and Stew...:stirpot::drool::drool:
  2. bigfrank
    bigfrank
    NorCal
    Do you haul it in your dump trailer, or do you have a flat bed? I have both, but my dump would be too small for my tractor I think. I need to get a set of forks for my tractor.
  3. T.Jeff Veal
    We have both types. Like this morning, loaded tractor on dump trailer to get the wood, took flat bed to bring it back home. Tractor and dump trailer is a bit heavy, but manageable. How big is your tractor and dump trailer. Our dump is a 7x12, it would haul tractor fine, but can't shut the doors with the counterweight on...just use a bungee cord to hold them shut.
  4. T.Jeff Veal
    This was today with dump trailer getting almost full. IMG_20190604_120649015.jpg IMG_20190604_120716718_HDR.jpg Bed bolts seem tight, will have to check it out.
  5. bigfrank
    bigfrank
    NorCal
    My dump is also 7x12, but not sure about loading it on the dump. Would make my arse pucker! Would have to make multiple trips anyway I guess. Much easier to load it on the car trailer.
  6. bigfrank
    bigfrank
    NorCal
    I have lots of truck to pull whatever I need. 2003 F250 with 7.3L, and my wifes truck, a 1997 F250 with 7.3L wither will haul anything I currently own loaded.
    I almost got a 14' dump trailer, but knew I would want to load the tractor on it and decided that may not be for me. My dump trailer will hold it as it only weight about 3300lbs and the trailer is 10k GVRW.
  7. T.Jeff Veal
    Finished up at the Hancock County honey hole yesterday. Got 2 dead hickories and a red oak, and a couple pieces of white oak. IMG_20190604_130700542.jpg IMG_20190604_135653793.jpg
    Got 43' of logs off the dead oak. It was on the steep hill with the rocks. IMG_20190605_063005.jpg
  8. Midwinter
    OK, you're making me want to scrounge some more oak!
    Chaz and Chazsbetterhalf like this.
  9. T.Jeff Veal
    Made mine do the same the first time...lol...learned to make sure it was in 4 wheel drive, and go slow...and the ramps are lined up straight...
    Chaz, Chazsbetterhalf and Midwinter like this.
  10. T.Jeff Veal
    OAK, OAK, OAK... HICKORY....OAK, OAK, OAK....Maybe you can find some on the way to/from the GTG this weekend.
  11. Midwinter
    Loaded car going up, driving back in the dark. Plus those northern folk don't leave wood lying by the side of the road!
    Chaz, T.Jeff Veal and Chazsbetterhalf like this.
  12. buZZsaw BRAD
  13. T.Jeff Veal
    We wound up hauling 7 dump trailer loads from there, mostly red and white oak, with some hickory on the last load. Never can tell when another honey hole will show up. Sometimes it's just 1 or 2 trees. Do have another couple trees to look at in the same area we we're Monday.
  14. T.Jeff Veal
    We took advantage of a really cool June day, low 70's and misty this morning. Put a pile of oak and hickory logs on the cutting sled and got them bucked up. IMG_20190612_113445864.jpg
    The standing dead red oak, made some pretty wood. IMG_20190612_140804063_HDR.jpg
    2nd pile to finish processing. These were to big to pick up whole. IMG_20190612_161619072.jpg IMG_20190612_161633373.jpg
    Starting on the last row in the big shed now.
  15. Midwinter
    I can smell that wood from here!
    Chazsbetterhalf, Chaz and T.Jeff Veal like this.
  16. T.Jeff Veal
    Luckily, we didn't have any stinky oak yesterday.
    Chazsbetterhalf, Chaz and Midwinter like this.
  17. jrider
    jrider
    Just curious why you don't cut those logs while they are on the forks? No bending over.
  18. buZZsaw BRAD
    looking good T.Jeff Veal :thumbs: Dontcha love how easy that oak splits? Give me red oak any day! When that big shed is full are you done? Cool day here, id like to go cutting but it is raining. I dont blame you for taking advantage of it after seeing the heat youve been working in.:dennis:
  19. T.Jeff Veal
    No sir, won't be done. We still have 4 full cord racks to fill, plus we have pallets and metal roof panels to build several more. We've got to much wood going bad to stop...:tree::axe::stacker::woodsign:
  20. T.Jeff Veal
    Guess never thought about it. If we had a narrow bucket and thumb to securely hold the log, might be good. I would probably hit the bucket or fork with the saw...lol...I'm used to running a 25" bar, so I can reach the ground without bending too much. I might give it a try though. I will probably wind up with a piece in the middle the will fall and need cutting.
