Git'ter done down in Dixie
Discussion in 'The Wood Pile' started by T.Jeff Veal, Dec 29, 2018.
  1. buZZsaw BRAD
    Nice! Delivering a load of chunkies myself today.
    T.Jeff Veal and Chazsbetterhalf like this.
  2. T.Jeff Veal
    New customer came by the woodyard this morning. He got 1 row of 7-8 yr old oak from the shed at the woodshop, then finished up the load with some of the rounds of white oak on the splitter ramp. They were so happy with this wood, they want a trailer load of oak and hickory. I ran the splitter and he helped move the rounds and stacked on the truck. 0115221034_HDR.jpg
    Split them and tossed in the shed. Going to deliver our truck load Tues morning 0115221310.jpg
    Then got the tops on the ash totes and moved them next to the holly. Even made a top for the wire baskets of chunks... 0115221312.jpg
  3. buZZsaw BRAD
    Looks like a little FHC gnome village! Those IBC totes are the handiest things for nuggets
  4. T.Jeff Veal
    The totes worked great for splits, I like the metal bins next to them better for chunks and nuggets. Has door built in...
    I have 1 tote that the cage is bent in on the corner. I'm going to leave the bladder in, drill holes in the bottom and use it for chunks...
  5. Stephiedoll
    Stephiedoll
    Omaha, NE.
    We have over 100 of the totes now, or close to it but none came with the bladders.
    PatrickNY, M2theB, Erik B and 3 others like this.
  6. T.Jeff Veal
    Wow, that's alot.
    Chazsbetterhalf likes this.
  7. Stephiedoll
    Stephiedoll
    Omaha, NE.
    It is, but sad to say most are only filled with air.:headbang: Maybe a faster splitter will help.
  8. T.Jeff Veal
    It will definitely help. We have been busy since August with firewood, but our sheds are still empty. We spent the spring doing cooking/smoker wood, 48-84 hrs/wk at my job and then most of June remodeling the bathroom.
    Y'all will get it done...
  9. T.Jeff Veal
    Finished filling a tote with chunks form the cutoffs, carried it over to our cousin's house. 0127221046.jpg
    Oil looks good, going to mix it with the bar oil. It's 40W to 140W... 0127221149.jpg
    I wonder if Scotty Overkill or blacksmith have seen any like this in their RR shops...
    M2theB, SimonHS, Slocum and 9 others like this.
  10. blacksmith
    blacksmith
    central Pa
    Yeah we have lots of those Jeff. They don't allow scrap passes anymore for that stuff because a person or two took advantage of it. Some ruin it for all.
  11. Stephiedoll
    Stephiedoll
    Omaha, NE.
    I agree that it stinks that a few have to ruin a good thing. See it often around here.
  12. T.Jeff Veal
    We got all the oil from the totes drained into 1. Don't know how many gallons it might be. 0207221115_HDR.jpg
    Then got 2 more totes ready for use. Figured out how to make a door with the cut out. Conduit couplings. We had some splits fall out one of the first ones we did
    Eric VW
    The other tote is set up for chunks. Drilled holes in the bottom of the tank, then used 3" hole saw to cut holes in sides. 0207221901_HDR.jpg
    This top is on the oil tank, water would hold in the plug, so covered it with a piece of metal 0207221137.jpg
    My cousin, who we gave the cutoffs and tote of chunks to, his wife works at the oil distributor, that is where we got the totes from. We happened to talk about bar oil, she said they had it in 5 gallon cases, had a lot of loggers buy a pallet at a time from them. They had gotten 24 pallets in at a good $$. She could sell me some for $35 a case...$7/gal.
    Already had the 3 gallons of Countyline brand...$12/gal. I think I have room for 2 more cases...
    She told me the next time they ordered, it would be more $$
    WinonaRail, Chvymn99, M2theB and 7 others like this.
  13. buZZsaw BRAD
    Nice improvisation on the tote Jeff! I like the doors. GREAT deal on the bar oil. I paid $12/gal for a couple recently.
  14. T.Jeff Veal
    Used a little hoarder resourcefulness to solve a couple problems.
    When I had to get 3/4" couplings to go over the square tubing, the screws weren't long enough. 0210220933.jpg
    Trip to the hardware store proved that the threads were some type of chinesium rigging...:headbang:...neither standard or metric size or thread..:loco: :crazy:..
    So, I drilled and installed a small sheet metal screw where the coupling screw would land...:yes: 0210220935.jpg
    Tightens up now:thumbs: 0210220937.jpg
    After making the chunk totes, I had the tops that were cut off. As I was headed to the dump with them, I drove by this bin we use for splitter scrap/kindling...it had been covered
    with a piece of tin that didn't fit too well...did a little :sherlock::sherlock:...
    Then fastened 2 of the tops on it...works great...:) 0210221332_HDR.jpg
  15. T.Jeff Veal
    During deer season, I found a big beech limb had fallen and a water oak fell close to 1 of the stands. 0205221003.jpg
    It had gotten really bad at the base of the trunk, the reason it fell. When it got this much punk in the center, I left it 0205221243_HDR.jpg
    In the process of getting this home, O found a small cherry that looked like it was dying and a big cherry that was no doubt standing dead. 0205221036_HDR.jpg
    Got a few green cherry splits from the small tree to put on the cooking pile... 0211221020a_HDR.jpg
  16. T.Jeff Veal
    Found out hindsight really is 20/20...
    We realized I should have divided it with a wall. Got it restacked on 1 side, 0212221231.jpg
    Going to use pallets for the wall, braced the 2 leaning stacks at the top, got one side ready for more hickory 0212221230.jpg
    WinonaRail, SimonHS, Chvymn99 and 5 others like this.
  17. T.Jeff Veal
    Had a new customer become a repeat customer, needed another truck load. We had 1 older oak log from a recent score left, got it split and loaded, then finished the load with the seasoned hickory we had moved to 1 side of the shed 0212221231.jpg 0215221305_HDR.jpg
    We then had time to add supports to the wall we are building. Going to add 2 more pallets high and then cut 2 down to fit up to the leaning stack 0215221812_HDR.jpg
  18. T.Jeff Veal
  19. T.Jeff Veal
    Went to the woodshed after work last night. Wanted to get something accomplished for the day. Had a short row to prop up and move the cribbing on the end. Got that done and was able to finish the divider wall. 0228222224.jpg
    I then started restacking some of the limb wood and a few splits against the new wall. 0228222238_HDR.jpg
  20. T.Jeff Veal
    Took a little vacation, so now it's time to get back to work on the woodyard.
    I heard the 'Bota whining in the tractor shed, so I let it out to enjoy some sun and work. Got 6 hickory logs out and bucked, 3 logs in the picture 0322220848.jpg
