Git'ter done down in Dixie
Discussion in 'The Wood Pile' started by T.Jeff Veal, Dec 29, 2018.
  1. T.Jeff Veal
    That makes about 1 1/2 cords of cooking wood sold this year.
  2. Midwinter
    That's a nice little sideline for you! Seems like you are tripping over pecan, would be a shame to use it for heat. There was a fellow on here in Florida that was cutting a dead orange grove for smoking wood, muzzy17is, never told us how it went.
  3. T.Jeff Veal
    That's right, haven't heard from him in awhile.
    Seems like pecan is showing up now. I'll keep it separate
    brenndatomu, Chaz, Midwinter and 2 others like this.
  4. FatBoy85
    FatBoy85
    Washington State
    Any chance you have apple out there? Might open up a bit of more market for you if you can find it.
  5. T.Jeff Veal
    No sir, pretty much too far south. Might see one in somebody's yard. There is some in North GA. But I hear they want $$$ for it
  6. FatBoy85
    FatBoy85
    Washington State
    I’m betting that if you did find it, you might be keeping a fair share yourself. Here it’s funny how it is pretty much found off and on and I’m often found using it too. But the tree to cut it gets to be a lot to process too. They get pretty big here sometimes
  7. T.Jeff Veal
    I need to cut a load of pecan and head north and swap some out...our pecans get big too. This one was 26" dia. I've seen some bigger too. IMG_20190714_083953.jpg
    brenndatomu, Chaz, OhioStihl and 5 others like this.
  8. FatBoy85
    FatBoy85
    Washington State
    If the trade fits! Smart idea, hope that’ll work. Mostly the apple tops go wide, it’s a gnarled bunch but makes the bbq an excellent fare. I’ve only burned pecan in some chips and chunks not much bigger than a small matchbox, but when you’re cutting your own bbq wood, some special kind of delight seeps in.
  9. B.Brown
    B.Brown
    USA
    As usual Jeff, you and the wife, do make the best looking wood i've ever seen, clean, neat, and split just right.
  10. thewoodlands
    thewoodlands
    Nice work T.Jeff Veal , how does that split?
  11. T.Jeff Veal
    Thank you sir. I think I'm getting a little off, need to calibrate my laser eye again...
    We just get lucky sometimes.
  12. T.Jeff Veal
    Not to bad with hydro. Can be a PITA by hand, gets a little twisty like hickory can.
    brenndatomu, Chaz and Midwinter like this.
  13. T.Jeff Veal
    Delivered 2 loads to a guy that got one load from us last year. He has a stove in his auto repair shop. He said our wood puts out the heat, still had a little left from last winter. He should be set for a cold winter now.
    First load is at least 3/4 hickory, rest red oak.
    Second load is red/white oak with a little hickory. IMG_20191008_120518390.jpg Made a small dent in the big shed. One row and a piece. IMG_20191008_120531875.jpg
  14. thewoodlands
    thewoodlands
    That looks like some nice firewood, are the temps still hot your way?
    Midwinter, brenndatomu, Chaz and 2 others like this.
  15. T.Jeff Veal
    Thanks, guess I'm getting to be a true hoarder, hated to see it leave, but grass cutting was slow this year and we have a cruise in Oct '20 to finish :emptywallet:...
    It is some of the best wood we have had in a few years.
    We must be having an artic blast... high was 85° today...lol...nice out today, still no rain, severe drought down here.
    Midwinter, brenndatomu, Chaz and 4 others like this.
  16. thewoodlands
    thewoodlands
    I hope you get your rain, we went through our dry period which lasted over a month if not longer.
    Midwinter, brenndatomu, Chaz and 3 others like this.
  17. T.Jeff Veal
    I have forgotten how long it's been, more than a month, I'm sure
  18. T.Jeff Veal
    Well, I had an idea on how to build a chunk, shorty and nugget bin with the plastic pallets I have. My good friend Chvymn99 reminded me to :ithappened:if I built it. So here goes...
    Found several cargo control ratchet straps in the trash bin at work, used grinder to cut clip off strap.
    Had to cut a few threads so loop would fit over 1/2" conduit. IMG_20191012_093832540_HDR.jpg
    Both ends of strap go on conduit, then drove it down even with top of pallet IMG_20191012_102136150.jpg then ratchet tight IMG_20191012_103007457.jpg Makes a pretty good bin. Had time to give some chunks a new home. A couple pieces of metal roofing on top, be completed. Should last awhile. IMG_20191012_103000229.jpg IMG_20191012_114702417.jpg
  19. Chvymn99
    Looks good and solid... :handshake:
  20. T.Jeff Veal
    Seems to be so far. Once I tightened the straps, didn't wiggle.
