Git'ter done down in Dixie
Discussion in 'The Wood Pile' started by T.Jeff Veal, Dec 29, 2018.
  1. T.Jeff Veal
    :handshake:
  2. T.Jeff Veal
    I'll check WCS and se if they have one.
  3. JD Guy
    JD Guy
    Upstate SC
    Is available from Stihl. IIRC it also fits the 362? If you want I can look up the PN It also comes with a bit different part for under the clutch cover to replace the one that’s there due to the difference in depth.
    Edit:
    The PN as follows:
    Clutch Cover 1138-648-0400 or 1122-640-1711
    Brake cover 1140-021-1100
    Chip Deflector 1138-656-1500
    Best to check with your (knowledgeable) Stihl dealer as I had to order the parts twice because my dealer is basically worthless :emb:
    eatonpcat, metalcuttr and T.Jeff Veal like this.
  4. buZZsaw BRAD
    I think mine is OEM, wasn't included with saw stock. Only thing I hate is no captive nuts on it and the full wrap handle on mine gets in the way when loosening them.
    Nothing worse than losing one of your nuts.:rofl: :lol:
  5. JD Guy
    JD Guy
    Upstate SC
    yes you’re right and I realized after I had sent the information to T Jeff that I forgot to mention that. It’s a non issue for me as this is the only saw I’ve ever had with captive “nuts”. I don’t miss the feature at all though. I’ve been running a saw for a fair number of years at 74 years old now and I’ve lost a whopping total of 1:whistle:
  6. buZZsaw BRAD
    I get used to having the captives on a few other of my saws. Same goes for the switch. On the newer mtronic ones it will automatically go back to start when turned off and all you need to do is pull the rope. My 361 doesn't do that and I sometimes forget when I'm using it. Ill pull the rope several times and it wont start. Ill be cursing up a storm at it until I realized its in the "off" position and feel like a dumb a$$ after! :emb:
    Thinking I've lost 2-3 in 40 years.
  7. JD Guy
    JD Guy
    Upstate SC
    buZZsaw BRAD Agee, It is a learning curve with the Mtronic. My 400 is the only one with it and rather than every move being more or less automatic from muscle memory I have to think about the start/stop procedure. I don’t really use this saw often. Only pull it out when felling or bucking bigger wood
  8. buZZsaw BRAD
    I read somewhere to let it return to idle before turning it off as it "remembers" what the carb was running at when shut off. Don't know if true or not but I try to do that when using one.
  9. JD Guy
    JD Guy
    Upstate SC
    I’ve adopted that process too, restarts are much better!
  10. Erik B
    Erik B
    Western Wisconsin
    My 362 is not Mtronic and the off switch is momentary and returns to run after shutting the saw off.
  11. buZZsaw BRAD
    Im pretty sure its like that on all Stihl pro model saws whether mtronic or not.
  12. T.Jeff Veal
    Making a little progress this week, since I'm working 6AM-6PM shift. Work a couple hours at a time. We haven't set up the lights yet...lol.
    We got the heartwood from the 4 logs on the previous post split into a tote... 20250715_200500.jpg The sapwood that was a little punky or knotty pieces went into the deer camp pile... 20250715_200508.jpg
    We had 3 bigger short logs and 1 longer log left from that trailer load, got those bucked and split enough to finish tote...
    About dark now, so we moved another trailer load of oak logs from mom's yard to the woodyard for processing 20250715_212228.jpg
  13. T.Jeff Veal
    Didn't get started on the woodyard till about 7:30 last night, worked by myself. Got the 10 rounds from post #2192 above split, sorted and stacked.
    Nearly all is nice heartwood, a few pieces with solid sapwood are included. 20250716_210221.jpg
    Sapwood pieces that felt light for their size went to deer camp pile.
  14. T.Jeff Veal
    We prepped a couple more totes...
    This one had a big hole in the cap and it was stuck on the threads...good candidate for another chunk tote... 20250805_125437.jpg
    This tote has the round tubing, it doesn't work well with the hinges and latches we make, so we just cut the opening and use it for deer camp firepit wood. Got it full and put in storage... 20250805_110353.jpg
  15. T.Jeff Veal
    Had 1 more tote already prepped, so got a few more logs out. 20250903_104346.jpg
    Should have the tote finished this morning.
  16. T.Jeff Veal
    We got that pile of rounds split and stacked, needed 1 more log to finish the tote.
    As we were splitting that wood, we had a round with a weird knot. Inside we found an old squirrel stash of acorns..
    It had completely grown over the limb.
    Our campfire pile has grown again too.
  17. T.Jeff Veal
  18. T.Jeff Veal
    No rats, mice or chipmunks around our yard...lol
  19. JimBear
    JimBear
    Well done, no soil flying or trenching done while cutting.
    I felt the need to go out & replace my chain just seeing those logs laying on the ground. I always throw some sod no matter how careful I think I am being.
  20. T.Jeff Veal
    Oh, I've done plenty of trenching...lol...
    There was a bit of saw chips under the logs. I was trying to be very careful, I had just ran that chain through the grinder before doing the video
