Git'ter done down in Dixie
Discussion in 'The Wood Pile' started by T.Jeff Veal, Dec 29, 2018.
  1. T.Jeff Veal
    We made it back to working on the woodyard yesterday morning. We had one more 330gal empty tote left, so we filled it with 18" red oak splits for the restaurant. 20250628_104428.jpg
  2. yooperdave
    That, sir, is one tightly packed tote! :handshake:
  3. buZZsaw BRAD
    X2. Rumor has it Jeff can get a half cord in a face cord sized tote. :stacker:
  4. T.Jeff Veal
    Thanks, my friends. I'll 'fess up...I stacked a little on the bottom that Miz Carol couldn't reach...the rest is her artwork...
    The new tractor and bigger loader got it off the ground enough to move it...barely.
  5. T.Jeff Veal
    After we finished that tote, we tried out something different...
    That will go to a deer camp for the firepit.
    jo191145, Ron T, RCBS and 11 others like this.
  6. JD Guy
    JD Guy
    Upstate SC
    I have been thinking about a spring planting also. Is your thinking that either keeps deer in your area and provides better grazing for does and fawns? Do you then do a fall planting too? I have considered that a spring planting when turned under would make a better soil structure and help the fall planting. Our food plots don’t really last very long in the fall with the numbers of deer on our place though.
  7. T.Jeff Veal
    Yes, better nutrition for all the deer, antler development on the bucks, healthy does and fawns. And yes, sometimes cover crops will enrich the soil.
  8. T.Jeff Veal
    Did some rearranging on one of the tote storage areas today. Mowed the grass close and had a couple old billboard canvases and 2 big tarps. Used the signs first, we set the 3 - 16" totes in a row, then moved the 14" totes in a row next. Going to add 4 more 14" totes in that row. Then we will start with 18" totes and use the other big tarp, once brown area is full. 20250630_123127.jpg
    We planted wildflowers in that area several years ago, they have re-seeded quite well. As I was moving a tote, I "picked" some brown eyed susans with the forks...
    Miz Carol is one lucky gal...:thumbs::whistle::cool:
    Boogeyman, jo191145, Ron T and 15 others like this.
  9. T.Jeff Veal
    At work, we have those self-dumping hoppers, so we modified our box. Added a front slope, now we can throw scraps in, chain it to the forks and dump it on the burn pile... 20250701_095559.jpg
    We also finished that deer camp tote to the left.
  10. T.Jeff Veal
  11. T.Jeff Veal
    Had 1 more long sweet gum log in that load of oak, made 11 18" rounds... 20250707_124135.jpg
    That and a couple small elm limbs filled up the deer camp tote, it's mostly hickory 20250707_154525.jpg
    That filled all the totes we had prepped, so time to get more ready.
    Miz Carol helped get some moved into place..
    We started on 4 Tuesday morning before we had to run some errands, we finished those Wednesday, then did 6 more...10 ready to go... 20250709_115742.jpg
    Boogeyman, ole, jo191145 and 15 others like this.
  12. buZZsaw BRAD
    SWEET GUM!!!???
    Cant believe you processed it!!! Thought you sold those to the mill/pulp plants?
    Hope Ms. Carol isn't a "lady driver" with the Kubota. :whistle: Are those new tires?
    Great team work there folks. :thumbs:
  13. T.Jeff Veal
    Didn't have enough/big enough to go to sawmill. Chipmill gig is up for now.
    Yep, new tires on the new tractor. We got it April 10th.
  14. T.Jeff Veal
    After some errands in town, we had time to buck 4 16' red oak logs into 18" splits. 2 of the logs... Messenger_creation_C1E889B5-FA38-411D-A9FB-E4AA71486444.jpeg
    Let the XS400 have some fun today Messenger_creation_90858DAE-BF3C-4A1F-975D-6EE3B08519E4.jpeg
    It had already started raining, with thunder nearby. Got enough for Blue Samson to start on in the morning
  15. T.Jeff Veal
    Yesterday morning we split and stacked the 4 logs from above post...sure turned out a lot of wood, around 1/2 cord...shade over 1 1/2 totes. 20250711_091429.jpg
    I've been thinking of a better way to make stops for the tractor forks, sometimes the clamps were hard for Miz Carol to get loose and I've had bigger logs roll over the 4x4 blocks.
    Using 3 sharp drill bits, worked our way up to 3/4", bought some 3/4 x 8 bolts and some flat washers. Had my shift mechanic weld 2 washers on each bolt. Now just drop 1 in each hole... 20250712_084913.jpg
    Finished 4 short logs from that trailer load, got another tote and a piece. 20250712_094948.jpg
    We then started on some older oak logs, cut Aug-Sept '24, before Helene. Messenger_creation_DBD76C8E-7A60-4306-95A9-448D66A6F68F.jpeg
    Roll to finish the cut... Messenger_creation_E7002410-68F6-4156-94C8-5525FF35137E.jpeg
  16. jrider
    jrider
    Why not cut them all on the forks?
  17. JD Guy
    JD Guy
    Upstate SC
    T.Jeff Veal Just wanted to suggest a modification to your MS400 that I did and while not a Huskil HP producer I found it beneficial. I put a large capacity clutch cover on and it really moves the chips through and seems to keep the inside of the clutch area cleaner. FWIW
  18. buZZsaw BRAD
    Mine has one too. The guy i bought it from customized it with one.
  19. eatonpcat
    Nice work TJ and Miz Carol!
  20. T.Jeff Veal
    Just moved these logs from a distance, these logs were only 6' long, 4 cuts, and on the bigger side. Kinda mixing things up.
