Giant Clinker?
Discussion in 'The Pellet Bag' started by wildwest, Dec 4, 2014.
  1. badbob
    badbob
    By the way I have gotten bad pellets before(euraka-local made) and cost me an auger motor and a bushing.Picked up 5 bags last year(heard the "came around")burned 1 and dumped the rest on the driveway,still junk,happens.
    wildwest likes this.
  2. imacman
    imacman
    Denver, NC
    P. 46, Figure 27 "Fresh air Damper" Remove right side panel of stove, damper adjustment is at bottom at rear. P. 8, Fig. 6
    "Make sure that the fresh air intake damper is always fully open when the stove
    is burning. "
  3. badbob
    badbob
    You found a different manual imac,send/post link?
  4. wildwest
    Clean burn pot every other day, I guess I need that regimine while we burn through the Rocky Mountains. Thank you for the insight! We don't have a king/kroger up here, boy do I miss that store! We had a Marketplace King Soopers in Ft Collins it was fantastic. Ever heard of South & Jones pellets?
  5. imacman
    imacman
    Denver, NC
  6. wildwest
    Thank you Thank you! I read the manual in Sept when we put the unit in, but honestly its was all new to me so couldn't actually apply a lot of the information in there. PS refresh my memory, what pellets are you burning?
  7. wildwest
    Thanks imac, I can't seem to find the diagrams either, but wow I appreciate that you take time out for a stranger across the country ! :handshake:
    Stinny likes this.
  8. imacman
    imacman
    Denver, NC
    Hey, that's what we're all here for, to help each other out. :campfire:
    PS Did you see my post #45 above?
    wildwest and eatonpcat like this.
  9. wildwest
  10. badbob
    badbob
    Ligs.
  11. Lousyweather
    Lousyweather
    I'm only correcting this for accuracy sake.....buuuut, depending on the version of the control board, you can vary the voltage fairly dramatically....somewhere in the neighborhood of 20 volts.....earlier boards were about 5 volts. DONT DO THIS WITHOUT TESTING DRAFT!
    As for the double paddle fan, most models actually have this, but a couple models only are available as single-sided paddle fans, such as the F/S Accentra. FWIW, the high altitude fan impeller isn't double sided at all, its got larger fins.
  12. jtakeman
    Draft? As in draft beer? Now you talking!
  13. imacman
    imacman
    Denver, NC
    Amazing......ANY thread can become a beer thread instantly! :thumbs: :drunk:
    wildwest and jtakeman like this.
  14. imacman
    imacman
    Denver, NC
    And just as amazing....I just happen to be enjoying an adult brew as we speak. Some smooth Mich Light in a retro Bubble Boys glass! Are the Rangers on tonight?
  15. smoke show
    smoke show
    Pittsfield, Wi
    nope, the Packers are! :D
    jtakeman and imacman like this.
  16. wildwest
    Thanks again Bob and RockyMtnHigh for all your advice! The RMP seem to have a lot more fines (hopefully using that term correctly, the saw dust that comes in the bag). My stove's auger does not like the the sawdust. Also, they do not feed as well as the Heartlands, both of us have poked the pot scraper tool into the hopper and have seen an avalanch of RMP pellets cave into the center (where my stove feeds). I have to wonder if that is because many of them are too long to feed properly.
  17. badbob
    badbob
    Interesting.Would you give me the hi-alt impeller part number for my stove?Thanks,Bob.
  18. badbob
    badbob
    That is possible,pellets come in all qualities and vary from batch to batch.A lot of stoves do not like fines.I have seen where purchasers(or the sellers) use lo bid for shipping,and the older truck/trailer rigs beat the pellets to death.I personally never like to see more than 1/4 cup of fines per bag,then I run it through my sifter,does not happen often.
  19. wildwest
    what do you use for a sifter?
  20. badbob
    badbob
    I'm cheap--2 plastic 5 gal buckets,one I drilled lots of holes in the bottom.Dump in a gallon,swish around,dump out and do again.Does get 90 %.Have used them(on and off)for years.
