Getting water from here to there?
Discussion in 'Everything Else (off topic)' started by Well Seasoned, May 27, 2018.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Ooo yea!!! I’m excited to see this!:dex:
  2. Pallet Pete
    Ovid
    Are you done yet?:rofl: :lol:
  3. Eric VW
    Eager much.....?:rofl: :lol:
  4. brenndatomu
    ...she said :p
  5. Pallet Pete
    Ovid
    What can I say I geek out on this type of stuff! :whistle:
  6. brenndatomu
  7. brenndatomu
    Now if you only had a siphon/or pump made from pallets...I would have geeked out on that! :D
  8. Well Seasoned
    Chvymn99, basod, Pallet Pete and 2 others like this.
  9. basod
    basod
    Mount Cheaha AL
    I use a siphon to pump my pool cover off all winter except I cheat with a sump pump to prime it. A 1.5" old pool vacuum hose will move a lot of water.
  10. Well Seasoned
    I measured the drop from the water lever to ground level and it's only about 4'. So I'm hoping there's enough pressure, we'll see.
    Pallet Pete likes this.
  11. brenndatomu
    4' drop is about 1.73 PSI, so it will flow, but that's about it...probably not going to work a sprinkler, or even a spray nozzle very well at all
  12. Woodwidow
    Would it increase the pressure if your siphon was a larger pipe than the hose you attach at the bottom end? You would have the weight of the water in the pipe trying to force its way out the narrow exit of the hose.
  13. Well Seasoned
    We'll give it a try. Dont want to run a chit ton of hose from the house, was hoping for ease. Well see in a bit here. Heading to Lowes hoping they have everything I need.
    Pallet Pete, basod and brenndatomu like this.
  14. Canadian border VT
    Would work soaker hoses overnite though
    Pallet Pete, Chaz, huskihl and 2 others like this.
  15. Well Seasoned
    I'm thinking maybe. Planning on larger pvc pipe transitioning to garden hose
    Pallet Pete and basod like this.
  16. Well Seasoned
    This is my hope. Maybe a drip line
    Pallet Pete, basod, Chaz and 2 others like this.
  17. Woodwidow
    I think soaker hoses work better as you are not spraying all that water into the air to evaporate.
  18. brenndatomu
    Water pressure doesn't change with the diameter of the water column, only the height. I know it seems like it would, but surprisingly not...
    bushpilot, Pallet Pete, basod and 5 others like this.
  19. Well Seasoned
    Would the elevation start at the water mark, 3ft down in the well or at the top of the concrete?
    Not sure if bringing up water 3ft first hinders pressure at all?? If I count the top of the concrete, then I have 7feet of gravity pressure?
  20. ironpony
    ironpony
    Mid Ohio
    yes, height affects head pressure not diameter. IMO for 200 bucks you would have a self-contained irrigation system, use soaker hose or drip irrigation lines.
