Getting conflicting info from local hearth shops
Discussion in 'Modern EPA Stoves and Fireplaces' started by mike bayerl, Feb 18, 2015.
  1. BDF
    BDF
    You can go with a hybrid and get the benifits of both all at once; a nice secondary burn with visible flames when you want, and a cat. burn that will go much, much slower which is great for long burns, especially in the shoulder season when you only need a little heat.
    There are a few hybrids out there, four that I know of. Two are Woodstock Soapstones, the Ideal Steel and the Progress Hybrid. Another one is the Regency F5100 which appears to be a nice stove although it is by far the biggest of all of them (and about the biggest woodstove made). And finally there is another brand that I cannot think of at the moment but I think it is a Travis industries stove- someone will chime in with the brand and name I am sure.
    Lots of us, including me, have the Ideal Steel and have been quite happy with it (first year in production). The price is also very competitive at under $2,000 for a hybrid or a pure cat. stove.
    Brian
  2. HDRock
    Never owned a cat stove , but don't like the idea of the maintenance required .
    I like the simplicity and fire show of a tube stove.
    With a tube stove you clean it up once a year , that's it.
    Ash drawers and every thing , just more possibilities for things to go wrong .
    Just my opinions :)
    The heat swings don't bother me at all.
    I have a hall similar to what you have , 3BR 1200 sq ft, you will definitely need some small fans on the floor to move the cold air towered the stove room , with a couple of small fans , temps at other end of my house are about 4 degrees cooler, with out them it was 8-10 degrees
    TurboDiesel and mike bayerl like this.
  3. unclefess
    unclefess Guest
    go for bigger ,it wont hurt i like my castine but every day i wish i got the oslo
    mike bayerl likes this.
  4. oldspark
    oldspark
    NW Iowa
    As many have stated that comment is just BS from a person who does not know how to run a stove.
  5. My IS heats my home
    My IS heats my home
    Albany, NH
    Did Woodstock come up with another steel hybrid after the Absolute was in production?
  6. Unhdsm
    Unhdsm
    Bradford, Vermont
    The Navajo coal hybrid but that's a pretty niche stove. I'm not even sure if it will be available to purchase directly.
  7. My IS heats my home
    My IS heats my home
    Albany, NH
    Coal burning from WS? hmmm... Is it something they produce? Wood fired too I suppose
  8. Unhdsm
    Unhdsm
    Bradford, Vermont
    Yes- it burns wood and coal. It was a special project sized and designed for Navajo out west to work with their homes and available resources. Since I have a background in public program policy I followed it as close as I could. Cool stuff.
    raybonz and My IS heats my home like this.
  9. My IS heats my home
    My IS heats my home
    Albany, NH
    I don't see it on their website. Is there anything (a photo or specs) floating around?
  10. Unhdsm
    Unhdsm
    Bradford, Vermont
    raybonz likes this.
  11. BDF
    BDF
    THAT is where the bottom draft we need on our Ideal Steel's went!
    OFFTOPIC: Most modern stoves will not, and it should not even be tried really, burn coal. Burning coal requires a grate and a draft from underneath to keep it going. And anthracite or 'hard' coal has a lot of gas in it that burns blue, exactly like natural gas or propane. But if one has a stove capable of burning the stuff and access to it at anything even approaching a reasonable price, it really is an interesting experience to burn coal. Very, very different from burning wood. In the end, I prefer burning wood as coal has too many quirks, is a bit more dangerous (the possibility of filling the stove / chimney with gas and then having it all ignite), generates a tremendous amount of ash compared to wood and is just dirty, nasty stuff to handle / store / fill the stove with. But it is interesting to do it for a while and go through the learning curve.
    Brian
    raybonz likes this.
  12. BDF
    BDF
    Not that I now of and actually, I forgot about the Absolute; Woodstock produces three hybrids: the Progress, the Ideal Steel and the Absolute Steel.
    Brian
