Generator Transfer Panel
Discussion in 'Everything Else (off topic)' started by thewoodlands, Apr 21, 2015.
  1. thewoodlands
    thewoodlands
    How can you tell if an existing Generator Transfer Panel can handle a higher watt generator?
    Inside the Generator Transfer Panel it says 35A ..... 120 ..... 18A .... 240 .... 30A Max.
    We have a 4200 watt portable generator but we're thinking about getting a 8000 running - 10,000 start .... watt generator.
    We do want to put more on the panel so we might need a bigger one.
    wildwest and My IS heats my home like this.
  2. Stinny
    A 10,000 watt gen is a little under 50 amps @ 240 volts, 100 amps @ 120 volts. You'll need a 50 amp / 240 volt transfer panel rating.
  3. KaptJaq
    KaptJaq
    Long Island, NY
    When you are on the generator how much do you plan on using? We have a 6,500/8,000 watt generator and, with the whole house running, it rarely runs hard. We probably stay under 3,000 watts.
    The box you have now is properly rated for the 4,000 watt generator. Anything larger will pop the generator breaker in the transfer box if you push it.
    KaptJaq
  4. thewoodlands
    thewoodlands
    Thanks for the replies, we'll be getting an estimate for a new one.
    eatonpcat and Stinny like this.
  5. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Are you going with a standby unit? I had to put one in at work. I should have done it years ago, my hair wouldn't be as gray as it is now!
    Gary
    eatonpcat and papadave like this.
  6. thewoodlands
    thewoodlands
    A portable generator.
    papadave likes this.
  7. My IS heats my home
    My IS heats my home
    Albany, NH
    While you guys are talking genny's, is natural gas quiter than gas or diesel?
  8. Gary_602z
    Gary_602z
    Our 20kw Kohler standby on propane is a lot quieter then a 6500 gas portable that we have. That said some of the Hondas are quiet and I borrowed a 5000 watt portable from one of by drivers that was fairly quiet.
    Gary
    My IS heats my home and Stinny like this.
  9. basod
    basod
    Mount Cheaha AL
    If you're putting in a portable "not on demand start system"
    the generator @10kW max - is an advertising gimmick, 8kW will max it out - basically what the motor could tolerate for normal fuel consumption rates, or generator winding insulation
    The switching disconnect isn't really the main concern in swapping this over - its the feeder cable from the sub panel to the disconnect, probably 10ga rated for 30amps in it's current configuration
    The feeder cable will need to be upsized in addition to the switch(is has an interrupting rating and internal conductors are probably capable of carrying the current)
  10. MasterMech
    Check the output options of the genny. An 8k/10k may not have a 50A output. In which case a 30A setup should be fine.
    wildwest and thewoodlands like this.
  11. thewoodlands
    thewoodlands
    They came up to give us a estimate, about all we need is a new transfer panel if that along with a new whip.
    They still haven't emailed us the estimate but we're hoping to get that this week.
    wildwest, MasterMech and Stinny like this.
  12. rottiman
    I have a 5000 Honda running on propane. Same noise level but runs a whole lot smoother on propane.
  13. thewoodlands
    thewoodlands
    The contractor called this morning when I was in the woods with the price, we thought the price was good so we'll go with it.
    He'll be putting in an outlet in the floor for my wife and we'll have a new (bigger) Transfer Panel for the generator.
    Hopefully we can get this done before our storm season (high winds) begins which is usually by the end of May thru August.
    From my talks with the electrician, he thinks we can have power to everything and then we'll control what we want on or off.
    Our old generator is from 1998, bought before the ice storm hit. It has been a good little generator so we'll keep it for a back up.
    papadave and wildwest like this.
  14. thewoodlands
    thewoodlands
    The contractor just called back, he's ordering everything he needs Monday. The power company will have to shut off the power when he's ready so we'll see how long that will take.
    Stinny and papadave like this.
  15. thewoodlands
    thewoodlands
    The contractor called me again, everything is in for the transfer panel but we're waiting on a floor outlet to come in which should be Wednesday or Thursday.
    Our storm season (high winds) is getting closer so it will be nice to get the new transfer panel in.
    papadave and Stinny like this.
  16. thewoodlands
    thewoodlands
    We just received a call from our contractor, June 1st is the date he'll do everything.
  17. papadave
    That's great zap.
    How long did he say it'll take?
    Stinny likes this.
  18. thewoodlands
    thewoodlands
    He seems to think just the one day. The power company said they would be here to shut the power off at 8:30 a.m.
  19. thewoodlands
    thewoodlands
    The job got done today, power for the whole house when we lose it.
    We will have to watch what we are running if we want to use the hot water heater.
  20. papadave
    Wow, someone who followed through on doing what he said he'd do and when.
    Gotta' be a nice feeling getting that done zap. Very cool.
    thewoodlands and Stinny like this.
