Gas line upgrade.......they forced my hands
Discussion in 'The DIY Room' started by SD Steve, Sep 18, 2023.
  1. SD Steve
    SD Steve
    South Dakota
    Well, here in South Dakota there is almost no codes for gas lines. You can do almost anything you want. Just make it work and look good. Only the bigger cities require the gas lines to be grounded. That's about it for codes
    And I avoid black pipe if I can.
  2. SD Steve
    SD Steve
    South Dakota
    Why would Galvanized piping be prohibited? Is there a hazard?
    I've never heard of that. And I did it in my house because I don't want them to rust. My basement is quite humid in the spring and summer.
  3. brenndatomu
    I was always told that you don't want to use galvanized on gas line because the galvanizing can flake off and plug an orifice...but recently someone that should know about these things told me that back in the day it was done to keep people from mixing up what pipes are for what...black pipe is gas, galvanized was water line. That sounds more likely to me.
  4. yooperdave
    Yeah, flaking off is what I learned also.
    And, the sulfur added to the gas can break down the zinc coating leading to corrosion
  5. chris
    chris
    SE WI
    pressure factor between black and galvanized as well
    eatonpcat likes this.
