Gas Hot Water Heater (WhirlPool)
Discussion in 'The DIY Room' started by Chvymn99, Sep 23, 2020.
  1. Chvymn99
    kinda of what I was thinking. I’ll try that Saturday morning. And see what I flush out....
    Horkn likes this.
  2. DaveGunter
    DaveGunter
    Or via the anode rod hole, while you are checking the condition of the rod
    Horkn, Chvymn99 and brenndatomu like this.
  3. Horkn
    You may not see anything flush out. It dissolves it totally.
  4. Chvymn99
    Well I chickened out... When I saw that I had a plastic drain valve.... So I'll need to get one on hand before I drain it. But just out of curiousity, I went and shot some water out of the faucet for 1 minute. It was registering about 162-4 when it was set at 130 F... I turned it down to the next notch. Will check it tomorrow.
    But upon reading on the robertshaw gas manifold, I was seeing about the calibration. One of the side items I saw is that the tube that goes into the tank I guess is liquid filled and can loose fluid over its life causing out of calibration reading. Interesting side note.
  5. billb3
    Sometimes just moving the control up and down the temp scale a few times is enough to clean the control.
    I "fixed" the temp control on my mom's Amtrol Boilermate that easily about 5 years ago.
    Horkn likes this.
