Gas Cans....The Vent is Back!
Discussion in 'Chainsaws and Power Equipment' started by XXL, Apr 3, 2016.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    Wondering if we have an invention on our hands? Man the potential is enormous! Something to consider...
    TurboDiesel and Eric VW like this.
  2. 94BULLITT
    94BULLITT
    Frederick County, VA
    The new eagle cans with the funnel are a pain to use. The funnel does not seal to the can, and leaks and makes a mess. I added vents to mine so I could pour fuel in a timely manner. The problem now is the funnel on them is small and the fuel comes out fast and can over flow to the vent has to be regulated by my thumb. I need to get a funnel for fueling and do away with the ones on the cans.
    clemsonfor likes this.
  3. clemsonfor
    Yea. New cans won't happen here. Those would be illegal along with toilets that flush more than 1.6 gallons af water per flush (or is it 1.3?)
    XXL and Eric VW like this.
  4. MasterMech
    That's exactly why I don't like them for small equipment. With equipment big enough to swallow fuel 5+ gallons at a time, typically you can get a nice big steel funnel that will park itself in the filler neck reasonably well.
    If you get Type II safety cans, they have a second "fill" opening that serves as a vent when pouring and they have a flexible metal spout.
  5. Babaganoosh
    Babaganoosh
    Jersey Shore
    What they need to do is make no-spill adapters for the rest of the gas cans. Those ones where you twist the spout a quarter turn and then have to jam it against the tank of what you are refilling suck a bag of balls. I'd buy those in a heartbeat.
    A Visitor and clemsonfor like this.
  6. TurboDiesel
    yea they work great don't they:rolleyes:...plumbers worst nightmare :hair:
    this is what happens when do gooders invent stuff. now you need to flush twice.
    unclefess and clemsonfor like this.
  7. clemsonfor
    Yea but when you pee you save half te water :)
    Luckily I still have old toilets in my house. But relitives don't and my farm house I stay in when I go there has a replacement and many freinds have the new one. You have to be concious of it!!!
    I always forgot my brother and sites in law don't have new toilets and try to be concious of it. But still clog them. And they don't have a plunger!!! How do uou not have one esp with those toilets!. The first time it did one of those delayed flushes from the water pressure of a full bowl. The next time it never unclog get and I told them and no we don't have a pmunger!!! So I had to just leave it. But luckily all that was in there was water. Everything g was down...plugged somewhere in the path. Those toilets are worthless.
  8. Shawn Curry
    Shawn Curry
    Western NY
    I got these from my dad last weekend.
    Good thing too cause I was getting low on the more-spill type spouts. For anything bigger than a chainsaw, I usually remove the spout and just pour from the container. Then the spout will get left somewhere - usually the lawn, where it gets run over by the lawnmower.
    Boozer, jon1212, unclefess and 3 others like this.
  9. Bret Hart
    Bret Hart
    Central NY
    Stuck with nothing but these safety cans at the resort. Crazy expensive and are magnets for moisture.
    MasterMech likes this.
  10. MasterMech
    Storage habits matter, right Bret? ;)
    We reduced the number of cans in the shop to move inventory more frequently. Would also dump cans under 1/2 capacity in larger equipment and refill them to prevent condensation.
    raybonz, TurboDiesel and XXL like this.
  11. Bret Hart
    Bret Hart
    Central NY
    We have several safety cabinets for storage but they're metal too and don't help with the moisture. Can't really do without a lot of them here with this many operators but the cans don't sit more than a few days at a time. Just recently convinced my director to let me switch to non ethanol gas since price is down and I'm way ahead on my fuel budget for the year.
    XXL and clemsonfor like this.
  12. clemsonfor
    At least non E for the two stroke and really small stuff. The big mowers and tractors drink so much it's more like your truck useing it as in its not a big deal.
    XXL likes this.
  13. Bret Hart
    Bret Hart
    Central NY
    We have 3 each of 1000 gallon gas and diesel tanks that everything is filled from except the road trucks. All tanks need at least 500 gallons a week so nothing sits very long thankfully. The non ethanol should help with the fuel issues we see with the specialty machines that sit for a while between uses.
    XXL likes this.
  14. clemsonfor
    Yea those are the ones I was thinking about.
    My buddy says ethonol problems are a wives tale.!! Haha he also really don't work on his own stuff or have much stuff or know people that actually know what the problem is and what caused it anyway!! He said I don't have problems. I said cause you use your stuff probably. I have over 20 gas engines so any problem I see is magnified in that I have much more items to develop a problem.
    XXL likes this.
  15. MasterMech
    That's a lotta gas. Enough that I can't see condensation building up in the fuel tanks with E10 fuel. Heck we have gas stations that don't move that much fuel around here. Lol
    If the turnover in your portable cans is also that high, then you shouldn't see moisture build up. But switching to E0 you can get a cumulative build up over time, at least in the gas containers. (Diesel, like ethanol, is hygroscopic and absorbs small amounts of water). Having the guys completely empty and refill any partially used cans made a huge difference for us.
    raybonz and clemsonfor like this.
  16. Bret Hart
    Bret Hart
    Central NY
    Keeping them full would likely help us with the water issue but I don't speak Burmese and the few guys here that speak both English and Burmese sometimes have a hard time understanding what we need translated. I'm just happy they understand the difference between straight gas and 2 cycle.
    clemsonfor and MasterMech like this.
  17. MasterMech
    :rofl: :lol: :yes:
  18. clemsonfor
    But he also is talking about specialty machines that have fuel sit in them and not the bulk tanks
