Gardening with gutters?
Discussion in 'The DIY Room' started by Pallet Pete, Apr 15, 2014.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I have been looking at using old gutters for gardening lately. My question is what kind of veggies could I grow in them? Green onion of course but what else?
    Thanks fellas.
  2. Grizzly Adam
    Grizzly Adam Guest
    Leeks! Get it? I crack me up!
    Docwu, gbreda, andybaker and 9 others like this.
  3. My IS heats my home
    My IS heats my home
    Albany, NH
    why gutters?
    Pallet Pete likes this.
  4. Pallet Pete
    Ovid
    Because I have a 109' long fence and a small yard. If I attach them to the fence I can easily fit 400 + ft on it without any issue. It is a very sturdy fence.
  5. Pallet Pete
    Ovid
  6. Grizzly Adam
    Grizzly Adam Guest
    I am heading to menards thursday to pick up parts to make a similar hoop house.
  7. tuneighty
    tuneighty
    South Central PA
    Lettuce's, Spinach, Arugula.
    I just threw this together from 1" irrigation tubing. ($55 for a 100' roll) Leftover from the wife's "Hula Hoop" project. I made them a little too long, I think they are 10' each. I will cut them down a bit after tonight's frigid temps.
  8. Stinny
    That's a good idea Pete. Easy to water too.
  9. jetjr
    jetjr
    Pa/Md line
    Anything shallow rooted should be ok. Water retention may be an issue could maybe try a cotton wicking system in the bottom or some of the water bottle spikes like HF sell spaced out every so often. I have read of others doing it.
  10. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I'd like to see how it works out for you.
    I may try a few of these pallet gardens this year. We too, are tight on space. There are quite a few options.
    [​IMG][​IMG]
  11. Pallet Pete
    Ovid
    I did that with one a few years ago and it worked very well!
    fishingpol likes this.
  12. Pallet Pete
    Ovid
    Can you send me what you picked up and what your doing? I am trying to do this without spending a lot...
  13. Daryl
    Daryl
    Flowers. That would be pretty. :)
    SolarandWood likes this.
  14. Grizzly Adam
    Grizzly Adam Guest
    You mean the list? Because I'm not about to mail you all my parts :)
  15. basod
    basod
    Mount Cheaha AL
    If you go the gutter route any leafy green(outside of head lettuce) herbs, radishes and beets for the greens - probably wouldn't be great for setting good sized root/bulbs.
    Snap peas might do well if you had a trellis behind it. The later developing peas/beans probably require too much of a root system and water to justify the space/yield
    Can always put a few summer squash or zucchini 3-4' apart at the base in the ground to catch the missed water.
    Cucumbers will do well if caged from the ground(train them to grow up not out) - a few plants will give you all the pickling cukes one could ever ask for
    Don't seal the gutters tight drainage is required or the seedlings will rot.
    Throw a marigold in here and there on the spacing - the natural scents/oils help repel bugs
    jetjr likes this.
  16. basod
    basod
    Mount Cheaha AL
    After I read the hoophouse link above I figured I'd add real world pro-built experience.
    Buy greenhouse poly - you will replace the cheap crap annually and costs you more in the long run - it's lasts about 3-4yrs...the first time the wind rips up on that luffing poly all your hard work/plants are toast - a big greenhouse could be $$$thousands in losses.
    Don't staple the poly to your end frames or base ledger. Use lathes - one set to anchor initially then wrap over the tacked lathe and place another one directly on the ledger tight to the top of the first lathe.
    Rip 1x4" in half if you don't have pallet material to do this. Rolling excess poly on the top lathe will help even more with stretching.. Doubling the poly and mating a muffin fan to the inside sheet would keep it from luffing and tearing - also adds an air insulation layer
    Stinny likes this.
  17. lukem
    I used to work at a greenhouse....and replaced the plastic twice. This is all good advice. I'll add that you should put the plastic on on a relatively warm day without much of a breeze. Too cool and you won't get a good stretch. Too windy and you'll get taken for a ride...ask me how I know.
    basod likes this.
  18. smoke show
    smoke show
    Pittsfield, Wi
    How do you know?
    billb3 and papadave like this.
  19. lukem
    I took an involuntary ride off the peak of a hoop...got about 20' in the air....then deposited with a certain amount of authority. I was pi$$ed because the plastic tore and we had to refasten a whole side with those stupid cam lock things (not fun)...my boss had the most unbelievable oh chit look on his face...that kind of made it all worth it. Now that I'm a lot older and slightly smarter, I would probably wait out the wind.
    Pallet Pete and smoke show like this.
  20. Grizzly Adam
    Grizzly Adam Guest
    Just picked up 19 pieces of schedule 40 (was going to go 80, but this is prototype so I thought I would go cheap this time. 10 T sections. Still need 5 crosses and 4 corner T's, going to check Home Depot. Maybe I should add a garden hose attachment and drill some sprinkle holes.
    jetjr likes this.
