Garden Dump cart wheels?
Discussion in 'The DIY Room' started by Machria, Apr 6, 2015.
  1. Norky
    Norky
    It's good to spin the tire after filling with slime. I get it in a gallon jug. If it doesn't work on first fill, I put a little more in. I always clean out the valve stem before putting the valve back in too.
    HDRock and cnice_37 like this.
  2. ironpony
    ironpony
    Mid Ohio
    when I have used it I thought you were supposed to drive around a while to distribute it. that's what I did at least.
  3. eatonpcat
    Slime works pretty well for me...Just a mess when the tire comes off!!
    Horkn likes this.
  4. cnice_37
    cnice_37
    Ayup, you gotta spin the tire to get the slime all around the insides. RTFM :p
  5. Machria
    Machria
    Long Island, NY
    Mitch Newton and Horkn like this.
  6. TurboDiesel
    Thats a decent price.
    And NO MORE FLATS !!!:yes:
    Horkn likes this.
  7. Horkn
    I've seen slime not hold what appeared to be a fairly simple hole on the front of my friends Deere lawn tractor. The slime made putting a tube in that tire a real pita. The tire would not pop off that bead, even with a Chevy cavalier's front wheel and my 240 lb self on the plank. Once I started jumping it finally popped off, allowing us to get a tube in it. Slime is nasty to deal with after its been put in a tire.
    BillinTX likes this.
  8. Machria
    Machria
    Long Island, NY
    I've also herd that before. Worse, tire places (if you ever bring the tire in...), REALLY hate that stuff! They get pee'd off if you tell them you put slime in it... I've been at a counter when a tech was preaching to a customer about the mess it makes....
    Horkn likes this.
  9. TurboDiesel
    I've seen an atv tire sling slime all over a machine. It never did fix the leak. And atv tires usually only have 4-11 lbs of air in them
    Horkn likes this.
  10. Hellbent
    Hellbent
    North Central Kansas
    A neighbor I had previously did the expanding foam on his garden tractor. It was a old Deere that weighed a ton and had wheel weights. It worked great for him. He said the trick was you had to let the weight compress the foam and then you added more. He said it took three or four times to get it finished.
    I also worked with a guy who filled his with quick-crete to give him no flats plus extra weight for pushing snow. He drilled a 2" hole in the top of the tire taken off the tractor and poured it in. Let cure and remount. It sure worked but I always wondered what happened when you wore the tread off. I guess a whole new tire and wheel
    Horkn likes this.
  11. Hellbent
    Hellbent
    It has worked well for me but I found the trick is to fill the tire pressure more than you want it. For example 35psi normal 45 psi after slime. I think it gives it a chance to squeeze through the hole and then I take the pressure back to normal. I also found out the hard way (reading the instructions after I already messed up) that you are supposed to drive it for a while after you fill. Dang fine print!
    Horkn and TurboDiesel like this.
  12. HDRock
    I have had problems with my little dump cart tires over the years put in new tubes a couple of times.
    The cart has been living outside for 25 years the tires are cracked all to heck, but it has been working just fine for the last 5 years ever since I put slime tubes in them, these are tubes that come filled with slime and are the best, if you need to take the tire and tube off the not a problem the slime is contained in the tube.
    As far as the red dust caps on there you just have to break them off and there should be a nut underneath on the axle with a cotter pin.
    My 2 cents
    Horkn likes this.
  13. Machria
    Machria
    Long Island, NY
    Thanks guys, but I think it is going to be a much better solution with the Marathon flat free tires. BUT, now that I have a new set of tires, I can always try to fill the old tires with foam, and sell them to YOU guys on ebay!! :D
    Horkn likes this.
  14. HDRock
    Oh, I agree with that , I just wanted to put in my 4 cents.
    Did ya take off the old wheels ?
    Horkn likes this.
  15. eatonpcat
    Are there other choices??
    Horkn likes this.
  16. HDRock
    Don't know what ya mean :confused:
  17. ironpony
    ironpony
    Mid Ohio
    Dually's......
    smoke show, Horkn and eatonpcat like this.
  18. HDRock
    He was asking how to get the wheels off and didn't say if he got the puppies off or not yet
    Horkn likes this.
  19. ironpony
    ironpony
    Mid Ohio
    puppies.....another dog thread:picard:
    HDRock, Horkn and milleo like this.
  20. HDRock
    Hush puppy tires
    Horkn likes this.
