Funnest Craigslist score ever!
Discussion in 'The Wood Pile' started by Midwinter, Aug 8, 2017.
  1. Midwinter
    Also 2017 MS 180, no price listed, and a 2017 MS 180 C-BE, no price listed. Ditto those models for 2016.
    Eric VW and Backwoods Savage like this.
  2. Backwoods Savage
    For a choice there I'd probably go with the 170 or a straight MS 180 if they have one.
    I should say that it is perhaps because of the narrow kerf chain is one reason they cut so good. The only down side to that is you need to sharpen more often and the chain will wear out a but quicker. For sharpening, I have one of the dremel type tools that I can hook onto the battery on the atv so can sharpen it right in the woods when needed. It takes only a couple minutes to do and is easy to do. Just have to be careful to not hold grinder on too long else you'll burn the chain. You can also get some stuff to put on the wheels to keep it cool while grinding. Stihl sells one for around $30 but you can sometimes find them for as low as $10.
    Eric VW and Midwinter like this.
  3. Backwoods Savage
    The 180 should not be much higher than the 170 and that is what I'd go for if it were me.
  4. Midwinter
    This is like having a consult with the head surgeon at Mass General about my bunions! Thanks so much for your advice, and I will report back tomorrow.
  5. yooperdave
    You're really close on that one...closer than you think!
  6. MikeInMa
    Might as well pickup a quart of the pre-mixed fuel. It'll get you going and used to the saw before mixing your own 2-stroke
    Eric VW, bogieb and Midwinter like this.
  7. Mwalsh9152
    Mwalsh9152
    Pelham NH
    If its Nashua outdoor power, they have Echo too.
    Eric VW, Backwoods Savage and HDRock like this.
  8. Mwalsh9152
    Mwalsh9152
    Pelham NH
    my office is at #16, all the way at the end of the building on the dock side is a pile of pallets between the stairs and a trailer, or the loading dock on the other side of the stairs. Take all you want!
  9. Oldman47
    Oldman47
    Illinois
    If you want a good but cheap solution to sharpening a chain, get a Granberg File-n-joimt or one of the copycat ones sold by Oregon and Stihl. It will give a perfect sharp chain and takes only about 5 minutes to do a small chain with no power needed. Even one of the all-in-one file guides made by Stihl can do a good job but it takes more control by the person using it to get a really sharp chain.
    Don't worry about matching the sharpener to the brand of saw or chain. You can do a perfectly fine job on a Husqvarna chain using a Stihl jig.
  10. HDRock
    Yeah , don't overlook the Echos , check out the CS 352 or CS 310
  11. Backwoods Savage
    You could but that stuff is super expensive!
    Also, use mid grade gas rather than regular.
  12. MikeInMa
    Undestood. But for a first time user, it eliminates needing to buy a gas can and oil to mix. Sure, long term mix your own, but for a new chainsaw operator who may not using the saw for periods of time, letting the mix age, there's nothing wrong with pre-mix, IMO.
  13. Midwinter
    We're in the store, 1 qt. Is 8.99.
  14. HDRock
    $36.00 a gal :makeitrain"
    yooperdave, bogieb, Eric VW and 2 others like this.
  15. Midwinter
    We're getting the Stihl MS 180, $199.99. They're just putting some gas in it to start it up. And yes, we're getting a can of the special gas.
  16. Midwinter
    Won't start, husband all sweaty, I'm taking it back to the store to see what we're doing wrong.
    bogieb, Eric VW and Backwoods Savage like this.
  17. HDRock
    Try to start it ,as per manual instructions
    bogieb and Eric VW like this.
  18. Midwinter
    A large man got it to start, it was flooded. They are adjusting the idle, and will give me a lesson.
  19. MikeInMa
    Good idea to have them show you the ropes about it. Good luck with it!
    bogieb, Stephiedoll, Eric VW and 2 others like this.
  20. MikeInMa
    You are going to want to get a container of bar oil, as well.
