Full Belly Tonight
Discussion in 'Modern EPA Stoves and Fireplaces' started by rdust, Jan 1, 2016.
  1. jeff_t
    jeff_t
    SE MI
    Glad to see someone with reasonably sized splits :yes: There's a picture on another forum someplace of eight splits filling my king rather nicely.
    rdust likes this.
  2. rdust
    rdust
    SE, Michigan
    You and Solar know how to fill em. I look at stacks posted and often think the splits look like my kindling would look if I made any. :) I can usually fill the princess with 6-8 splits without cherry picking the stacks. When I see 12-14 splits in a stove I see a lot of extra splitting time.
    jeff_t likes this.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Extra splitting time, less drying time. Some folks aren't on the 3yr plan yet.
    jeff_t and rdust like this.
  4. rdust
    rdust
    SE, Michigan
    True story! My first season my "big" splits were 3x4 rectangles.
  5. rdust
    rdust
    SE, Michigan
    Supposed to be 14* tonight so loaded her up. Even had a few fillers in the rack I could use.
  6. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Have to admit, alot of my wood makes a 20 split load in my princess. Still getting good burn times...... I split small 2yrs ago not knowing the 3+ year plan would come together so quickly.
    TurboDiesel likes this.
  7. SolarandWood
    SolarandWood
    Syracuse NY
    I like 8x8s...conveniently the height of the wedge on my splitter. I think my record was somewhere around 130lbs of 3 year dried in one load. The BK magic is being able to choose to torch it in 12 or 40 hours with a predictable burn throughout.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    SolarandWood likes this.
  9. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Saw the pic, good stuff
  10. rdust
    rdust
    SE, Michigan
    Actually these stove control the burn so well I don't see a dramatic difference with split size. Bigger splits just means less time handling/splitting.
    bobdog2o02 and SolarandWood like this.
  11. SolarandWood
    SolarandWood
    Syracuse NY
    I completely agree on the burn control but all else being equal, bigger splits let you get more weight in the stove.
    bobdog2o02 likes this.
  12. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Your both very right.
  13. HarvestMan
    HarvestMan
    Southeastern Michigan
    That's 4 loads worth for my Fireview. I can get a 12 hour burn on that size load ... 4 x 12 = 48 hours. Alien technology ha! I just need my stove to be 4 times its current size ... 4 x 475 lbs = 1900 lbs. OK, perhaps a bit on the heavy side. FYI - I have a BS in Mathematics ... so there is no point in disputing my calculations. :D
    BTW, love those 8x8 splits ... don't think they would fit through my load door, but will need to measure to be sure.
  14. TurboDiesel
    Door is 8x8.5 but i think you would only get one in
    HarvestMan likes this.
  15. JA600L
    JA600L
    Lancaster, Pa
    Here is the Ideal Steel packed and ready to rock. I won't be home into 5:30. No worries. This load is mostly white ash:dex:
  16. TurboDiesel
    is that a 3d camera? neat pic
    and the light from underneath looks evil...
    [insert evil laughter here]
  17. JA600L
    JA600L
    Lancaster, Pa
    No special camera here. I just got home . It is still 73 degrees upstairs. It was 75 when I left this morning 11 hours ago. I have plenty of heat coming off the stove and huge coals. Life is good :cheers:
    rdust likes this.
  18. rdust
    rdust
    SE, Michigan
    12 hours + since the morning load. 77 in the stove room was 78 when I left, 69 on the t-stat in the hallway which was 70 when I left. High today was 19, weather.com shows current temp is 14 my outside thermometer shows 6 but that always reads low right after the sun goes away. Should make it a couple more hours before reloading.
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Stove Jenga, I can do that.
  20. rdust
    rdust
    SE, Michigan
    Hit the tune up on last nights load wrong! The morning load didn't catch up so torching a quick load before tonight's load. Stove room was 72 after work and tstat was showing 65! Yikes! :emb:
