  1. slvrblkk
    slvrblkk
    Northampton, PA
    Well someone is finally thinking around here! :thumbs:
    badbob, ivanhoe, Luneyburg and 3 others like this.
  2. CleanFire
    CleanFire
    "best thinking while drinking" .. I'll be a genius later. :thumbs:
    ivanhoe, Luneyburg, bogieb and 2 others like this.
  3. CleanFire
    CleanFire
    Winds are 10-15 MPH steady, gusting to 20+ here, had to adjust combustion air down 5% - first time I had to do that this season.. It be Chilly outside today.
    * Hence the "later" above.. Else I'd be using a Calculator, Abacus, and a Slide Rule, to figure it out. :D
  4. slvrblkk
    slvrblkk
    Northampton, PA
    Me too! :rofl: :lol:
  5. Luneyburg
    Luneyburg
    Hills of Central Mass
    Dang Bogie looking pretty frosty as well , I'm sure it was even worse at -17 tonight should be another frosty one for them dang chilly all day and gonna drop quite a bit.
    It appears you have out frosted me Bogie ! Then again gets colder up there anyways thanks for the pics :thumbs:
    bogieb, CleanFire and ivanhoe like this.
  6. Luneyburg
    Luneyburg
    Working on it ! Last night where I don't have to drag my dumb arse out of bed to go to work the next morning so I am going to get purdy dang smart tonight I'm feeling it :D
    ivanhoe, bogieb, CleanFire and 2 others like this.
  7. CleanFire
    CleanFire
    Makes sense - she drinks Vodka. :thumbs:
    ivanhoe, bogieb and slvrblkk like this.
  8. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I'd join you geniuses but med time and drinking time for me is just before my geezer nap.
    ivanhoe, bogieb, PelletHound and 2 others like this.
  9. Luneyburg
    Luneyburg
    Heh I think your on to something CF
  10. Luneyburg
    Luneyburg
    Next time Bear and I am sure there will be a next time with this gang .
    ivanhoe, SmokeyTheBear and CleanFire like this.
  11. badbob
    badbob
    Mine frosts inside the house,but usually not until -10 or below,but we have lower humidity out here.I have the 3" tubing(harman recommended)and(I think I mentioned this before?)bought a aluminum (used,ebay)y valve,for a vacuum system,for wood shop,added a spring,taped over the shaft opening,so it is 95% or more sealed,and just flip the valve when I see frost,burn inside air,for an hour or two.May not work back in your humidity,but works well here.Also,the year before I did this,I slid off the pipe/tubing,whenever I saw frost,never saw any on the inside.
    ivanhoe, bogieb and CleanFire like this.
  12. Luneyburg
    Luneyburg
    Awesome and exactly what i did eventually saying well Dumbarse just pull it off and check the inside ! ( Just wanted to keep JT thinking about Frosted Flakes)
    I can assure you that my dirt basement has more humidity than most basements actually I can guarantee this but having the p43 down there helps significantly and really the only reason I can store my pellets in the basement . Seems for me sub-zero the oak will start its frosting and usually just condensate above zero with a tad bit of frost at the top where it exists the structure.
    Gonna make JT yearn for some more frosted flakes is this thread keeps on keeping on :cool:
