Front Steps Railing Post Cap motion sensing Low Voltage LED Accent Lights for dark days of fall?
Discussion in 'The DIY Room' started by don2222, Sep 15, 2015.
  1. don2222
    don2222
    Salem NH
    Hello
    I saw the first 2 pics at the local Ace Hardware store and thought it would pretty but I would need one of those new slim line routers to cut the post channels. So I picked up the lights and wires on the day of the 20% off anything you can fit in a bucket and brought it all home! I also got a nice Makita Router and 3/8" bit to cut approx 1/4" deep channel with the straight edge guide that comes with the router.
    The connector block with clip leads is easy to install but I drilled a hole in the back of them and mounted them with a wood screw instead of double sided tape for more security. One of the spike connectors did not make good wire contact when I fired up the lights so I had to go back and make sure it pierced the wi properly to make the electrical contact.
    The 12v LED lamp is good for approx 24 years and the motion detector I already mounted above the garage will only turn the lights on when needed so they should last a very, very long time.
    The only draw back is that becaust the low voltage transformer takes a few seconds to warm up before the LEDs lite, so when I drive into the driveway the cap lights come on 30 seconds later. That is how long it takes me to get to them so it works fine for me.
    Anyone else try this? Any tips and how do you like them?
    Pic Store Demo 1-2 -- Ace Hardware Store Display
    Pic 1 - Post Cap LED in aluminum cap and connector block
    Pic 2 - Choosing location to start routing
    Pic 3 - 6 Routing channel 3/8" wide and 1/4" deep for 16 Guage Low voltage 2 conductor wire
    Pallet Pete, milleo, papadave and 4 others like this.
  2. don2222
    don2222
    Salem NH
    Hello
    More pics
    Pic 7 - Top of post Low voltage wire installed with u shaped electrical wire clips
    Pic 8 - bottom of post - drill hole to run wire inside frame nailed to stringers.
    Pic 9 - 1st terminal block with wire pressed into spikes. Wire then goes to second block.
    Pic 10 - Outdoor AC outlet in weather proof electrical box on right side under steps with LED low voltage transformer plug in mounted under door in back of steps. Additional outlet can be used for Rope or Tape LED railing lights.
    Pic 11 - Junction box for 14 guage direct burial electrical cable for AC power coming out of the house under the stairs. This wire goes to the junction box where garage lights connect to motion sensor.
    Pic 12 - Additional 2 AC outlets on right side under steps for more rope or tape lights on motion sensor.
    Final pic - Lights on temperarily to test out system before finished work.
  3. wildwest
  4. papadave
    Lookin' gooder there Don.
    don2222 and wildwest like this.
  5. don2222
    don2222
    Salem NH
