Friend / coworker needs a hand
Discussion in 'The Wood Pile' started by Chaz, Feb 23, 2020.
  1. Chaz
    Chaz
    Southwestern NY
    Thanks
    Yeah, to his benefit it's all pretty much standing dead ash.
  2. Chaz
    Chaz
    Southwestern NY
    Well, there were moments that I was asking for divine intervention.
    :whistle:
    I can say that I'm extremely happy with my current ability to gauge tree height.
    I was virtually spot on when it came to where the top limbs would be.
    I did come close to damaging a small section of fence by not fully accounting a side branch. The tips "kissed" the fencetop, but didn't even fold the top over.
    :D:D:D
    Was really great fun. A bit stressing, but exhilarating as well.
    :thumbs::thumbs::thumbs:
  3. Eckie
    Eckie
    Nice work chaz! Did you have to use any wedges? And like was said, always keep some pucker factor...helps keep you honest and paying attention!
  4. buZZsaw BRAD
    Nice work Chaz :thumbs: How was the adrenaline factor?
  5. buZZsaw BRAD
    this statue was less than 20 ' away from a tricky tree i felled last Spring. It was an ash!
  6. amateur cutter
    Throw bag & a slingshot works well too. Even one of those balloon launchers would work if you know somebody that's got one. Brad uses a slingshot to very good effect, but they ain't cheap. I think the "tater gun was Brett's" chipper1 ?
    Nice work on the trees! Bore cut is very effective.
  7. T.Jeff Veal
    Great job, brother. We is proud of you. Glad everything went safely. The hinges look good IMO. Thanks for showing the FHC spirit.
  8. Barcroftb
    Barcroftb
    The Mitten
    Air cannon was mine at Dennis' Adam. It's called the APTA:
    APTA: Air Powered Tree Access
    There is a giant slingshot as well called the big shot:
    Notch Big Shot Throw Weight Launcher
    However the cheapest rout is to just modify a wrist rocket slingshot:
    DIY – Cheap Throw Line Slingshot (vid)
    Basically you shoot a heavy sinker tied to heavy test fishing line over your desired branch. Then tie mason twine to the fishing line and pull it over the branch. Then tie your pull rope to the mason twine and pull that over the branch.
    If you want to get fancy you can spring for some throw line that is made for this application instead of the mason twine. The mason twine will sometimes break if you aren't careful. I have seen cheap throw line at Menards by the chainsaw stuff.
  9. Chaz
    Chaz
    Southwestern NY
    Definitely worth protecting.
    :yes:
    Yes made much use of my wedges.
    Gave them to my coworker as he had none but steel wedges for splitting. I'll pick up a couple new ones from TSC this week.
    :yes:
    High
    It's quite exhilarating, and a touch nervewracking at the same time.
    Yes, I've only started using a bore cut, as many of mine are too small to manage one.
    I've become a fan.
    Thanks amateur cutter I'll have to go back a few threads I guess.
    Two of the last ones have no branches for at least 35+ ft. Tough for me to get my current rig over branches that high.
    I could likely free fall them safely, but want the added security of a guide rope.
    :thumbs:
  10. Chaz
    Chaz
    Southwestern NY
    Thanks Jeff I appreciate the support and kind words.
    :handshake:
    It was good to get out, and the weather was nice.
    I'm glad that everything fell as it should.
    :thumbs::thumbs:
    Thanks Barcroftb
    I couldn't remember exactly whose equipment it was, but I coulda used it this weekend.
    Haven't told Chazsbetterhalf yet..
    :startled:
    .. but this weekend reminded me that I need to invest in a good maasdam rope puller and rope.
    The 2 ton come-a-long is rather clunky and time consuming for this type of work.
    :doh:
    I'll be glad to get back to "work" and not work so hard.
  11. farmer steve
    farmer steve
    top of the hill york co. PA.
    Good job Chaz.:thumbs: Sorry about the white stuff on the ground.:rofl: :lol:
  12. Barcroftb
    Barcroftb
    The Mitten
    Ifn ya lived closer I'd have come over and helped no probs.
    I really like my rope puller, but I often just set up a simple 2 or 3 to 1 system using my pull rope and an English truckers hitch. Mainly because I often forget the rope puller, or I don't feel like bringing an extra piece of gear.
    If you do decide to go with the rope puller, I can show you some mods that make it gooder. I like the 120' kit at gap arborist supply:
    Masdaam Continuous Rope Puller Kit - Gap Arborist Supply
    chipper1, brenndatomu, Chaz and 6 others like this.
  13. Chazsbetterhalf
    Chazsbetterhalf
    Ya have now. :rofl: :lol::rofl: :lol:
  14. eatonpcat
    Stupid question time...What is a bore cut??
  15. Barcroftb
    Barcroftb
    The Mitten
    Here ya go brother
  16. Backwoods Savage
    Good on you Chaz for helping out a friend. Keep on felling and you'll get better and better at it.
  17. Chaz
    Chaz
    Southwestern NY
    Excellent video.
    :yes::yes:
    One of my hinges gave me some grief.
    Had wedges in, cut the back strap and the tree just shrugged it off.
    :bug:
    So, I had to cut on a weakened tree, which seriously gave me some pucker factor.
    After it dropped, I saw my error.
    Had around 2.5 - 3 inches of hinge.
    :picard:
    That one was a serious learning mistake.
  18. Chaz
    Chaz
    Southwestern NY
    Thanks Dennis.
    Will be dropping more for sure, and learning all I can.
  19. Chaz
    Chaz
    Southwestern NY
    Not a stupid question at all man, I hadn't heard of a bore cut till I read about it here.
    As stated, I've become a fan, and will use it whenever possible.
    :yes:
    :saw:
  20. Chaz
    Chaz
    Southwestern NY
    Ain't much to be done about the white stuff, but that'll go away eventually.
    Then it's mud season.
    :picard:
