Freezing temps, report in. It's Cold out there!
Discussion in 'Everything Else (off topic)' started by bogydave, Dec 30, 2013.
  1. bogydave
    Had those below zero° periods.
    I have some big splits in the wood box that I keep passing over
    knowing the cold will be back.
    2 big rectangle splits in the middle of the new load help it burn longer
  2. papadave
    3° here now, with a forecast low of -2°.
    That means it'll actually get down to either -2, or -10.:mad:
    Very cold, either way.
    Full on Oak loads.
    Went to pick up my wife from work, but forgot to load the stove earlier and didn't want to right before I left.
    House was down to 67, not bad, but 64 by the time I got back about 45 minutes later.:cool:
    In 45 minutes, the stove would melt into the floor w/o a bit of attention.
    1.5 hours later, and we're almost back to 69°.
    Chvymn99 likes this.
  3. papadave
    So, accuweather is telling me it's still 3°, but my outside probe thermo says -4° already.
    This should be fun. I couldn't do this very well w/o the Oak.
    Chvymn99, HDRock and savemoney like this.
  4. HDRock
    Guess what they named this storm coming through the States
    Hercules :eek:
  5. Chvymn99
    Well it's sitting about 15 right now. But here is weather forecast for us in the next 7 days... All I can say is Brrrrrrr...... Thank God for NC30 and Dry wood....I got Hedge, Locust, Oak and Mulberry all staged and ready for action. Good Times....:thumbs:
    concretegrazer and papadave like this.
  6. rottiman
    Currently -25.8 and forcast for -32 overnight with a wind chill of-41. Supposed to warm up to -4 tomorrow and then down to -35 tomorrow night. Both stoves rollin on with 3 yo Red Oak and the house is sittng @ 74. Gotta wonder how long this is gonna carry on.
    Chvymn99 and papadave like this.
  7. bogydave
    Cold there, mild here. :)
    Was outside most of the day playing, fire in the fire pit.
    Beer stayed cold, watched the stars come out.
    kept adding wood to the fire.
    back in a 7:00 pm.
    Up to 34° today, 28° now, nice day. Just need more daylight.
    hoping for more than 2" tonight.
    papadave likes this.
  8. Gark
    Gark
    SW Michigan
    So it's 13f. and no colder predicted overnight. This goofy stove will overburn with more than 4 splits in it, so the night-night load is two fat black locust splits and a white ash in the lower front to start the BL. It will burn all night through the cat, enough heat to keep the propane furnace from starting (that's most important) with an adequate bed of coals to restart tomorrow A.M. No matter that the bedrooms are in the lower 60's: we have comforters and sleeping in cool air is more comfy. Next week's forecast is in the below zero for overnights and the stove will burn but may need a bit of help from the propane furnace. Life is good.
  9. lukem
    Supposed to get double digit negative early next week. That's about as bad as it gets around here.
  10. papadave
    Forecast starting on the 9th is for temps in the 30's until close to the end of the month.
    I'll take it.
    I don't, however, believe it. Seeing, is believing.
    If it's close to those temps, the wood shed gets a reprieve, and so do I.
    Paul bunion likes this.
  11. thewoodlands
    thewoodlands
    Minus -13 with winds at 21 - 25 which puts the wind chill at - 40.
    The combination of the wood stove and the pellet stove going in the basement had the livingroom at 69 & the bedroom at 68.
    Those readings for our area are taken from the Massena Airport, so I think we're a touch warmer, more inline with Saranac Lake NY, they're at -12 with winds at 9 making the wind chill - 30, I'll take that 10 degree swing. :zip:
  12. charlie
    charlie
    Schoharie, NY
    A big fat 1 degree here... High of 6 tomorrow with a low of -14 tomorrow night...
  13. concretegrazer
    concretegrazer
    Southwest MO
    9° here its time to bring the hedge and mulberry to the house.
  14. Paul bunion
    Paul bunion
    The long range forecast here is for above average temps into Feb once past this cold blast. Highs in the 40s after next Wed. See how that pans out.
  15. savemoney
    The temp has climbed up a bit. Now at -2 F, Snowing and a bit of wind. Wife wanted to go out for breakfast and go to Sams Club. Now back home. Very thankful to be back inside wher it is warm. I told her that is the last time I am going out shopping again until the temp warms up some and the wind cuts back.
    Daughter called, No hot water. Their furnace has gone out again, the second time this week. The furnace man was there most of the afternoon on the 31st, but what ever they did then didn't keep it going. Who knows, could be a whole new problem. It is one of those furnaces with the power vent. Uses PVC for a chimney. I think they make an acid in some condensate that erodes the furnace over time. Who ever built the house put it in thinking he would get out of the need of installing a conventional chimney.
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    I've had a power vented boiler for the last 17 years one was a gas fired unit and the other is an oil fired unit. The only issues I've ever had with those boilers was loose connections on the controls. Whoever thinks that quick connects are wonderful needs to be seen by a competent shrink and then locked up. After the third service call on the gas unit I told the guy to do a soldering job, end of calls. Neither of the units were condensing boilers.
  17. bogydave
    31°f here, 20% chance of snow.
    Wish we were getting hit like the N-East .
    Have fun
    Burning the misshaped splits. Don't stack as tight in the stove but
    get thru the mid 20° nights well.
    House 73° this AM
  18. Smokinpiney
    Smokinpiney
    "South" Jersey
    It's been in the high 20's all day and that's gonna feel warm compared to tomorrow. High of 17 and a low of 1! Almost forgot the 35mph wind and snow for tonight. Im headed in to work at 1am to start plowin the lots.
  19. charlie
    charlie
    Schoharie, NY
    2 degrees out , windchill -9... Burning pine and small 1-2 inch rounds of apple wood from my apple tree pruning a few years ago... Progress Hybrid has the house at 75 draft just cracked... Got up to 5 degrees here today..
  20. bogydave
    Youns are getting a real winter this year.
    Makes a wood stove and good firewood a great thing to have.
    Nice to go stand by the stove to soak the bones full of heat :)
    Can't do that with other types of heat
    concretegrazer, HDRock and charlie like this.
