Freedom Fuel and Nations Choice
Discussion in 'The Pellet Bag' started by IHATEPROPANE, Dec 15, 2014.
  1. IHATEPROPANE
    IHATEPROPANE
    :rofl: :lol: I could see how the title could be misleading lol
    Pallet Pete and slvrblkk like this.
  2. IHATEPROPANE
    IHATEPROPANE
    Here is what I got for temps and feed rate. Right in line with expectations:
    Feed rate: 2.8 lbs/hr
    Heat: 144.6
    ttdberg and slvrblkk like this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    What would you compare these to?
  4. IHATEPROPANE
    IHATEPROPANE
    MinuteMan 2.6 142.1
    Freedom Fuel 2.8 144.6
    Okies Platinum 2.9 146.1
    These are my results so far using this particular thermocouple. As I have maintained, for the most part all pellets heat about the same when you look at the feed rate. These first three fall in line perfectly. Considering there is some tolerances and uncertainties to deal with. I would say these all out out the same heat if feed rate was the same. I won't know about ash for a while. But I did notice that these FF may be leaving some stuff in the burn pot.
  5. slvrblkk
    slvrblkk
    Northampton, PA
    Wow, that is definitely good to know! Can't wait to see the ash content of these.
  6. will711
    will711
    Pocono Mts.
    Is there an Arizona area code on the bag :whistle:
  7. Skier76
    Skier76
    CT and SoVT
    Both of these burned so-so in my GCI60. Glad I grabbed a few bags vs. buying a ton or more.
    will711 and IHATEPROPANE like this.
  8. will711
    will711
    Pocono Mts.
    Smart move :thumbs: and welcome to the Show my Friend :D
    Skier76 and IHATEPROPANE like this.
  9. KatwillNY
    KatwillNY
    Ive tried them both and they are crap. at least in my stove. Lots of ash and lots of fines. little heat.
    IHATEPROPANE and slvrblkk like this.
  10. Skier76
    Skier76
    CT and SoVT
    Pic for proof. I have my stove hooked up to a wifi t-stat and it'll show runtime along with room temp. As you can see, the temps on this day dropped under the setpoint. On this particular day, I ran a bag of Fredom Fuel. Usually, I run AWFs or Okie Golds. With those, I'll run near the setpoint all day.
  11. ttdberg
    ttdberg Pellet Pig
    CT
    IHP not to put you on the spot, but can you give a rundown of how your stove is configured to run? I wish I got results this consistent and would like to know how yours is configured so maybe I can try to do the same kind of test? At a high level I have 2 options, room temp and stove temp. I've only ever used room temp mode. Wondering if stove temp mode might get me closer to how your test results are achieved?
  12. IHATEPROPANE
    IHATEPROPANE
    I always test running on my lowest setting in manual mode. My stove is designed to run the auger a fixed amount of time and have it off a fixed amount of time at each setting. So every hour the auger will turn the same amount and in perfect conditions deliver the same exact amount of fuel. I normally let the stove run all night and take temps in the morning. I place the thermocouple one inch in front of the top center heat exchange tube, wait five minutes. Turn the thermocouple on, wait five minutes, and in average mode take that number.
    When the thermocouple is not in average mode the range is usually about +/- 5 degrees from what I posted.
    A Harman may make things more difficult because your stove is constantly changing feed rates.
    Hope this helps.
    ttdberg likes this.
  13. subsailor
    subsailor
    Winthrop, Maine
    Exactly why I've always said it's hard to test for heat output with Harmans. About the only way I can think to do it is run the stove in stove mode, set the feed rate at 1 and set the heat output at max (7). That might get you close.
    IHATEPROPANE likes this.
  14. Yogi
    Yogi
    Framingham, MA
    I did a 10 bag run of Nations choice after cleaning out the stove. It produced 1 gallon of ash and temps on my stove setting 1 around 140 degrees. (I use an IR gun pointed at a specific spot near the air outlet). By weight it was around .9%. We had to tend to the ashes twice a day. For reference, we then I cleaned the stove again and did 10 bags of the recently arrived Okie DF. 20 fluid oz of ash, about 0.15% by weight and the temp was around 165 degrees. So the nations choice was not as bad as some I tried last year, but a far cry from the Okie DF.
    ttdberg, jtakeman and IHATEPROPANE like this.
  15. IHATEPROPANE
    IHATEPROPANE
    Nice input! Those DF are some sweet pellets.
    jtakeman likes this.
  16. ttdberg
    ttdberg Pellet Pig
    CT
    Welcome Yogi, and thanks for the feedback!
  17. ttdberg
    ttdberg Pellet Pig
    CT
    Agreed, essentially I would be starving the stove of fuel, making sure it continuously runs at the MAX configured feed rate (be it 1 or 2 or whatever) by ensuring it can never reach the configured temp. It's basically the same thing that happens when I get home at night and turn on the stove when the house is cold, only in this situation I would be forcing it to occur for an extended period of time.
    subsailor and IHATEPROPANE like this.
  18. IHATEPROPANE
    IHATEPROPANE
    I burned my 5 bags and all went well. The ash was dark, and there was a small ash cake in my burn pot, but it did not interfere with the stove lighting. I am going to burn some Minute Man without cleaning to give me a better idea of how many bags I could burn through without cleaning. My rough estimate would be 8-10. Somewhere between MWP and Vermont's.
    ttdberg likes this.
  19. IHATEPROPANE
    IHATEPROPANE
    I ended up cleaning and loading the Nations Choice. Stove will be running non stop so i should have a feed rate and temp tomorrow morning. Pellets looked normal. More of a normal size pellet in my opinion. I expect to see a lower feed rate and lower temp because of the size compared to what I have run recently.
    ttdberg likes this.
  20. IHATEPROPANE
    IHATEPROPANE
    Results are in:
    MinuteMan 2.6 142.1
    Nations Choice 2.6 136.6
    Now last night temps were a bit colder than when the rest of the testing was done. I will continue to monitor to see if there is a change. But I am pleased so far. As always YMMV
    ttdberg, will711 and slvrblkk like this.
