Forgot To Mix.....hurrdurr
Discussion in 'Chainsaws and Power Equipment' started by reckless, Sep 24, 2014.
Thread Status:
Not open for further replies.
  1. foragefarmer
    foragefarmer
    Central, Virginia
    If you bought it last month you might need to run cause this month is running out.
    • Gasoline-powered equipment may be returned within 30 days of purchase with a valid sales receipt. After 30 days, item may be sent out for repair at the customer's expense, unless covered under warranty.
    clemsonfor likes this.
  2. jharkin
    jharkin
    Unbolt the muffler and look in the exhaust port. turn it over. If you see vertical scoring on the piston skirt its damaged.
    See here, this was a recent example we saw of a guy on another forum i frequent who ran a tank of straight gas in a screaming 14,000 rpm 26cc and blew the motor. Different application than a saw but the result is the same.
    http://www.helifreak.com/attachment.php?attachmentid=534581&d=1410121508
    reckless and HDRock like this.
  3. Cut4fun
    Cut4fun
    OHIO Redneck
    I wanted to say that sooooooo BAD. Thanks Gary for having the NUTS to say it. :yes::dex:
    Oliver1655, UncleJoe, mdavlee and 5 others like this.
  4. MasterMech
    If it's running fine, mix correctly from here on out and consider yourself lucky. Leaf blowers don't see the RPM's that saws do and that may have saved you in this case.
  5. clemsonfor
    If I had better signal today I was gonna say exactly what gary (guido) said
    Cut4fun likes this.
  6. SquareFile
    SquareFile
    somewhere
    But leaf blowers are under a lot of load like chainsaws in the cut. No oil may cause bearing failure prematurely.
  7. MasterMech
    Think about how every straight-gassed saw we all have seen fails. Have you ever pulled apart a saw that was straight-gassed and seen the top-end intact and the bearing toasted? Me neither. ;) Even if the big end bearing did get a little warm, it should be fine from here on out providing it doesn't have a cracked cage. (unlikely) If he had done damage to a bearing it would be noticeably noisy.
  8. SquareFile
    SquareFile
    somewhere
    Most piston failures I see is air to fuel lean seize. My point is a blower is under a great load, much more stressful than high RPM. Bearings have failed before pistons because of lack of oil. Just a guess but I bet manufactures cut corners somewhere in the lower priced equipment. Maybe cheap cages?
  9. SquareFile
    SquareFile
    somewhere
    Actually this whole thread is pointless. The OP admittedly straight gased it for 20 minutes, wants us to help but will return to the store for a refund if it damaged?
    No need to reply MM I'm OUT!
    Carbine and clemsonfor like this.
  10. reckless
    reckless
    That wasn't my question in the op but thanks for questioning my morals.
    To everyone else thanks I will pull the muffler and take a look, unit is running fine currently.
  11. Scotty Overkill
    I'm betting it'll be fine bud......being new, and having had that happen, maybe run it a little rich with oil next tank of gas or two. It'll smoke but it may also help the rings with that extra lube....
    Speaking of oil, I've been running Amsoil Sabre 2 cycle oil and I gotta say I love it!
  12. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    This is your statement, I stand by my prior comments. The dealer nor manufacturer is responsible for your admitted error, on what basis would you try to return it?
    Carbine and Cut4fun like this.
  13. reckless
    reckless
    The problem is this... Who are you to question my actions? Thanks for your opinion though.
  14. Scotty Overkill
    Ok fellas, we're gonna freeze this one as I see it heading south....
    We're not here to judge each other, so let's live and let live.....
Thread Status:
