Forestry - Managing the family property
Discussion in 'Everything Else (off topic)' started by lukem, Oct 25, 2024.
  1. lukem
    Spending a few hours in the honeysuckle hell hole today. PXL_20251123_171043119.jpg
  2. lukem
    I got the first pass on this 2 acre section done yesterday. First pass of many, unfortunately. It's nearly 100% bush honeysuckle coverage and it's hard to keep track of what I've already done so I just focused on the biggest stuff I could find. Some of them were over 10' tall and were 4"+ at the base. I probably cut 400 stems yesterday. I'm going to try to get whatever is too big to spray done this winter then spray everything else next spring.
    The little DeWalt pruning saw was 100% the right tool for this job.
    Loggers haven't been scheduled yet. Not sure when that's going to happen. Sooner the better.
    I'll probably start in on some more tree killing in the areas the loggers won't be in here in a few week. I have a big stand of small walnuts that needs thinned badly. I hate killing walnut trees, but it's way too crowded in there. Lots of small beech trees need to come out too. It's easy to find them now as they are about the only thing left with leaves still on.
    Still lots of work to do, but I'm starting to be able to see the woods again....not just a giant pile of work that needs done.
  3. RCBS
    RCBS
    Over here
    So it'll be a frozen (hopefully) harvest? It wasn't planned but worked out best it possibly could my last sale didn't involve much mud. I think it rained one day while they were in the woods. Otherwise dry and dusty late summer conditions. I'm sure the trucking would have been nearly impossible for sloppy conditions as they were having the skidder pull them up to the yard even on dry dirt. (looooong easement, all uphill)
  4. lukem
    Not sure if it will be frozen or not. The ground is very sandy loam sitting on top of sand/gravel, so it never really gets muddy. Even the bottoms are this way. Everything will be yarded out downhill...should be easy.
  5. morningwood
    morningwood Administrator
    Sprayed a combo of Roundup + 2,4-D to defoliate a bunch of honeysuckle a few months ago when we were still in a drought. I'm hoping that does the trick (I'll know in the springtime). I'd rather not have to cut it all with a pruning saw, or a high dollar brushcutter. Like you, I have a few acres that needs to be cleared out.
    Are you spraying the stumps after cutting them?
    metalcuttr, MikeInMa and brenndatomu like this.
  6. lukem
    I'm spraying the stumps with a mix of diesel, triclopyr 4, and some blue dye. A little bit of that stuff goes a long way...basically a nuke for any woody plant. I can carry around a squirt bottle and only have to refill it once a day, at most, and it doesn't freeze in the cold.
    I don't like spraying over my head so, even though this is a lot more work, I prefer to do this on the big ones. I'll get all the low stuff with some Crossroad (2,4-D and triclopyr) from a backpack sprayer next spring.
    A forestry saw would be nice, but I just couldn't get there on justifying the spend.
    RCBS, metalcuttr, eatonpcat and 4 others like this.
  7. eatonpcat
    Just add some vodka and you have a happy hour!!
    RCBS, MikeInMa, sms4life and 4 others like this.
  8. lukem
    I prefer to add a little bourbon to the applicator (me) after the job is done for the day.
    RCBS, eatonpcat, MikeInMa and 5 others like this.
  9. morningwood
    Great idea about the dye. Are you just using food dye?
    Yep, nothing beats a mouthful of Roundup. Got that a few times this fall when spraying some bigger stuff.
    I can't justify the cost of a forestry saw either. Do like the idea of getting a battery powered pruner because I can use it on these messy walnut trees in my yard.
  10. lukem
    I bought a small container of oil based blue dye since I'm using oil based herbicide. I can't remember exactly what the intended purpose was for it, but I just put a couple tablespoons in per gallon and it works great.
    If you are using water based herbicide you can use "Rit". It's used for dying clothing and is about as cheap as I've found.
    RCBS, eatonpcat, MikeInMa and 3 others like this.
  11. Chud
    Chud
    NC
  12. lukem
    I got notified this week that the NRCS has denied funding for invasive removal. Oh well, doesn't change anything for me and I wasn't really expecting anything anyway.
    RCBS, Chvymn99, brenndatomu and 4 others like this.
  13. lukem
    Haven't posted much, but I've been plugging away on killing honeysuckle, vines, and some unwanted trees. I'm not going to do much on trees until the loggers are done, but I have girdled about 60-80 mediumish beech trees. I have a lot more to do but they are mostly on hillsides and it way too slick out for that right now.
    I spent another tank of gas on honeysuckle today. I have all the big stuff down, just need to spray the rest.
    I also picked out the winners in a stand of walnut trees that needs thinned. I haven't killed the losers yet...feels wrong even though I know it's the right thing to do.
    Chvymn99, fuelrod, walt and 4 others like this.
  14. fuelrod
    fuelrod
    Western Maine
    Is there a market for the beech?
    That's my primary firewood. Btu's are very high (25.2/cord) on the charts and I can get it to dry in a year c/s in a single row.
    I've still got a foot or more of snow in my woods.
  15. Eric Wanderweg
    My thoughts too. The black walnut may not be worth the trouble for OWB fuel, but the beech surely would be.
  16. lukem
    Just for pallet wood. These are way too small to bother with for burning...under 4".
  17. lukem
    Spring has sprung and the multiflora and honeysuckle are showing themselves. I put a huge dent in things last year but I did miss a few. I ended up buying a brush blade for my trimmer and I'm going out tomorrow to cut them off and spray the stumps. This is the time to do it...anything with leaves shouldn't be there right now...and they stick out like a sore thumb.
    The buckeyes are still a few weeks from leafing out...when they do they'll get dosed too.
    Still no word from the loggers. I heard the mill that bought them has a yard full, so I doubt they are in any kind of hurry. I will probably contact my forester next week and see if he has any insight.
    Chvymn99, brenndatomu, billb3 and 2 others like this.
  18. billb3
    If honeysuckle is like wisteria and PI, they can be persistent and need multiple doses.
    brenndatomu and eatonpcat like this.
  19. lukem
    Not with the triclopyr diesel cocktail, at least in my experience. That stuff is one dose death.
    Woodtroll, eatonpcat and brenndatomu like this.
  20. Woodtroll
    Woodtroll
    Mtns of SW VA
    What percentages of the components do you mix? I assume you add an emulsifier as well? Thanks!
