Follow The Build Of The Member Created Custom Saw
Discussion in 'Chainsaws and Power Equipment' started by KilliansRedLeo, Jul 14, 2014.
  1. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    OK, here is how it is going to work. I will put up two polls at the same time, one for the top handle and another for the muffler; these polls will run for 3 days. Based on the votes I will then complete the build.
    I will then put the completed saw up for bids for 3 days only. If no didders then saw will go back to the parts bins.
    mdavlee and DexterDay like this.
  2. DexterDay
    DexterDay Administrator
    Northeast Oh
    Had I not bought the 665, it would have been mine. No questions asked. :thumbs: I will still scrape up some scratch. .
    I sure hope someone takes advantage of this. This is a phenomenal saw.
    Chvymn99 likes this.
  3. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Just had one of the local tree service companys stop by with a pickup truck full of saws to repair. All Stihl 441s and 361/362s for repair (23 saws). My God, those ground crew guys are hard on saws! Some stuck tight, others with almost NO compression, one even had the chain on backwards!
    So, I will be 'off the air' for the next little while.
  4. Chvymn99
    Sounds like you've got your hands full....
    Oliver1655 likes this.
  5. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    They do this to me twice a year, February before the summer business gets going and July/August before the fall season gets going. They bring all the chit they broke in the previous 6 months. This time Stihls, last time Husqvarna. Usually can't fix all of them but most times they get back 75-80% of what they bring. I then end up with trash barrels full of parts some can be used some can't!
    PullinMyPoulan, mdavlee and Chvymn99 like this.
  6. mdavlee
    mdavlee
    Wow that's a pile of saws to work on.
  7. Oliver1655
    Oliver1655
    Central Missouri
    I like the 375 sticker, makes it distinctive & a conversation point.
    When you have the chance, could you get the power head weights? Full of fluids ready to go & dry?
    I'm also curious how the compression & squish came out.
    This has been a great idea/post! :thumbs:
    :popcorn:
  8. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    More like 'a pile of chit' to work on, some have really been rode hard and put away wet. One a near new 441CM stuck tighter than a drum!
    concretegrazer, mdavlee and Chvymn99 like this.
  9. Chvymn99
    Sounds like another good thread....:D..... That you've got.....:thumbs:
    papadave likes this.
  10. mdavlee
    mdavlee
    Must have forgot the oil on that one.
  11. DexterDay
    Northeast Oh
    That's what I was thinking..
  12. DexterDay
    Northeast Oh
    KRL- Sounds like a bunch of work. Snap a few pics if you get a chance :)
    Oliver1655 and Chvymn99 like this.
  13. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Since a base gasket was used, did not even measure the squish, factory usually set squish between .030-.050. Mdavelee offered to port the saw, he likes gaskets so that is what I did. Saw is set pig rich on the top end 11.9-12.5 pulling the chain. Compression dry was 130 with oil 145 or so, saw has barely 20 mins on it. It is not full nor empty right now so perhaps later.
  14. DexterDay
    Northeast Oh
    On a 372 xp, stock compression is around 130-145. So that's about perfect!
    Good job KRL!
  15. MasterMech
    That's a hard saw to kill...... o_O I'd be interested in seeing what happened to it.
  16. DexterDay
    Northeast Oh
    I'd be interested in buying one if they wanted to sell some ;)
  17. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Largest tree service in the city of Rochester and surrounding suburbs. Do both residential, commercial and are under contract to the utilities company to do line clearing and storm related tree removal. Probably in excess of 60 crews out of three locations. Family owned business so they use stuff until there is nothing left of it. Broken non useful parts I get to throw away but any useful stuff goes back to them even if it doesn't run. Tried to buy from them before, no go, they even want the scrap metal back! Most of the stuff they use is just old rebuilt junk, if they bought more than three saws a year I would be surprized!
    Nice guys but TIGHT REALLY TIGHT.
    papadave, DexterDay and Cut4fun like this.
  18. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Did the CM first because it was clean! Saw is fine, they must have gotten into some kind of very small cable, it was wound so tight around the crank on both sides that the saw would not even turn over. Don't ask how they did it, most 'ground crew' guys are not up for a job with Robert Oppenheimer! Got it all out, saw started on second pull. They came to get it immediately!
    cnice_37, Oliver1655, mdavlee and 4 others like this.
