Flue temperatures on horizontal vs vertical
Discussion in 'Modern EPA Stoves and Fireplaces' started by Backwoods Savage, Dec 18, 2013.
  1. Backwoods Savage
    I sort of maintain that the temperature readings will be higher if the flue runs horizontal vs vertical. Am I nuts? It just seems to me that when running horizontally, the hottest point would be right along the top of that pipe whereas on a vertical, the hottest would be more in the center. In addition, it would seem that the horizontal would heat a bit faster. Again, am I nuts? Well, okay, my wife insists that I am so that is covered well.
    charlie, NortheastAl and raybonz like this.
  2. bogydave
    Makes sense to me.
    One reason horizontal pipe slows (is a choke) to draft is
    the higher temps are at the top , lower temp at the bottom & create some turbulence.
    Heat rises, it don't go side ways ,
    forcing it to go sideways is lost draft efficiency
  3. DexterDay
    DexterDay Administrator
    Northeast Oh
    I have 2 Probes. One on my Horizontal and one on my Vert.
    And yes, the horizontal is higher. :)
    So you may be nuts Dennis, but maybe not as nutty as you think :) (still o.k. In my book ;))
    Never took a pic of the upper probe, but I will now. May be until tomorrow before I post. So someone remind me. Pics, or it never happened. :)
  4. NortheastAl
    NortheastAl
    Putnam County NY
    Guess you're not nuts when it comes to this, Dennis. Good that Dex proved your point. Common sense is a not such a common thing to have. :)
  5. Todd
    Todd
    NW WIS
    Your not anymore nuts than the rest of us Dennis. I have a 45 coming directly off my flue collar and if I take my IR gun around the top of it the hottest reading is the top front while the underside reads much cooler.
  6. Backwoods Savage
    Oh, I have to have my wife read this. She'll never believe it! :eek:
    NortheastAl and DexterDay like this.
  7. Woody Stover
    Woody Stover
    Southern IN
    Same here on the tee take-off from my rear-vent Keystone; Top reads much higher than the bottom, and less than the vertical portion of the tee.
