Flue probe thermo. replacement
Discussion in 'Modern EPA Stoves and Fireplaces' started by Beetle-Kill, Mar 27, 2015.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    What is considered the effective life span of a flue probe?
    wildwest likes this.
  2. Highbeam
    Highbeam
    Good question. I suspect a very long time if it is operated within the design range and not physically damaged. The coil spring on your BK's stat is the same thing. The finish of the meter face or the probe rod itself may fail first.
  3. sherwood
    sherwood
    The literature that came with my Condor said one year. Mine is near the end of its second full year and still doing fine. I suspect the higher your average flue temp, the sooner you need to replace the probe.
