first time portin...
Discussion in 'Chainsaws and Power Equipment' started by R.Singletary, Jan 19, 2016.
  1. mdavlee
    mdavlee
    The xtorq is different on the fresh air cut outs and bottom of the skirt.
    R.Singletary likes this.
  2. R.Singletary
    R.Singletary
    ca
    Thank you fur your input...the x-torq is a taller piston...Right??? But all 3 are 50 mm right???...thank you...
  3. mdavlee
    mdavlee
    Xpw is 51.4
  4. R.Singletary
    R.Singletary
    ca
    Thank you fur your in put...that explains it...I slip the x-torq piston in to the cylinder I have been workin on...its the xpw...it went in very easy as did the piston of the xp...I thought all 3 where 50 mm...looks like I need to buy a xpw piston...puttin this project on hold...ugggg...is the stroke the same on thease 3 saws...thank you...
  5. clemsonfor
    Yea the xpw saw is 74cc (right?? Dont positively remember ) and the others are 71.
  6. mdavlee
    mdavlee
    Stroke is the same.
  7. R.Singletary
    R.Singletary
    ca
    Thank you fur your input...the xp and the xpw is the same in design but different in bore...right... By 1.4 mm...thank you...
    concretegrazer likes this.
  8. mdavlee
    mdavlee
    Yes. The transfers on the xpw as you have seen are way smaller.
    concretegrazer and R.Singletary like this.
  9. R.Singletary
    R.Singletary
    ca
    Thank you fur your input...thank you...
    mdavlee likes this.
  10. R.Singletary
    R.Singletary
    ca
    Thank you fur your input Clem...
  11. clemsonfor
    Do you copy and paste the "Thank you for your input.... part"? Haha
  12. R.Singletary
    R.Singletary
    ca
    Lol...thank you fur your input Clem...nope...lol...have a good day...
  13. R.Singletary
    R.Singletary
    ca
    Good evenin friends...I am lookin fur a 51.4 mm fur my xpw...I havent been able to load baileys web site fur a couple of days now...any other place to check...maybe a used one I could clean up...thease 51.4 mm are kinda hard to find...are there any other pistons that are 51.4 mm that will enterchange 372xpw...I seen one that was 51 mm fur a 575xp...will this work in the 372xpw..what is a 3 port piston...thank you...
  14. R.Singletary
    R.Singletary
    ca
    Good mornin friends...dose a husky 375 K have the same piston and rings as the xpw,..thank you...
    clemsonfor likes this.
  15. R.Singletary
    R.Singletary
    ca
    Good evenin...any one know...thank you...
  16. clemsonfor
    Too bad the get saws site is down. You could probably see piston size.
    I'm sure that MM or mdavelee knows or Cut4fun
  17. mdavlee
    mdavlee
    375k or 372xpw is it. No aftermarket options. About $90 or so is as cheap as I've seen them.
    R.Singletary and concretegrazer like this.
  18. clemsonfor
    $90 for rings!!!! Or Piston and rings?
  19. mdavlee
    mdavlee
    Piston and rings
    R.Singletary and clemsonfor like this.
  20. R.Singletary
    R.Singletary
    ca
    Thank you fur your input Clem,..yah it blows...thanks Clem...
  21. R.Singletary
    R.Singletary
    ca
    Thank you fur your input...dosent the 375 K have a 51 mm piston...would it work in place of the 51.4 mm of the 372xpw. What web site did you see the pistons and rings on...thank you...
