Gardening First project for the spring/summer.
Discussion in 'Hobbies and Interests' started by justdraftn, Apr 27, 2018.
  1. justdraftn
    justdraftn
    On the road
    Me too. I can let that pup run 24/7. …..well almost.
    Eric VW, Well Seasoned and bogieb like this.
  2. justdraftn
    justdraftn
    On the road
    Had to move the outside window struts.....oooooppps. No biggie.
    Looks better and makes a much stronger support for the windows.
    All the south window supports are set and ready.
    Hung the fascia on the north roof. Had a couple of 1x4s that I didn't use
    so I whipped up some crown mold drip cap. Looks better than sheet metal.
    Thunderstorm moved in so had to button it up.
  3. Well Seasoned
    Looks really good! You've got talent brother! :yes:
    Eric VW and justdraftn like this.
  4. Chaz
    Chaz
    Southwestern NY
    ^^ x2
    Great work.:thumbs:
    It would make a great solar kiln as well.. just saying.:eek:
  5. justdraftn
    justdraftn
    On the road
    The ties that bind. This door hung in the basement for 65+ years, from the
    day my dad installed it. My family and I walked thru this door thousands of times.
    I took it out last summer and installed a new, insulated door. It was time.
    Like so many things I have changed about this house, I just couldn't toss it out.
    Today, it got a new life. A new beginning. I am my father's son. Waste not, want not.
    It's perfect in it's new home.
  6. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Very nice project going on there. Nice repurpose on the door.
    My dad had a green house on the side of his shed when I was young. I used to really like going in it in the very early spring and enjoying the warmth and mossy smell of the wet brick flooring. It was made of old triple track storm windows and worked well until my friend stepped through one of the panes.
  7. Eric VW
    Awesome thread justdraftn :yes:
    Great work, and as usual excellent photo documentation :handshake:
    Well Seasoned, Chaz and justdraftn like this.
  8. justdraftn
    justdraftn
    On the road
    Thanks!
    Polycarbonate is very, very close.
    Road trip today.
  9. justdraftn
    justdraftn
    On the road
    Uneventful run up the road.
    217 miles round trip. ~4hrs
    gas ~$23
    saving $400 shipping from other suppliers priceless
  10. wildwest
    I'd love to go there some time, awesome you could shop in one!!
    Did you happen to catch the coverage on the Windsor tornado last night? Spooky stuff, I had driven from NW of FTC to Brighton for work and spent my lunch hour in the basement of the Brighton municipal building doing genealogy research when the tornado went over.
  11. MikeInMa
    You actually look like you know what you are doing.
    Excellent job and thanks for sharing!
  12. justdraftn
    justdraftn
    On the road
    My first Menards. It is like a super Target,
    a HomeDepot and Hughy Woods in one.
    I didn't do any "shopping". Just found my stuff
    and back on the road. I will say that the
    service was excellent.
    Just happen to stumble
    across the fact they are partnered w/Amerilux,
    company that makes the polycard.
    Free shipping to the store.
  13. justdraftn
    justdraftn
    On the road
    Thanks! I just need the basic shape in my head,
    then just make it up as you go. :binoculars:
  14. justdraftn
    justdraftn
    On the road
    Besides the door, last weekend when it was raining I threw together
    some insulated covers for vents in the south knee wall. Just foam insulation
    sandwiched in some 1/4" plywood. Liquid nails and brads. I will use some
    foam weather strip on the outside when I mount them.
    Decided to have a first go at the polycarb w/the windows. So far, so good.
    Cut 2x2s out of cedar. 5/8" dado to accept the poly. A lot of milling to get them ready.
    Had to cut weep holes at the bottoms of each. I really don't think they will
    create that much condensation...but, as they say, better to have them and not need
    them.....than.......
    I thought I would screw the frames together at the joints. Not
    a good plan. Cedar much too soft and not enough material. So, need to get
    out of the box on this one. Kreg pocket holes. By adjusting the jig guide and the
    depth of the hole, I can screw the frames to the studs from the inside. So, I dry fit
    the windows into the holes. Bingo!
    Frames got a coat of water seal and should get installed tomorrow.
    Final operation for today was the panel prep. Used compressed air to blow
    out each of the flutes. The tops have to be sealed so bugs can not get in.
    The bottoms are covered w/the vent tape that you get with
    the panel. It allows air to get in, water to get out and keeps bugs out.
  15. justdraftn
    justdraftn
    On the road
    Another good day. Three of the windows are installed. Decided that the bottom window
    on the east needs to open. So it will need some special attention.
    Again, just so impressed w/the Kreg pocket holes.
    I fit the frames onto the poly and slid them into the opening.
    Shimmed them to fit the way I wanted and set the pocket screws. Rock solid!
    Decided to get the insulation/visqueen chore over with. Not too bad.
    Been storing that bundle of stuff for 19yrs. Did almost the whole thing.
    Will finish the little stuff that is left w/a sheet of foam. Much nicer to work with.
  16. Eric VW
    Well Seasoned, bogieb and justdraftn like this.
  17. justdraftn
    justdraftn
    On the road
    Moving along. Insulation is just about done. South knee wall paneled w/some
    1/4" plywood I got for scrolling. It will not be seen once the plant beds are in.
    Opening window came together very well. Once I figure trim, it will be installed
    w/stop and foam weather stripping. Time to get busy.
  18. justdraftn
    justdraftn
    On the road
    Really a fun day. Finished the insulation and visqueen.
    A year ago, on June 8, we got hit w/an amazing hail storm.
    We got a new roof on the house and garage.....a real blessing.
    As I always do, kept some of the scraps.....just incase I might need them.
    The garage is a flat roof. Did not have enough of either the peel/stick or
    shingles to do the whole roof. My wife said, "Can't you use both?"
    Well there's an out of the box idea. Yes I can. Had just enough of both
    to do the job. ......and if I do say so, it is perfect. We both love the way it came out.
    It fits the eclecticism of this greenhouse perfectly.
    Polycarb is cut and ready to install.
  19. justdraftn
    justdraftn
    On the road
    Today was sort of like pay day. ......when you get a reward for hard work.
    I got paid very well today. ......I worked for it, though.
    Polycarb is up. It was a challenge.
    If you every work w/this.....when it comes time to set it, be prepared to
    lay your tools down.....walk away for a few......
    So the hype on this polycarb is it defuses the light.
    When I was standing inside when there was direct sunlight, 80F...…
    did not feel the heat on my skin like it was in direct sunlight.
    But, it does get warm in there in a hurry.
    Could not be more pleased.
    Midwinter, Woodwidow, Chaz and 5 others like this.
  20. bogieb
    Your project is coming along nicely. Love all the pictures you are sharing - much better tha just before and after (as I usually do :emb:)
    Thor, Woodwidow, Chaz and 2 others like this.
