First fire in the Beta Ideal Steel Woodstock stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by BrianK, Nov 23, 2013.
  1. Backwoods Savage
    Some good points Brian. However, I fear some might read this post and a couple others and think that the Fireview and Progress are very slow to heat up. Yes, they are slower than a steel or cast stove but I can not rate them as slow. Case in point is when we returned from DC to find our house with no electric and being after dark, we knew we needed to act as fast as possible. After all, we were very tired just from the long day's drive. The house temperature was 50 degrees and I'm going to say approximately 1 1/2 hours later it was 70 degrees. I do not think 10 degrees per hour is slow.
    In addition, we have never been overly concerned about heating up the stove too quickly. For sure if the stove were new or had been sitting for an extended period, say, out in the barn or garage, then for sure one needs to be careful because the stone would have picked up moisture. In our case, we were not afraid of that so we fired it right up. I do not know how warm it got because I looked to see 70 just as I was getting ready to sack out. I think we rather passed out from exhaustion that night but the house was nice and warm when we got up the next day.
    I'd also like to answer about smoke smell. Very, very rarely do we ever get smoke smell. An exception would be like earlier today after I put wood in the stove. My wife went outdoors and when she opened the door, smoke came inside. We have a stiff swirling wind and being a reload, there is smoke at the start. We smelled it when she opened the door. But when we open the door to reload, we do not get smoke smell.
    On the overfires, they are rare, especially in the Progress. We've been to the 700 degree mark several times but it is not that common. I don't think we've been over 650 at all this year.In fact, I'm amazed when I read that others are burning their stoves at 500 maximum or even 550 maximum. The stove is designed to operate up to 700 degrees so why not utilize the extra heat if you need it?
    Your point on the customization is right on. Some say they want a black box and that is okay if that is what they want but I find it hard to believe that many would want it. The ability to make this stove as you want it is one of its strengths. I'd much rather have a good looking stove rather than a black box any day.
    charlie and BrianK like this.
  2. raybonz
    raybonz Moderator
    Carver, Mass.
    You forgot to mention how cats love to chase the red laser dot lol :D
    fox9988 and BrianK like this.
  3. BrianK
    BrianK
    West central PA
    Thanks Dennis. I think we were just asking too much of the Fireview in our old drafty house and I was nervous because I felt we were pushing it too hard at times. Please don't get the wrong impression, we really liked the Fireview. It was a really nice looking and performing stove and I still prefer the looks of it over this new stove. But we needed more BTUs and I like the quicker heat output. Quicker is, as you point out correctly, relative.
  4. charlie
    charlie
    Schoharie, NY
    Dennis, I find I never need to go more then 500 with the PH... That will get the place to 80 in the stove room... usually 400- 500 is plenty..
  5. charlie
    charlie
    Schoharie, NY
    Looked at mine,,,same one.. Works good, have had it for 3 years...
  6. BrianK
    BrianK
    West central PA
    Tom from Woodstock said
    “No problem. We’ve done the same thing here – many times."​
    fox9988 likes this.
  7. fox9988
    fox9988
    NW Arkansas 72717
    It got to cranking some serious heat through the glass when the 1/2" andirons are glowing:fire:
  8. BrianK
    BrianK
    West central PA
    I definitely wouldn't want to be standing in front of it cooking on the cook top at that point :eek:
    At least not without an asbestos apron.
  9. charlie
    charlie
    Schoharie, NY
    The good thing, the Ideal Steel Stove can take it :thumbs:
  10. charlie
    charlie
    Schoharie, NY
    Brian, take your time centering and drilling your stove pipe for the probe... Since you are going through two walls of pipe, try to keep the drill level... I drilled my hole about 2o inches up my pipe.. 1/4 in bit. Tip of the probe should be about in the center of the pipe.. My gauge hangs out about an inch and a half... That little mounting clip that holds the gauge to the pipe is the nuts!
    Happy Thanksgiving!
    BrianK likes this.
  11. BrianK
    BrianK
    West central PA
    Yep. These Woodstock stoves do inspire confidence.
    charlie and raybonz like this.
  12. Tenn Dave
    Tenn Dave
    Are there any other beta testers out there? It sure would be nice if they would step up to the plate and start sharing some of their results. And it would take some of the pressure off Brian !!
    charlie, raybonz and BrianK like this.
  13. BrianK
    BrianK
    West central PA
    From what I heard in DC there are about a dozen Beta units planned to be in use this winter (some of them are Woodstock personnel).
    We are letting the stove cool off today because we're going to move it out from the corner install about 4 inches tomorrow morning. (Its been twenty hours since we loaded any wood. There are still red hot coals and stove top temp is 115.) The left hand wall is only 9" from the left rear corner of the stove and it hit 150.5 on the IR thermometer during a hot burn (stove tops around 550) a couple days ago so its time for a minor adjustment in positioning.
    With the stove cooled off I finally had a chance to check the operation of the bimetallic coil for the pre-cat air supply. It was sticking a bit after loosening the locking nut and I don't think it has been operating properly. I don't know if the pre-cat air simply decreases emissions or if it also affects temps/burns but I will keep a close eye on it over the next several cycles to see if it is moving with a hot cat.
    And I too would like to see reports from other Beta testers for comparison, especially since my supply of oak/ash/locust is so limited this year.
    I do plan on packing this thing to the gills with some large 3x6 and 4x6 seasoned oak blocks I have set aside and doing a long low burn as the weather warms up a bit this weekend, and record stove temps at intervals during the burn and length of burn.
    Tenn Dave likes this.
  14. Tenn Dave
    Tenn Dave
    Brian, you have been a great sport and we really appreciate it. I look forward to hearing the results of your long, slow oak burn. Thanks again.
    BrianK likes this.
  15. BrianK
    BrianK
    West central PA
    Here's the bimetallic coil for the pre-cat air supply on the right rear of the stove in the closed and open positions. On the Beta units it is behind a glass view panel to assess operation of the coil.
  16. fox9988
    fox9988
    NW Arkansas 72717
    I wish some of the other Beta testers would join the forum and share there experience. Maybe WS could put a bug in their ear?
    charlie, BrianK and raybonz like this.
  17. Tenn Dave
    Tenn Dave
    I might be wrong about this, but I think the goal of Woodstock with this new stove is to achieve Progress Hybrid like burning results ( maybe slightly longer burn times), but at a more affordable price point. And also offer a degree of customization to the purchaser. I do not think they are looking for 40 hour burn times. This stove is not intended to be a smudge pot that sits and smolders all day. It is intended to be a strong heater with a nice fire show with moderate to long burn times that will easily get you through the night with plenty of heat even on the coldest days of winter, and still have a big bed of hot coals for the next fire. Some folks, especially those with no backup heat source, put a huge amount of importance on super long burn times. But for me and the vast majority of stove owners, getting through the night with plenty of heat and a good coal bed in the morning is what counts. 12 hour burns times are great because they usually fit nicely into most people's working schedule. I know I like to check my stove before I go to bed and when I wake up in the morning. And even if it doesn't need any wood, I'm still going to check it for peace of mind. After all, this is a fire you have burning inside your home.
    The following was just my opinion and I hope no one takes offense. :)
  18. charlie
    charlie
    Schoharie, NY
    Great idea!
  19. raybonz
    raybonz Moderator
    Carver, Mass.
    Wow this really is a long burning stove! We are still posting in the 1st fire in the Beta Ideal Steel stove thread! Brian let us know when/if you ever need to add wood to that beast ;) Look out BK Ideal Steel is here! :D
    Ray
  20. BrianK
    BrianK
    West central PA
    Not unexpected, maybe you read the Woodstock Progress Hybrid performance thread?
    :whistle:
    I just dug out the 3"x6" and 4"x6" oak blocks (from a local pallet manufacturer, seasoned since Feb 2012, just shy of 2 years) for a long low burn. I should be able to pack the firebox pretty tight with this stuff.
    I'll start a new thread for that.
