First Fire In New Stove Guidelines Please
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Feb 10, 2016.
  1. yooperdave
    I bought a couple packs of those eco-bricks. Nothing more than pressed hardwood sawdust-no glue. If all else fails, you should be able to pick a few of those up, they may even be on clearance sales this time of year.
    Horkn, Eric VW, HDRock and 2 others like this.
  2. Kimberly
    Kimberly
    The Kangaroo State
    I think it is better now. This is with the door close and damper fully open; chimney is much warmer than when the first fire was built.
    doorclosed.jpg ​
    Elvisss222, Brad38, basod and 13 others like this.
  3. HDRock
    Now your CHOOCHIN :dex: :rootintootin::dancer:
    Sean, DaveGunter, milleo and 5 others like this.
  4. wildwest
    have you smelled the paint curing yet?
    bobdog2o02, milleo, Horkn and 2 others like this.
  5. yooperdave
    One more thing that will improve draft. Use this stuff to seal the pipe joints. The pipe that fits into the stove top thimble is probably most important, make sure it has a good tight seal.
    Rutland Hi-Temp Stove & Gasket Cement
    milleo, Eric VW and wildwest like this.
  6. fox9988
    fox9988
    NW Arkansas 72717
    :smoke::dex:
    Next time, stack the splits. The upper splits feed off the flames of the lower ones.
  7. Eric VW
    Good question!:thumbs:
    :popcorn:
    bobdog2o02, Horkn and wildwest like this.
  8. Well Seasoned
  9. HDRock
    Eeco-bricks will put out some serious heat and last quite long to
    bobdog2o02, Horkn, Kimberly and 2 others like this.
  10. yooperdave
    I wasn't that impressed with them. I'll give them another shot, now.
    bobdog2o02, Horkn and Eric VW like this.
  11. Eric VW
    My dad has always said to burn 3, 5, 7 (prime #'s) or more and not even numbered counts.... Anyone ever heard this? Something about air movement thru the splits. Of course, that is in reference to heating with a pre-pea stove.
    bobdog2o02 likes this.
  12. HDRock
    X2
    if you are burning a partial load stack them up in the middle don't spread them out
  13. fox9988
    fox9988
    NW Arkansas 72717
    Never heard of that. But they do stack better when using a partial load. Kinda like this :stacke:
    Horkn, Eric VW and HDRock like this.
  14. Kimberly
    Kimberly
    The Kangaroo State
    Thanks. Nice to have some warmth.
    Elvisss222, Sean, unclefess and 4 others like this.
  15. Kimberly
    Kimberly
    The Kangaroo State
    It smoked like mad on the first firing; had to unplug the smoke alarm.
    Jeffrey Svoboda, Horkn and Eric VW like this.
  16. HDRock
    I don't know about that but I have found I need at least 3 splits to burn good
    bobdog2o02, Sean, Horkn and 3 others like this.
  17. fox9988
    fox9988
    NW Arkansas 72717
    In case you haven't read it yet, every time you hit a new max high temp it will give off a little paint/smoke smell.
    bobdog2o02, basod, Sean and 5 others like this.
  18. wildwest
    Make sure to plug the smoke detector back in!!
  19. DexterDay
    DexterDay Administrator
    Northeast Oh
    I normally burn 3 split loads at home when I'm here. More heat and faster burns. (Tunnel of love when the doghouse air blows through the center)
    Here is a short vid I just took. When this load burns down, I'll spread the coals to the outside edges and add 3 more until I go to bed and load it full..
    basod, milleo, Horkn and 4 others like this.
  20. DexterDay
    Northeast Oh
    And 9' really isn't enough. You should look into adding another 3' section of class A outside.
    I originally had 15' outside and it worked. But going to 18' really helped a lot with start ups and also being able to close the air down.. a lot!
    That video showed my air closed completely at the beginning and the end. Draft is your friend!!
    Good luck Kim!! We are all rooting for you!!
    Elvisss222, basod, milleo and 6 others like this.
